Originally posted by Mark Hammer
View Post
Digitech Whammy IV Problem
Originally posted by stevenrb718 View PostThe pins on the 7905 are different than the other regulators. So after a re-test knowing that, U3 gave an input of -13.76v and an output of -4.95v. Looks like the regulators are giving proper power. Which leaves me stuck again.
I would suggest as a learning experiment to pick a chip on pcb then google search the datasheet for it. ex jrc4558 to see which pins are power .
nosajsoldering stuff that's broken, breaking stuff that works, Yeah!
The CS4221 and CS4224 are almost identical, so I think you can use the schematic from post #8 above.
Are you able to check for clock signal with a scope? It is shown MCLK at the upper right of pg.3 on schem.
(And at pin3 of U6/CS4221)Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Originally posted by g1 View PostThe CS4221 and CS4224 are almost identical, so I think you can use the schematic from post #8 above.
I think you may have gone about as far as you can without a scope.
It used to be fairly common for the crystal oscillators to go bad when units were dropped. That's why I asked about the 24mhz clock signal. Maybe they are more robust now, but they are cheap, like $1 or less. So it may be worth a shot to replace it.
It's the metal can near U9. You would need a 24MHz crystal, smd leads, in a package with the same physical dimensions.
Aside from that 'shot in the dark' maybe someone else will have some other ideas.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Originally posted by g1 View PostI think you may have gone about as far as you can without a scope.
