Results 1 to 25 of 25
Thread: Digitech Whammy IV Problem
  1. #1
    Join Date
    Nov 2018
    Posts
    30
    Thumbs Up/Down
    Received: 2/0
    Given: 0/0
    Rep Power
    0
    I have a Digitech Whammy IV that has an issue. Upon powering, all the lights blink a single time and nothing else. The unit has no response from the selector or the switch. The led for the pedal sweep stays lit. The power supply is correct and the unit does the same thing when attempting a calibration. So parts seem to visibly be faulty. I've read this to be a somewhat common experience, so anybody have any thoughts?
    0 Not allowed! Not allowed!
  2. #2
    Join Date
    May 2006
    Posts
    3,833
    Thumbs Up/Down
    Received: 183/2
    Given: 18/0
    Rep Power
    18
    I repaired one last year. And if memory serves, it was a burnt regulator. Those older units, like many digital devices of that era, used more current than recent devices do. The heat-sinking on the 3-pin regulators was fairly modest, and it is also easy to imagine the thermal compound coupling the regulator to the heatsink drying out over time, allowing one or more of the regulators to overheat and burnt out. I'm not saying that is necessarily what it is, but based on my own experience, that's a good place to start. Check the state of the thermal compound as well.
    Earlier this year, I repaired a Diamond Memory Lane pedal for a buddy, and it took several e-mail exchanges with the company's tech support until their tech guy remembered that in one of the earliest runs of the pedal, the distributor they bought their regulators from had sent them a pile of defective regulators, whose heat sink tab was about 1/3 the normal thickness. When they'd power up the pedals to calibrate them, they'd test fine. But because the heatsink was so thin, and the regulator was free-standing without additional heatsinking, it would begin to overheat after about 15 minutes, and drift off-spec, yielding a very annoyingly audible HF whine. Since I imagine they'd set up and calibrate the pedals in less time than that, it took them a while (and probably some customer feedback) to identify the source of the problem.
    Three-pin regulators are wonderful things, but they all demand certain thermal conditions to show their best.
    1 Not allowed! Not allowed!
  3. #3
    Join Date
    Nov 2018
    Posts
    30
    Thumbs Up/Down
    Received: 2/0
    Given: 0/0
    Rep Power
    0
    So you're thinking start with replacing U1 and U2? I read a guy had success with his by replacing the 2 tantalum caps near the chip...no such luck for mine. Any idea what the replacement part values are for U1 and U2?
  4. #4
    Join Date
    May 2006
    Posts
    3,833
    Thumbs Up/Down
    Received: 183/2
    Given: 18/0
    Rep Power
    18
    At the very least, take a reading of the output voltages on those two regulators, to verify that they are, or are not, to spec. Remember, if they aren't providing the right power to the rest of the circuit, why should the rest of the circuit do anything? I realize that one often hears recommendation to replace larger-value electrolytic caps. And while there is an outside chance there might be something amiss with these, this IS a fairly recent product, comparatively speaking, so I'm not expecting anything to have dried out.
    And just so we are clear, you can see in the photo that two of the regulators have heatsinks attached, and one doesn't.
  5. #5
    Join Date
    Nov 2018
    Posts
    30
    Thumbs Up/Down
    Received: 2/0
    Given: 0/0
    Rep Power
    0
    So I tested the regulators, and I don't have the slightest idea what the values *should* be if faulty. I got U3: 13.85 & 8.92, U2: 12.67 & 4.965, and U1: 3.295 & 6.93. I tested them a few more times and got nearly the same values. I can't say I understand the reading for U1.
  6. #6
    Master Destroyer nosaj's Avatar
    Join Date
    Sep 2011
    Location
    Pace, FL
    Posts
    3,118
    Thumbs Up/Down
    Received: 1,021/100
    Given: 142/35
    Rep Power
    11
    Quote Originally Posted by stevenrb718 View Post
    A regulator by definition regulated power. say a 15 volt regulator may have anywhere from 18 - 25 volts input and will put out a steady 15v.
    Got a schematic?
    nosaj
    Binkie McFartnuggets‏:If we really wanted to know the meaning of life we would have fed Stephen Hawking shrooms a long time ago.
  7. #7
    Join Date
    Feb 2010
    Location
    Posts
    11,498
    Thumbs Up/Down
    Received: 1,432/21
    Given: 3,579/8
    Rep Power
    22
    Sounds like you are getting 9V, 5V, and 3.3V out of the regulators. Those are common numbers for digital stuff so quite possibly correct.
    You will need to compare those to the schematic, or post the part numbers stamped on those regulators.
    Just because they don't have tubes doesn't mean they don't have feelings! - glebert
  8. #8
    Join Date
    Sep 2011
    Location
    Pace, FL
    Posts
    3,118
    Thumbs Up/Down
    Received: 1,021/100
    Given: 142/35
    Rep Power
    11
    schematicwhammy4.pdf
    Maybe this will help.
    nosaj
  9. #9
    Supporting Member Jazz P Bass's Avatar
    Join Date
    Dec 2008
    Location
    Wernersville, PA
    Posts
    12,832
    Thumbs Up/Down
    Received: 456/2
    Given: 238/0
    Rep Power
    25
    It looks to me like U3 is snaggered.
    That should be a -5Vdc output.
  10. #10
    Join Date
    Nov 2018
    Posts
    30
    Thumbs Up/Down
    Received: 2/0
    Given: 0/0
    Rep Power
    0
    Quote Originally Posted by Jazz P Bass View Post
    For 1, 2 and 3 the schematic shows +3.3, +5, and -5 respectively. Looks like the one that should be off is U2 by changing about 12.5 in to about 5 out, a -7.5v if I'm reading that correctly.
  11. #11
    Join Date
    Sep 2011
    Location
    Pace, FL
    Posts
    3,118
    Thumbs Up/Down
    Received: 1,021/100
    Given: 142/35
    Rep Power
    11
    You said" So I tested the regulators, and I don't have the slightest idea what the values *should* be if faulty. I got U3: 13.85 & 8.92, U2: 12.67 & 4.965, and U1: 3.295 & 6.93. I tested them a few more times and got nearly the same values. I can't say I understand the reading for U1."
    U1 should be +3.3Vdc You have 3.295
    U2 should be +5Vdc You have 4.965
    U3 should be -5Vdc You have 8.92
    i think you should retest and repost please.
    nosaj
  12. #12
    Join Date
    Nov 2018
    Posts
    30
    Thumbs Up/Down
    Received: 2/0
    Given: 0/0
    Rep Power
    0
    Quote Originally Posted by nosaj View Post
    nosaj
    You read my comment incorrectly. U1 didn't have an output of 3.295, that was the input figure. Output was 6.93. If U1 regulates a +3.3V and my readings are showing a +3.6, sounds close enough. U3 is a -5V, mine shows -4.9v, again sounds good. U2 should be +5v, mine is regulating 12.67 in down to 4.965 out: -7.7v....
  13. #13
    Join Date
    Sep 2011
    Location
    Pace, FL
    Posts
    3,118
    Thumbs Up/Down
    Received: 1,021/100
    Given: 142/35
    Rep Power
    11
    You cannot input 3.295 and get output of 6.93.. grab a datasheet the input output pins change.
    This makes no sense
    U2 should be +5v, mine is regulating 12.67 in down to 4.965 out: -7.7v What does the meter say 4.965 or 7.7.. just give us what the meter reads , not the subtractions between the 2 values.
    Thanks,
    nosaj
  14. #14
    Join Date
    Feb 2010
    Location
    Posts
    11,498
    Thumbs Up/Down
    Received: 1,432/21
    Given: 3,579/8
    Rep Power
    22
    Don't even need the datasheet, the schematic calls out the pin numbers, 1,2, and 3. You can see all 3 regulators have outputs at different pin numbers.
    I think we are all in agreement about U1 and U2 being ok.
    Need voltage readings for U3 pins 2 (input) and 3 (output). They should both be negative voltages.
  15. #15
    Join Date
    Sep 2011
    Location
    Pace, FL
    Posts
    3,118
    Thumbs Up/Down
    Received: 1,021/100
    Given: 142/35
    Rep Power
    11
    Quote Originally Posted by g1 View Post
    Just second nature to tell someone that. like finding the schematic.
    nosaj
  16. #16
    Join Date
    Nov 2018
    Posts
    30
    Thumbs Up/Down
    Received: 2/0
    Given: 0/0
    Rep Power
    0
    Quote Originally Posted by Mark Hammer View Post
    The pins on the 7905 are different than the other regulators. So after a re-test knowing that, U3 gave an input of -13.76v and an output of -4.95v. Looks like the regulators are giving proper power. Which leaves me stuck again.
  17. #17
    Join Date
    Sep 2011
    Location
    Pace, FL
    Posts
    3,118
    Thumbs Up/Down
    Received: 1,021/100
    Given: 142/35
    Rep Power
    11
    Ok time to follow where power should go. Based on the blink first I would find CS4224 check pin 18 for +5vdc.
    I would suggest as a learning experiment to pick a chip on pcb then google search the datasheet for it. ex jrc4558 to see which pins are power .
    nosaj
  18. #18
    Join Date
    Nov 2018
    Posts
    30
    Thumbs Up/Down
    Received: 2/0
    Given: 0/0
    Rep Power
    0
    The bill of materials show U6 as a CS4224 but U6 in mine is a CS4221.
  19. #19
    Join Date
    Sep 2011
    Location
    Pace, FL
    Posts
    3,118
    Thumbs Up/Down
    Received: 1,021/100
    Given: 142/35
    Rep Power
    11
    Pull the datasheet and see if you can spot the difference between the IC's.
    nosaj
  20. #20
    Join Date
    Nov 2018
    Posts
    30
    Thumbs Up/Down
    Received: 2/0
    Given: 0/0
    Rep Power
    0
    giving about 4.7v
  21. #21
    Join Date
    Nov 2018
    Posts
    30
    Thumbs Up/Down
    Received: 2/0
    Given: 0/0
    Rep Power
    0
    No more ideas?
  22. #22
    Join Date
    Feb 2010
    Location
    Posts
    11,498
    Thumbs Up/Down
    Received: 1,432/21
    Given: 3,579/8
    Rep Power
    22
    The CS4221 and CS4224 are almost identical, so I think you can use the schematic from post #8 above.
    Are you able to check for clock signal with a scope? It is shown MCLK at the upper right of pg.3 on schem.
    (And at pin3 of U6/CS4221)
  23. #23
    Join Date
    Nov 2018
    Posts
    30
    Thumbs Up/Down
    Received: 2/0
    Given: 0/0
    Rep Power
    0
    No unfortunately I can't.
  24. #24
    Join Date
    Feb 2010
    Location
    Posts
    11,498
    Thumbs Up/Down
    Received: 1,432/21
    Given: 3,579/8
    Rep Power
    22
    I think you may have gone about as far as you can without a scope.
    It used to be fairly common for the crystal oscillators to go bad when units were dropped. That's why I asked about the 24mhz clock signal. Maybe they are more robust now, but they are cheap, like $1 or less. So it may be worth a shot to replace it.
    It's the metal can near U9. You would need a 24MHz crystal, smd leads, in a package with the same physical dimensions.
    Aside from that 'shot in the dark' maybe someone else will have some other ideas.
  25. #25
    Join Date
    Nov 2018
    Posts
    30
    Thumbs Up/Down
    Received: 2/0
    Given: 0/0
    Rep Power
    0
    Well after finally getting the crystal in, I swapped it out and plugged it in. Initially, all the LEDs were lit on the board without change. Upon unplugging, and plugging back in, we're back to the pedal sensing LED being the only thing lit with no effect or change with knob turning or switching.
Thread Information
Users Browsing this Thread
  1. Looking for Digitech Whammy Schematic
    By SoulFetish in forum Schematic Requests
    Last Post: 01-07-2019, 07:31 PM
  2. Digitech Whammy 4 problem
    By jman3 in forum Guitar Effects
    Last Post: 03-22-2016, 06:08 PM
  3. Digitech Whammy freezing up
    By Nyqusit5 in forum Guitar Effects
    Last Post: 12-18-2012, 01:32 PM
  4. Digitech Whammy Rotary Encoder
    By EstynEstyn in forum Guitar Effects
    Last Post: 03-18-2011, 07:30 PM
  5. Will a Digitech Whammy do everything a Boss PS5 does?
    By elvis80 in forum Guitar Effects
    Last Post: 03-27-2010, 12:09 AM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
