Results 1 to 6 of 6
Thread: Digitech Drop Original Note Problem
    Nov 2018
    29
    Received: 2/0
    0
    I have a Digitech Drop Pedal where the pedal works, but every setting is allowing the original note to come through also. Anybody else have this issue before?
    Nov 2013
    234
    Received: 65/1
    Given: 15/1
    6
    a friend contacted me today for a problem with this pedal acting strange,it seems that is sensible to bad power supply,and needs a separate unit.Also no other pedal is allowed in front,so try with passive guitar through a cable direct in input,powered by a separate 500mA PS.
    Other than that i guess it is candidate for substitution.
    Nov 2018
    29
    Received: 2/0
    0
    Sad to say I've done all of the above.
    Feb 2010
    11,208
    Received: 1,168/21
    Given: 2,952/8
    22
    Isn't there a setting for 'drop + dry' ? Does that make it any worse, or is it possible that the pedal is stuck in that mode?
    Was it working correctly before?
    Nov 2018
    29
    Received: 2/0
    0
    The drop+dry works fine as it's an octave down with the dry signal...it's allowing that dry signal on every other setting that's the problem.
    Aug 2012
    Great Black Swamp
    2,129
    Received: 332/0
    Given: 822/1
    9
    Does it sound any different when drop + dry is selected compared to drop only?
    1 Not allowed! Not allowed!
  1. Digitech Whammy IV Problem
    By stevenrb718 in forum Guitar Effects
    Last Post: 02-04-2019, 08:21 PM
  2. Same Prosonic, Different Problem - ocillation/scratching noise on loud low note decay
    By Jecarroll7 in forum Maintenance, Troubleshooting & Repair
    Last Post: 02-26-2012, 02:57 AM
Tags for this Thread
