Page 6 of 6 FirstFirst 123456
Results 176 to 203 of 203
Thread: 5F6A low volume
  1. #176
    Join Date
    Feb 2010
    Location
    Posts
    11,759
    Thumbs Up/Down
    Received: 1,615/23
    Given: 4,135/11
    Rep Power
    22
    Why are you worried about 5.7VAC at the heaters? Is it causing a problem?
    It should run fine like that. If anything, it's better than running heaters 10% over, which many amps do.
    4 Not allowed! Not allowed!
    Just because they don't have tubes doesn't mean they don't have feelings! - glebert
  2. #177
    Join Date
    Dec 2013
    Location
    Sicily-Italy
    Posts
    105
    Thumbs Up/Down
    Received: 7/0
    Given: 10/0
    Rep Power
    6
    This is a small video that you hear background noise. Can you help me to find problem?
    https://youtu.be/vx6LWXCLwwQ
    0 Not allowed! Not allowed!
  3. #178
    Bent Member Chuck H's Avatar
    Join Date
    May 2007
    Location
    pacific north west
    Posts
    15,349
    Thumbs Up/Down
    Received: 2,323/4
    Given: 2,705/0
    Rep Power
    30
    That sounds like instability and/or possibly a bad tube or tubes to me.
    Do any of the controls affect the noise? If you turn down the treble does it stop?
    If you turn up the volume and treble does it get worse?
    If you tap on the tubes, what noises do they make?
    "Never bet your life on somebody else doing their job." SoulFetish's good friend
    "Being born on third base and thinking that you must have hit a triple is pure delusion!" Steve A
    "Back to the amp. It makes horrible sounds when I play my guitar thru it... because I suck at playing guitar." Mike6158
  4. #179
    Join Date
    Dec 2013
    Location
    Sicily-Italy
    Posts
    105
    Thumbs Up/Down
    Received: 7/0
    Given: 10/0
    Rep Power
    6
    I refer to background hum like not to whistles, even if this is a problem. Anyway, the whistles disappears after few minuts
    Hum is not affected by controls.
    Only V2 tube is noise on speaker when I tap it. But I changed three tubes in V2 and it is always noise at tap.
  5. #180
    Join Date
    Dec 2013
    Location
    Sicily-Italy
    Posts
    105
    Thumbs Up/Down
    Received: 7/0
    Given: 10/0
    Rep Power
    6
    Quote Originally Posted by Chuck H View Post
    I'm amazed! I discoverd that V3 tube was too hot, then I swap it with new tube. Background hum and whistles are disappeared but amp volume is slightly decreased.
    Let's say that the volume that was first heard at 1 now we hear at 3
  6. #181
    Join Date
    May 2007
    Location
    pacific north west
    Posts
    15,349
    Thumbs Up/Down
    Received: 2,323/4
    Given: 2,705/0
    Rep Power
    30
    Have you taken Helmholtz advice in posts 144 and 154 where he mentions cleaning and possibly tightening the tube sockets? If not then it's the very next thing you should do.
  7. #182
    Supporting Member
    Join Date
    Mar 2018
    Location
    Germany
    Posts
    2,270
    Thumbs Up/Down
    Received: 1,729/1
    Given: 981/2
    Rep Power
    5
    I thought the V3 socket was replaced (#170)? Can you post a picture?
  8. #183
    Join Date
    Dec 2013
    Location
    Sicily-Italy
    Posts
    105
    Thumbs Up/Down
    Received: 7/0
    Given: 10/0
    Rep Power
    6
    Yes, I replaced all three preamp socket.
    This morning I turn on amp and I can confirm that volume is low compared to before.
    I measured voltage at pin 5 of power tubes and it is -44VDC. Is this too cold bias? Voltage across 1ohm resistors at pin 8 of power tubes is 22mV
    Also, I measured heater voltage and it is very very low, only 5VAC. I measured voltage at wall and it is 210VAC, then 12.5% less than nominal primary winding of my Hammond PT, that should give 6,7VAC heater voltage unload.
    Could one of these be the cause of low volume?
    Anyway, the heater voltage is a problem in my opinion.
    What to do?
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	51872   Click image for larger version.
  9. #184
    Join Date
    Feb 2010
    Location
    Posts
    11,759
    Thumbs Up/Down
    Received: 1,615/23
    Given: 4,135/11
    Rep Power
    22
    Can you put that other tube you had for V3 back in? Does the volume come back up?
    Your line voltage regulation from the power company is horrible. You need to check it every time you are doing any work on the amp.
    If your AC line is dropping as low as 210VAC, then you may have to do something about the heater voltage.
    When I said 5.7V heaters was ok, I was thinking that it would not go lower.
  10. #185
    Join Date
    May 2007
    Location
    pacific north west
    Posts
    15,349
    Thumbs Up/Down
    Received: 2,323/4
    Given: 2,705/0
    Rep Power
    30
    I'm starting the think the inverse bucking transformer idea is a good one. The only rub would be that the amp may experience voltages that are too high whenever it's plugged in elsewhere.
    1 Not allowed! Not allowed!
  11. #186
    Join Date
    May 2007
    Location
    pacific north west
    Posts
    15,349
    Thumbs Up/Down
    Received: 2,323/4
    Given: 2,705/0
    Rep Power
    30
    Hey, wait a minute... My math alarm went off at some point. If 220V into a 240V primary is giving 5.7V then 210V should still be about 5.5V. Not 5V. Something else is going on.
  12. #187
    Join Date
    May 2007
    Location
    pacific north west
    Posts
    15,349
    Thumbs Up/Down
    Received: 2,323/4
    Given: 2,705/0
    Rep Power
    30
    vinceg,
    Can we please see a photo of the how the transformers are mounted? Something looks odd in your interior gut shots and I need to see how the transformers are mounted to understand it.
  13. #188
    Join Date
    Dec 2013
    Location
    Sicily-Italy
    Posts
    105
    Thumbs Up/Down
    Received: 7/0
    Given: 10/0
    Rep Power
    6
    Quote Originally Posted by g1 View Post
    No, other tube is bad, it broke and has air in. I can try another new tube.
    The other day I had a 218V wall voltage and all out voltage of PT unload were about 8% less that nominal. Heater voltage were 6.2 unload. With tubes in it were about 5.7.
    yesterday, wall voltage were 210V, then about 12.5% less and heater voltage were 5V with tubes in. Is normal a drop voltage with tubes in, right?
    vinceg,
    Ok, later I put pictures
  14. #189
    Join Date
    Dec 2013
    Location
    Sicily-Italy
    Posts
    105
    Thumbs Up/Down
    Received: 7/0
    Given: 10/0
    Rep Power
    6
    Now, wall voltage is 220V, heater voltage at PT unload is 6.2V and load 5.6V
    I did some tests. I measured voltage at V3 pins and I discovered that there is a 28V at pin 8 cathode.
    I changed V3 tube and now there is a 50 Hz background hum non affected by controls but volume is increased and cathode voltage is 35V.
    Then, with one tube, hum but volume right, with other tube no hum but volume lower
    Wall voltage is decreased to 210 and heater voltage with amp turn on and tubes in is 5V
  15. #190
    Join Date
    May 2007
    Location
    pacific north west
    Posts
    15,349
    Thumbs Up/Down
    Received: 2,323/4
    Given: 2,705/0
    Rep Power
    30
    I think that low volume tube must be bad (good call g1).
    In my experience Hammond transformer heater voltages are a little high rather than low. Did you measure unloaded voltage with all tubes out or just power tubes out? Your loaded voltage with wall at 220V should probably be about 6V or a little more. That power transformer has a 4A (amps) filament winding and your amp should be drawing 2.85A from it (with the pilot lamp). I'm not ready to chalk up your low filament voltage entirely to the low mains voltage yet. I think something else may be contributing to the problem.
    I wasn't clear about what I wanted in a photo I guess. I want to see how your transformers (both of them) are mounted on the under side of the chassis.
  16. #191
    Join Date
    Dec 2013
    Location
    Sicily-Italy
    Posts
    105
    Thumbs Up/Down
    Received: 7/0
    Given: 10/0
    Rep Power
    6
    Yes, my PT has a 6.7V unloaded heater voltage with the correct 240V primary voltage.
    This morning I measured unloaded heater voltage directly at PT wire by open fuse holder and this was 6.2V
    This is a picture of trasformers
  17. #192
    Join Date
    Dec 2013
    Location
    Sicily-Italy
    Posts
    105
    Thumbs Up/Down
    Received: 7/0
    Given: 10/0
    Rep Power
    6
    I want to give you an update. I tried to remove V1 and hum is still there, I remove V2 and hum is stille there slightly quieter, I remove V3 and hum is disappeared. Then I swap V2 and V3 without changes, so I tried other new tubes on V3 and hum is disappeared but volume is decreased about 50% less. Then, I tried all my 12ax7 in V3 and no changes. I decided to reading voltages:
    B+ 410VDC
    V1
    pin1 210-220
    pin3 1.8
    pin6 215-225
    pin8 1.8
    V2
    pin1 188-190
    pin3 1.1
    pin6 328
    pin8 188
    V3
    pin1 271
    pin3 18
    pin6 375
    pin8 18
    V4
    pin4 420
    pin5 408
    pin6 -45
    pin7 408
    V5
    pin4 408
    pin5 408
    pin6 -45
    pin7 405
    In the same moment:
    wall voltage 213VAC
    heaters unloaded 5.95
    heaters loaded 4.6
    I noticed that fuse holder that contain 4A fuse for heaters wires were hot, I do not know if it is normal
ID:	51924   Click image for larger version.
  18. #193
    Join Date
    May 2007
    Location
    pacific north west
    Posts
    15,349
    Thumbs Up/Down
    Received: 2,323/4
    Given: 2,705/0
    Rep Power
    30
    Would the V3 cathode voltage of 18V be taken with the tube that made the amp lower in volume?
    Fuse wires shouldn't be hot. There must be resistance very near the area getting hot. There should not be resistance in the wire or the fuses to make them hot.
    I don't see anything wrong with your transformer layout. I cant see all the transformer wires though. There are some "lead dress" (wire routing) issues in your build though. But we should fix the low voltage and hum problems first.
    Take the preamp tube that has been causing low volume whenever it's used and throw it away. It's not good and using it confuses the tests.
  19. #194
    Join Date
    Dec 2013
    Location
    Sicily-Italy
    Posts
    105
    Thumbs Up/Down
    Received: 7/0
    Given: 10/0
    Rep Power
    6
    Yes, the V3 cathode voltage of 18V is with the tube that made the amp lower in volume and quiet but the same tube before works fine and amp had hum.
    I do not know how to do
  20. #195
    Join Date
    May 2007
    Location
    pacific north west
    Posts
    15,349
    Thumbs Up/Down
    Received: 2,323/4
    Given: 2,705/0
    Rep Power
    30
    Quote Originally Posted by vinceg View Post
    That tube is not good. It only makes the hum less because it makes the gain less. Don't use that tube anymore.
    You should have about 5.6V (loaded) on your heaters at 213 wall volts. I think something might be wrong with your heater wiring or a tube filament. This could also be causing the hum.
    Try removing the pilot lamp and re test the loaded heater voltage.
  21. #196
    Supporting Member
    Join Date
    Mar 2018
    Location
    Germany
    Posts
    2,270
    Thumbs Up/Down
    Received: 1,729/1
    Given: 981/2
    Rep Power
    5
    V3
    pin1 271
    pin3 18
    pin6 375
    pin8 18
    Seems we still have the same problem as discussed before the socket change. As already mentioned, the high plate voltage at pin 6 (as well as the low common cathode voltage) mean that one of the triodes is not conducting current. (Its a double-triode having 2 separate heaters. One is internally connected to pins 9 and 4 , the other to pins 9 and 5. By jumpering socket contacts 4 and 5 the heaters are wired in parallel.)
    If only one of the triodes is operative, this results in low output and hum.
    Can you check that both filament wires are glowing?
    I suspect a socket wiring error/problem, especially regarding heaters. Can you check heater voltages between pin 9 and pins 4/5.
    Please check socket jumper connections between pins 4 and 5 as well as between pin 3 and 8. Also any wires shorting?
  22. #197
    Join Date
    May 2007
    Location
    pacific north west
    Posts
    15,349
    Thumbs Up/Down
    Received: 2,323/4
    Given: 2,705/0
    Rep Power
    30
    I suspect a socket wiring error/problem, especially regarding heaters. Can you check heater voltage between pin 9 and pins 4/5.
    Please check socket connections between pins 4 and 5 as well as between pin 3 and 8. Also any wires shorting?
    vinceg's reports indicate that this voltage condition only happens with one of his preamp tubes and not others and that it was that tube that was in the amp when these last voltage readings were taken.
  23. #198
    Master Destroyer nosaj's Avatar
    Join Date
    Sep 2011
    Location
    Pace, FL
    Posts
    3,214
    Thumbs Up/Down
    Received: 1,096/102
    Given: 146/35
    Rep Power
    12
    Dumb question. Is it always the same tube in that socket or does a differsnt tube give roughly same data?
    nosaj
    Binkie McFartnuggets‏:If we really wanted to know the meaning of life we would have fed Stephen Hawking shrooms a long time ago.
  24. #199
    Join Date
    Dec 2013
    Location
    Sicily-Italy
    Posts
    105
    Thumbs Up/Down
    Received: 7/0
    Given: 10/0
    Rep Power
    6
    Update
    Heater problem is resolved, the cause was fuse holders. I noticed that moving heater wires pilot lamp went out. Now I've wall voltage of 230V and heater voltage of 6.1V
    Also I change the tube and now amp has right volume. I'm surprise to note how tubes are bad
    Hum remain to be fixed.
  25. #200
    Join Date
    Dec 2013
    Location
    Sicily-Italy
    Posts
    105
    Thumbs Up/Down
    Received: 7/0
    Given: 10/0
    Rep Power
    6
    Quote Originally Posted by nosaj View Post
    nosaj
    Believe me, I got confused. I think that tubes fall down because low heater voltage
  26. #201
    Supporting Member
    Join Date
    Mar 2018
    Location
    Germany
    Posts
    2,270
    Thumbs Up/Down
    Received: 1,729/1
    Given: 981/2
    Rep Power
    5
    Update
    Please update V3 voltages.
  27. #202
    Join Date
    Dec 2013
    Location
    Sicily-Italy
    Posts
    105
    Thumbs Up/Down
    Received: 7/0
    Given: 10/0
    Rep Power
    6
    Now it is correct
    V3
    pin1 255
    pin3 41
    pin6 252
    pin8 41
  28. #203
    Join Date
    Dec 2013
    Location
    Sicily-Italy
    Posts
    105
    Thumbs Up/Down
    Received: 7/0
    Given: 10/0
    Rep Power
    6
    Update
    It seems that the cause of the hum is heater wires. I got up heater wire from V2 with a chopstick and hum has significantly reduced but not completely gone.
    What can I do to get better? Are they too close to signal wires? Can Heater elevation resolve?
Thread Information
Users Browsing this Thread
  1. 5F6A Volume Interaction?
    By robrob in forum Theory & Design
    Last Post: 04-09-2016, 11:57 PM
  2. 5F6A problem?
    By vinceg in forum Debugging Your Build
    Last Post: 01-21-2014, 04:34 PM
  3. 5F6A woes
    By asatbluesboy in forum Tweed Builders
    Last Post: 09-13-2012, 03:00 PM
  4. 5F6A ?
    By chuckb in forum Tweed Builders
    Last Post: 02-17-2010, 09:45 PM
  5. 5F6A popping
    By jpbondo in forum Maintenance, Troubleshooting & Repair
    Last Post: 01-08-2007, 08:02 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
