Results 1 to 6 of 6
Thread: My First Time...Burman
  1. #1
    "Thermionic Apocalypse" -JT nickb's Avatar
    Join Date
    Dec 2009
    Location
    Devon, UK
    Posts
    3,365
    Thumbs Up/Down
    Received: 595/1
    Given: 511/1
    Rep Power
    13
    One of these turned up today. I've never seen one before. Here's a pic. Now you know as much as I do!
    I'd be interested in any history. I'll dig into it today and find out what is under the hood(s).
    0 Not allowed! Not allowed!
  2. #2
    Old Timer J M Fahey's Avatar
    Join Date
    Oct 2007
    Location
    Buenos Aires, Argentina
    Posts
    11,208
    Thumbs Up/Down
    Received: 1,388/18
    Given: 1,056/27
    Rep Power
    26
    Interesting. Post a couple gut shots when you can
  3. #3
    Old Timer Leo_Gnardo's Avatar
    Join Date
    Sep 2012
    Location
    Dogpatch-on-Hudson
    Posts
    5,933
    Thumbs Up/Down
    Received: 1,005/15
    Given: 973/0
    Rep Power
    12
    Quote Originally Posted by nickb View Post
    I worked on a couple of Burman combos around 2007. They were made in the 70's, and used KT77 output tubes. Lucky that JJ had just releases their '77 or the owner was going to have to pay gold dust money for real Genelex. Turned out to be very versatile amps, and well made except for the flimsy chassis they were mounted in.
    Apparently the company floundered but I ran across a new webpage from an an apparently revived Burman a couple years ago. Ordinarily I'd google it for you but I'm running out the door, traveling to Thanksgiving dinner & visits.
    1 Not allowed! Not allowed!
    Enjoy. Every. Sandwich.
  4. #4
    Join Date
    Dec 2007
    Location
    Poland
    Posts
    1,637
    Thumbs Up/Down
    Received: 47/0
    Given: 14/0
    Rep Power
    13
  5. #5
    Supporting Member
    Join Date
    May 2006
    Location
    Staffordshire UK
    Posts
    3,621
    Thumbs Up/Down
    Received: 341/1
    Given: 353/1
    Rep Power
    18
    There used to be a couple of the combos knocking around in my area, but the last time one crossed my bench was maybe 15 years ago.
    I remember them as being a bit of a 2 trick pony, a very clean channel and an early (for the UK) cascading gain 'boogie lead' type channel, but no channel switching.
    There may have been some active tone controls too in there I think.
    Tracy Norton over on the defunct vintageamps.com has documented the schematics; I've kept that in mind in case I ever see one again, as they were built on a JMI AC30 style tagboard with many difficult to follow link wires.
    Tracy Norton Vintage Tube Amp Repair & Restoration
    (626) 296-8339
    Also on ampgarage https://ampgarage.com/forum/memberli...ewprofile&u=54
  6. #6
    Join Date
    Dec 2009
    Location
    Devon, UK
    Posts
    3,365
    Thumbs Up/Down
    Received: 595/1
    Given: 511/1
    Rep Power
    13
    Thanks all. Seem remarkably little is known.Certainly the build standard is above average and the transformers are massive by today's standards.
    More pics:
    Slave (power amp):
    Preamp:
    Preamp schematic ( unusual presence control and lowish impedance inputs).
    PowerPak Preamp.pdf
    Power amp schematic:
    PowerPak Slave.pdf
    As this is being regularly gigged, I had to disconnect the broken voltage selector (under the duck tape) and replace the power connector with a CE approved type with integral fuse. The front panel fuse is now decorative. Also the protective earth arrangement was not satisfactory. I did this in such a way that the original can be restored if need be.
    Only issues were three scratchy pots and a dry joint on the 68k on one of the input jacks. That and the bias set to 6mA. Caps seem in good shape with the exception of the bias filter which I have now replaced. The preamp power indicator was u/s to I removed it's guts and fitted a#47 size AC LED running of the heater supply inside so it looks the same from outside.
    2 Not allowed! Not allowed!
Thread Information
Users Browsing this Thread
  1. First time post, first time building cabinets
    By csparks75 in forum Cabinetry
    Last Post: 02-27-2018, 11:20 PM
  2. Burman 502 reverb spring
    By IGGY in forum Guitar Amps
    Last Post: 01-27-2016, 05:14 PM
  3. Burman 501 combo blows fuse
    By Willholmania in forum Maintenance, Troubleshooting & Repair
    Last Post: 09-12-2014, 01:25 PM
  4. Burman 501 combo reverb problem
    By Willholmania in forum Vintage Amps
    Last Post: 02-20-2010, 09:05 PM
  5. One minute of your time please - Blindtest time!
    By SJE in forum Pickup Makers
    Last Post: 09-30-2009, 02:59 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
