Page 2 of 2 FirstFirst 12
Results 36 to 45 of 45
Thread: Double neck Tele body?
  1. #36
    Supporting Member dmartn149's Avatar
    Aug 2009
    Near Nashville
    797
    Received: 176/1
    Given: 218/1
    11
    If you are going to buy new tuners, I'd like to recommend the locking, graduated type. I got the cheap ones from Guitar Fetish, and they work great.
    Vote like your future depends on it.
  2. #37
    Old Timer olddawg's Avatar
    Dec 2007
    La Jolla CA, Kapaa Kauai
    3,312
    Received: 478/6
    Given: 56/1
    16
    So the Mighty M neck is nice except for one thing... there's a tiny knot hole in the headstock! Click image for larger version.
ID:	52299 Not a HUGE deal, I've seen it on MIAs. Probably won't show when the decal is on.
    It dropped right in. I used the 22 fret neck so the "ledge" will cover square cut in the pickguard. I think once it's together with another neck it will be a very nice replica. Just a matter of what pickups and bridges to use now... and a total re-wire of course.Click image for larger version.
ID:	52300Click image for larger version.
ID:	52301Click image for larger version.
ID:	52302Click image for larger version.
    3 Not allowed! Not allowed!
  3. #38
    Dec 2007
    3,312
    Received: 478/6
    Given: 56/1
    16
    Iíve never used ďLockingĒ tuners. I learned to ďlockĒ my strings decades ago. It amazes me how many players simply donít know how to put on strings... even ones that have been gigging for years. Even guitar shops. Iím sure theyíre worth checking out just for convenience at that price point... but Iíll probably just use what I have for now, they seem fine. Iíve never seen tuner be an issue unless they are broken.
  4. #39
    Aug 2009
    Near Nashville
    797
    Received: 176/1
    Given: 218/1
    11
    Quote Originally Posted by olddawg View Post
    I’ve never used “Locking” tuners. I learned to “lock” my strings decades ago. It amazes me how many players simply don’t know how to put on strings... even ones that have been gigging for years. Even guitar shops. I’m sure they’re worth checking out just for convenience at that price point... but I’ll probably just use what I have for now, they seem fine. I’ve never seen tuner be an issue unless they are broken.
    I wouldn't use them with a fixed bridge, but I like them with a trem, also with the graduated posts, you can skip the string tree.
  5. #40
    Jan 2014
    Chicago
    123
    Received: 52/2
    Given: 91/2
    7
    I know one-or-three methods of anchoring strings dawg, do you care to share which particular method you're referring to? I've never taken to lockers either, and my Strat has thankfully been pretty stable.
  6. #41
    Dec 2007
    3,312
    Received: 478/6
    Given: 56/1
    16
    I start by turning the post so the hole in the post runs parallel to the neck. I insert the string from the nut side and leave enough slack for 3 - 4 turns with 3.5 optimum. I make a hard bend of the remaining string and pull it tightly around the post under the nut end of the string and the pull tightly straight up. Then I start winding. The wind will lock the string in place with the winds going towards the bottom of the post. When you are done and you cut off the excess string, the nubs should stick straight up. Next, stretch the new set in. I also use pencil lead everywhere the string touches (like the nut slots and the bridge) and put Vaseline (I used to use light oil) on the string trees. Iím a real bender and this method has always worked for me.
    1 Not allowed! Not allowed!
  7. #42
    Dec 2007
    3,312
    Received: 478/6
    Given: 56/1
    16
ID:	52495Click image for larger version.
ID:	52496 DONE! At least for now. The missing bridge was $11. I used the small tuners from the 12 string on one neck and bought a matching $14 set for the other neck. The necks were Mighty Mite that StewMac gave me a $30 discount on each with them on sale. So $130 apiece. They dropped right in and set up really well. I didnít have to touch the intonation! These necks are great for the price imho. I was able to fix the one damaged neck pickup. All the electronics work.. no buzzes even with reasonable gain. The top neck has a 3 position switch. The bottom neck has a 5 position. The ďneck selectĒ switch is in the horn. It was factory wired this way. One thing you have to be careful with with these Asian screws is torque. If you use these parts itís imperative that you have the correct drill bit and use soap. Iím really pleased with how it turned out. A bit heavy... but itís a double. I have a set of ďSpaghettiĒ Fender headstock decals on order for $10. It should turn some heads and plays and sounds every bit as good as most Teles Iíve played. Now... a case will probably cost more than I have into it!
    7 Not allowed! Not allowed!
  8. #43
    Bent Member Chuck H's Avatar
    May 2007
    pacific north west
    16,435
    Received: 3,071/5
    Given: 3,709/0
    32
    Bitchin! That actually all came together pretty fast as "projects" go.
  9. #44
    Dec 2007
    3,312
    Received: 478/6
    Given: 56/1
    16
    And incredibly inexpensive. Btw.. the necks are great. Iíve done very little adjustments after bolting them on. I think most of the Asian suppliers are using the same spec. Iím told by some people that the hardware is inferior... but I just donít see it. Even the cheap knockoff pickups sound good. I got lucky.
  10. #45
    Dec 2007
    3,312
    Received: 478/6
    Given: 56/1
    16
    2 Not allowed! Not allowed!
  1. Tele Neck on a Strat Body?
    By big_teee in forum Guitar Tech
    Last Post: 07-27-2017, 10:37 PM
  2. Fender neck on Squier body issue.
    By Sea Chief in forum Guitar Tech
    Last Post: 12-17-2015, 08:47 AM
  3. Gap between neck and body / pickguard
    By pforsell in forum Guitar Tech
    Last Post: 09-27-2011, 07:11 PM
  4. Neck-Through-Body Pickup Recess Holes
    By bbsailor in forum Guitar Tech
    Last Post: 04-16-2010, 08:47 PM
