Results 1 to 14 of 14
Thread: Clip: DIY JCM800 Atomica/Jose
    May 2017
    85
    Received: 8/0
    3
    Finished this build recently. Ceriatone chassis/turret board, but changed most of the circuit into an "Atomica" style Jose mod. But maybe a little more aggressive/modern.
    In place of the trimmer on the back, I have a 6-position rotary for different clipping options. Though I find myself using 2N5401s most of the time.
    4 Not allowed! Not allowed!
    Junior Member
    Dec 2015
    13
    Received: 1/0
    Given: 4/0
    0
    Do you have a schematic for this?
    Old Timer olddawg's Avatar
    Dec 2007
    La Jolla CA, Hanalei, Kauai
    2,954
    Received: 266/0
    Given: 30/1
    14
    A very clean build...
    May 2017
    85
    Received: 8/0
    3
    Quote Originally Posted by Chasin' Note View Post
    Typical Jose. Start with a JCM800 type of circuit with dual gains and a pre-tone stack master volume.
    Cathodes are 2K7/.68, 2K7/.68, 820R/.68
    First stage plate is 320K total. In this case 100K and 220K in series with a 330pF bypass.
    First coupler is 0.022uF, second stage is 0.0022uF
    4700pF bright cap on Gain 2.
    68K/68K voltage divider on Gain 1 (68K from wiper to ground and 68K input grid on V1b)
    Typical Jose mod with whatever zeners or transistors you like
    Depth mod with whatever value cap you like
    Everything else stock JCM800
    And just go from there if you want to tweak something.
    Old Timer J M Fahey's Avatar
    Oct 2007
    Buenos Aires, Argentina
    11,587
    Received: 1,743/18
    Given: 1,341/29
    26
    Typical Jose means nothing to us.
    ... whatever zeners or transistors you like
    ... whatever value cap you like
    Would you care to share an actual schematic?
    Thanks.
    May 2017
    85
    Received: 8/0
    3
    Junior Member
    Dec 2015
    13
    Received: 1/0
    Given: 4/0
    0
    Thanks bro
    Oct 2007
    11,587
    Received: 1,743/18
    Given: 1,341/29
    26
    NOW we know what are you talking about, .
    So basically cold cathode stage removal and added clipping diodes , so end result is way less second
    harmonic and a lot more third ... a woodier sound comopared to original reedier one,which is the core of JCM800 sound.
    Total gain not much changed because what´s increased by bypassing (and rebiasing) cold cathode and increasing V1 plate load is lost by heavily loading first stage with a 68k resistor.
    Rest of circuit looks roughly standard.
    May 2017
    85
    Received: 8/0
    3
    The entire circuit is pretty standard. That's why I said "typical Jose." This thing is 40 years old by now.
    Feb 2010
    47
    Received: 19/0
    Given: 1/0
    0
    I don't understand how this clipper works. I mean the BE-junctions of the 2N5401s.
    Anyone cares to clarify ?
    Thanks.
    Dec 2009
    Devon, UK
    3,491
    Received: 692/1
    Given: 570/1
    13
    Quote Originally Posted by strato56 View Post
    Thanks.
    They behave like back to back zener diodes. It's a guess at to what the zener voltage might be as it's not specified in the datasheet other than >5V.
  12. #12
    Feb 2010
    47
    Received: 19/0
    Given: 1/0
    0
    Thanks ! I thought 5V was the breakdown voltage.
  13. #13
    May 2017
    85
    Received: 8/0
    3
    Yeah, just using transistors for their internal zener-like behavior. They do sound different than using zeners of the same/similar voltage. The MPSA06 sound like 12v zeners and the 2N5401 clip a little more. Maybe like 9v-10v. But the character/feel is a little different than a zener. I have a rotary switch in this amp with a bunch of clipping options on it from 20v zeners, 18v, 16v, 12v, 9v, and a few transistor options. Not in the schematic, but you can see it in the photo.
  14. #14
    Feb 2010
    47
    Received: 19/0
    Given: 1/0
    0
    Thanks for clearing that up !
  1. Do I need a pre-amp with a clip-on mic?
    By nicholaspaul in forum Music Electronics
    Last Post: 05-28-2013, 10:35 AM
  2. Jose Marshall
    By Valvehead in forum Theory & Design
    Last Post: 12-31-2009, 05:29 AM
  3. definition of clip
    By rabies in forum Guitar Amps
    Last Post: 01-25-2009, 04:06 PM
  4. 5D3 Clip
    By s2amps in forum Tweed Builders
    Last Post: 07-21-2006, 08:15 PM
