H&K Bass Amp: Xenon T10 Lightbulb to T10 LED Conversion
  • H&K Bass Amp: Xenon T10 Lightbulb to T10 LED Conversion
    Hey guys, I hope my question will make sense -- as I'm an absolute rookie when it comes to 'electronics'... hence my cry-for-help to you folks.
    So... I recently purchased an early 90's Hughes & Kettner BassBase 400 bass amp. The control panel reminds me of an old Sansui or Marantz tuner from the 70's... cool looking blue display...
    The H&K BB600 service doc. states that the replacement bulbs are xenon 12V/ 5W/ T10-WB light bulbs; however, after doing a little googling, I learned that there are maybe twenty gazillion variants of the T10 bulbs, mostly automotive - which is just great, since I loved being confused.
    Okay, my questions: (based on being side-tracked whilst googling), can I substitute the xenon T10's with those T10 LED's?
    I understand that I'll need to keep the 12V - 5W units the same - but since I'm trying to go from a light bulb to an LED, would I need to do any modifications to the amp, or are these LED replacements simply plug and play?
    Hope I make sense[?]
    Thanks in advance!
    If the original lamp is 12v and you substitute a 12v Led unit, there should be no problems.
      Thanks El Duderino!
      I know it’s a simple thing - but I’d rather ask questions than to prod and poke into things I’m unsure of.
      Really appreciate the response.
        The Dude, thanks a lot! Been wondering this question for some time now
          First check sockets for voltage and polarity.
          Incandescent/Filament lamps , such as "Xenon" ones, are AC/DC and polarity insensitive, LEDS are not so by any means.
          So:
          * You might have 12VAC feeding those sockets; in that case incandescent will work, LEDs will most probably be damaged.
          * You might have 12V DC wrong polarity, again incandescent will work; LED will not and also may be damaged.
          * you might have 12VDC proper polarity, in which case all will be fine.
          Personally, I would grab a set of same size and specs old style incandescent lamps and use them.
          By the way, if they were good enough for H&K .....
          EDIT: just checked T10 12V LED lamp, all sockets are polarized, and show different coloured wires.
            From what I can guess of the bassbase600, there are 5 lamps in series running off an AC winding.
              And, someone who did it recently:
              http://handkusers.forumotion.com/t61...00-information
