Page 1 of 6 123456 LastLast
Results 1 to 35 of 203
Thread: 5F6A low volume
    Dec 2013
    Sicily-Italy
    105
    Received: 7/0
    Given: 10/0
    7
    5F6A low volume
    Hi, I re-wiring my own 5F6A clone and now it has a very low volume. What could cause the problem?
    1 Not allowed! Not allowed!
    Sep 2011
    Pace, FL
    3,233
    Received: 1,121/102
    Given: 152/36
    12
    Quote Originally Posted by vinceg View Post
    Pictures and the schematic you used would be appreciated.
    nosaj
    2 Not allowed! Not allowed!
    Dec 2013
    Sicily-Italy
    105
    Received: 7/0
    Given: 10/0
    7
    You are right, sorry.
ID:	51446   Click image for larger version.
ID:	51447   Click image for larger version.
ID:	51448   Click image for larger version.
ID:	51449   Click image for larger version.
ID:	51450   Click image for larger version.
ID:	51451   Click image for larger version.
ID:	51453   Click image for larger version.
    Dec 2013
    Sicily-Italy
    105
    Received: 7/0
    Given: 10/0
    7
    I used Ceriatone and Robinette layout for mods
ID:	51455   Click image for larger version.
ID:	51456   Click image for larger version.
ID:	51457   Click image for larger version.
ID:	51458   Click image for larger version.
ID:	51459   Click image for larger version.
ID:	51460   Click image for larger version.
ID:	51462   Click image for larger version.
    Supporting Member
    Mar 2018
    Germany
    2,349
    Received: 1,789/1
    Given: 1,024/2
    5
    Not sure, but picture 9 might show a diode shorted by a cap's lead.
    - Own Opinions Only -
    Dec 2013
    Sicily-Italy
    105
    Received: 7/0
    Given: 10/0
    7
    Possible. Thank you for the tip. One thing to watch tomorrow with the light of day. Italy is now evening.
    This could be the cause?
    Sep 2011
    Pace, FL
    3,233
    Received: 1,121/102
    Given: 152/36
    12
    Also since you used Dale resistors, we can't tell what the values are. Sometimes a wrong resistor value in certain position can choke the volume. It will be up to you to verify each one against the schematic or layout.
    nosaj
    Dec 2013
    Sicily-Italy
    105
    Received: 7/0
    Given: 10/0
    7
    Quote Originally Posted by nosaj View Post
    nosaj
    I will also control the values of the resistors. Although I doubt they are wrong. Unless Mouser did not make a mistake.
    Anyway, it seems strange to me that the amp does not have a back hiss. I noticed that without guitar plug in there is not classical valve hiss, even raising volume control. Could it be a problem in V1 preamp section?
    Sep 2011
    Pace, FL
    3,233
    Received: 1,121/102
    Given: 152/36
    12
    Anywhere in the signal chain can choke the signal, whether it is in the preamp or the poweeramp.
    See this on page 47 the click test. http://theguitar-blog.com/wp-content...r-Handbook.pdf
    nosaj
    Supporting Member
    Mar 2018
    Germany
    2,349
    Received: 1,789/1
    Given: 1,024/2
    5
    Same over here in Germany.
    In winter time most of the day(s) I depend on electric lighting.
    Old Timer J M Fahey's Avatar
    Oct 2007
    Buenos Aires, Argentina
    11,753
    Received: 1,884/23
    Given: 1,463/35
    27
    Just curious, did it work properly before the Mods?
    Personally I have found that by far the best Mod, the one which brings smiles to users, is to rip all of them off and return amp to original circuit, go figure.
    Not kidding: amps become Classics for a reason: they provide better sound than others since forever, and peak sound and performance was reached after extensive , ear tested modding ... 50 years ago.
    Once at the peak of the mountain, all paths lead downwards
  12. #12
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    32,148
    Received: 1,887/7
    55
    If an amp was working, then you do something to it, and it no longer works right, it is a safe bet the work you did was the cause. SO look especially at every part you changed, every joint you soldered.
  13. #13
    Dec 2013
    Sicily-Italy
    105
    Received: 7/0
    Given: 10/0
    7
    Yes, it worked well. I just decided to change the resistors and capacitors and improve the wiring. The mods concern only the bias circuit.
    However, this night I had a flash of inspiration: I forgot to solder the feedback resistor at the output. I can not wait to run into the lab to see if this is the cause of the problem.
  14. #14
    Dec 2013
    Sicily-Italy
    105
    Received: 7/0
    Given: 10/0
    7
    Update
    I realized I forgot to solder feedback resistor to out. Unfortunately I do not think was the problem. Now the amp has right volume but sometimes it disappears. It also seems to produce some sort of oscillation when I increase the volume control and it has background noise.
    these are the values I have read:
    Power transformer has 325+325 V AC than it is correct. At B+ there is 411V DC.
    V5 (6L6)
    pin3 400
    pin4 413
    pin5 -40
    pin6 404
    V4 (6L6)
    pin3 400
    pin4 400
    pin5 -40
    pin6 407
    V3 (12ax7)
    pin1 233
    pin3 41
    pin6 236
    pin8 41.5
    V2 (12ax7)
    pin1 170
    pin3 1.1
    pin6 310
    pin8 167
    V1 (12ay7)
    pin1 152
    pin3 2.3
    pin6 153
    pin8 2.3
  15. #15
    Nov 2013
    305
    Received: 118/11
    Given: 39/0
    7
    feedback resistor just lowers the overall gain,assuming it is the right value and the phase is correct,hence negative.Resistor and cap change has a slight effect,for good or worse,only if your building technique is the best possible required,from what i see it's not,sorry,most probably you have some bad soldering or miswire,although voltages are looking fine,which is a good thing.
  16. #16
    Dec 2013
    Sicily-Italy
    105
    Received: 7/0
    Given: 10/0
    7
    Quote Originally Posted by alexradium View Post
    I checked all the way but I not able to find the cause of the problem. About feedback resistor, before I had 27K with 16Ohm output. Leave it or change with 75K?
  17. #17
    Nov 2013
    305
    Received: 118/11
    Given: 39/0
    7
    27k is the original referred to a 2 ohm output,no wonder it oscillates at 16 ohms,try 75k at 8 ohm it should be ok
  18. #18
    Dec 2013
    Sicily-Italy
    105
    Received: 7/0
    Given: 10/0
    7
    I have two 8 Ohm Jensen speakers connected in series, so I have to use the 16 Ohm output, right?
  19. #19
    Nov 2013
    305
    Received: 118/11
    Given: 39/0
    7
    you can use whatever output you want for the feedback,just use the correct value
  20. #20
    Bent Member Chuck H's Avatar
    May 2007
    pacific north west
    15,441
    Received: 2,418/4
    Given: 2,801/0
    30
    Update
    Enzo said:
    The volume disappearing could be a consequence of an intermittent fault or short. It could be a crossed component lead like Helmholtz spotted, a bad solder joint or a host of other things. Since the amp worked before the problem is almost certainly a result of the work you performed. You say that the work was ONLY done on the bias supply. But you "forgot to solder feedback resistor". The feedback resistor is not part of the bias supply. So you must have done work on circuits other than the bias supply. Like Enzo said, check everything you worked on.
    JM2C but if you ran the amp with a 27k resistor from the 16 ohm tap before the work then leave it that way for now. Once the amp is working correctly you might consider changing some things, but you should get it back to working like it was first.
  21. #21
    Dec 2013
    Sicily-Italy
    105
    Received: 7/0
    Given: 10/0
    7
    Sorry but I do not understand. Before re-wiring I had a 27K feedback resistor, two 8 Ohm speakers in series but I do not remember which OT output I used and the amp worked well, it did not oscillate. Now, I leave everything as before or I put the 75K resistor that corresponds according to a 16 Ohm output?
  22. #22
    May 2007
    pacific north west
    15,441
    Received: 2,418/4
    Given: 2,801/0
    30
    If you had the output transformer or phase inverter leads lifted and there is any possibility that you reconnected them differently then this may cause the amp to oscillate with the feedback resistor reconnected.
    As was mentioned before... The problem is almost surely a mistake in your work. Narrow your search to the work you performed.
  23. #23
    Dec 2013
    Sicily-Italy
    105
    Received: 7/0
    Given: 10/0
    7
    Thank's Chuck, the problem is that I do not know what checked
  24. #24
    Dec 2013
    Sicily-Italy
    105
    Received: 7/0
    Given: 10/0
    7
    Yes, I agree. Unfortunately I re wired the entire circuit and mod the bias circuit. So, I would need a starting point. I have already checked all the connection with tester, the value tension at the pin seems right... I do not know what to do
  25. #25
    Dec 2013
    Sicily-Italy
    105
    Received: 7/0
    Given: 10/0
    7
    Checking heater voltage I discovered that it is 5,20V. Could it be the cause of the problem?
  26. #26
    Aug 2012
    Great Black Swamp
    2,255
    Received: 439/0
    Given: 1,175/1
    11
    That is definitely a problem. Heater voltage less than 90% of 6.3vac will cause issues.
    I'd suspect the heater voltage is a symptom rather than a cause, though, based simply on the thread discussions so far.
  27. #27
    Dec 2013
    Sicily-Italy
    105
    Received: 7/0
    Given: 10/0
    7
    Why a symptom? The voltage of the heaters depends only on the power transformer. Maybe you mean that I also have a problem with the transformer as well as the circuit?
  28. #28
    Dec 2013
    Sicily-Italy
    105
    Received: 7/0
    Given: 10/0
    7
    One thing I forgot to say before. When I checked the voltages at the plates, in the V5 (6L6) the tester did not read the voltage immediately. In the tester's display I saw the value go up to about 400V and at the same time I heard a whistle that stopped when the tester finished the measurement. While in the V4 (6L6) the reading of about 400V was instantaneous and silent.
  29. #29
    Sep 2011
    Pace, FL
    3,233
    Received: 1,121/102
    Given: 152/36
    12
    A symptom because something may be pulling it down. Remove all tubes and check filament voltage at each socket. Should be seeing around 6.7VAC unloaded give or take.
    nosaj
  30. #30
    Aug 2012
    Great Black Swamp
    2,255
    Received: 439/0
    Given: 1,175/1
    11
    that ^^^
    Plus, what else may be accidentally shorted to the PT windings? A wire whisker, or blob of solder, and now two circuits have become one - to the detriment of both. If a lot of the build was redone during your mods, then a lot of the build needs to be checked and debugged. I know my heart sinks when I contemplate tearing a bunch of stuff out just to start again, but patience and focus is really the foundation of any troubleshooting.
  31. #31
    Site Janitor tboy's Avatar
    Behind The Zion Curtain
    648
    Blog Entries
    1
    Received: 348/2
    Given: 260/4
    15
    I realized I forgot to solder feedback resistor to out... ...Now the amp has right volume but sometimes it disappears. It also seems to produce some sort of oscillation when I increase the volume control and it has background noise.
    Are you sure you have the correct polarity for the feedback? Having positive feedback where it should be negative could cause those symptoms.
    -tb
  32. #32
    Dec 2013
    Sicily-Italy
    105
    Received: 7/0
    Given: 10/0
    7
    Update
    I checked the heaters voltage at the output of the transformer with socket heaters wires disconnect and it is 6.25V. Right. Then, I extract all tubes and I measured the heater voltage on each socket and it is 6.10V. Then, I measured heater voltage with all tubes in and it is 5.7 -5.9 V. Doing tests, extracting preamp tubes I understood that with only the power tubes in the heater voltage is about 5.7 V. Is it right or there is a problem?
    About the low volume, I built a Audio probe and I injected a 1KHz signal at amp input. Then I checked with probe at V1 preamp out and there was a signal. Then I checked at V2 pin 8 and I heard a very strong pop and I was scared and I left. So I bet the probe at pin 3 of the power tubes and I heard an amplified noise but not the signal. I need your help to use the probe in the correct way and find the cause of the low volume.
    Update
    I think I think I found the point where the signal is interrupted. At V2 pin 1 there is signal but at pin 6 and pin 8 there is not signal. Why? I try swapped the tubes V2 and V3 but there is no change. I also checked with smartphone camera for unwanted contacts and also with tester but it solder seems right.
  33. #33
    May 2007
    pacific north west
    15,441
    Received: 2,418/4
    Given: 2,801/0
    30
    Are you using a light bulb current limiter or Variac type adjustable transformer during this testing?
  34. #34
    Dec 2013
    Sicily-Italy
    105
    Received: 7/0
    Given: 10/0
    7
    No. Did I make any trouble?
  35. #35
    May 2007
    pacific north west
    15,441
    Received: 2,418/4
    Given: 2,801/0
    30
    No. I'm trying to figure out why your filament voltage is low. It is already below 6.3V with that transformer winding unloaded. This is a problem. It would be typical to see that unloaded voltage be higher than 6.3V to compensate for loading with tubes installed. Do you know your power transformer brand and model number?
  1. 5F6A Volume Interaction?
    By robrob in forum Theory & Design
    Last Post: 04-09-2016, 11:57 PM
  2. 5F6A problem?
    By vinceg in forum Debugging Your Build
    Last Post: 01-21-2014, 04:34 PM
  3. 5F6A woes
    By asatbluesboy in forum Tweed Builders
    Last Post: 09-13-2012, 03:00 PM
  4. 5F6A ?
    By chuckb in forum Tweed Builders
    Last Post: 02-17-2010, 09:45 PM
  5. 5F6A popping
    By jpbondo in forum Maintenance, Troubleshooting & Repair
    Last Post: 01-08-2007, 08:02 AM
