Boss OD-2. LED issues.
  • Boss OD-2. LED issues.
    Embarrassed to admit this pedal is beating me atm
    Pedal ops ok.
    Led only works on battery. Nothing on boss pwr adapter. If I provide an earth to the led at r53 it glows bright. If I Bypass D1 and r2 (ie pin 5 to ground) led bright. (Replaced both)
    At a loss. I’m sure the issue is staring me in the face!
    Cheers Gav
    Cheers,
    Gavin
    Tone, its in your fingers mate!!
    schematic?
      Do you have something plugged into the input jack? The ground is completed by the jack shorting ring to sleeve when a plug is inserted.
      Schematic here:
      https://www.hobby-hour.com/electroni...-schematic.gif
        Cheers,
        Gavin
          Yep,there's a jack in the input. all its grounds checked ok The pedal works fine. its just the LED. LED works fine on Battery.
          Cheers,
          Gavin
            D1 and R2 are good?
              Removed and Tested good. substituted both no diff.
              Cheers,
              Gavin
                Some boss pedals the led won't work on adapter if it's not the specified boss adapter. Does it call for the PSA or ???
                  Here's the info: https://music-electronics-forum.com/...l=1#post512364
                    G1,
                    You sir are a legend.
                    I thought I was going mad. Certainly done my duds on this job, but have learnt something, so happy!
                    Cheers mate
                    Gav
                    Cheers,
                    Gavin
                      Glad to be of help. Fortunately, it was one we had just discussed recently, so I could still recall it.
