Results 1 to 15 of 15
Thread: Use of Ceramic Caps in Gibson Custom Shop Guitars...
  1. #1
    Join Date
    Apr 2011
    Posts
    232
    Thumbs Up/Down
    Received: 11/0
    Given: 19/0
    Rep Power
    9
    I'm having an argument with someone and they are trying to tell me that the custom shop does not use ceramic caps in their guitars. I say they do. The 61 SG RI have ceramics and even the really expensive Custom Shop Firebirds are wired up with ceramic capacitors. Can anyone here confirm this? Can anyone please post some pictures of said ceramics in the control cavity. I've been trying to google the images but no luck. Thanks.
    PS: also, can anyone confirm the use of black shrink wrap in the control cavities as shown in the photo below? Also, can anyone here confirm the authenticity for a Custom S61 RI SG Custom. Thank You
    http://josephsantos.com/wp-content/u...2/IMG_0668.png
    0 Not allowed! Not allowed!
  2. #2
    Senior Member nevetslab's Avatar
    Join Date
    Apr 2010
    Location
    Burbank, CA
    Posts
    1,511
    Thumbs Up/Down
    Received: 489/1
    Given: 1,177/1
    Rep Power
    11
    Quote Originally Posted by cluster View Post
    Those are definitely ceramic caps. I can't tell you WHAT type of ceramic dielectric they are from the photo. They don't look like NPO, may be X7R. I don't think I have a parts list on any of Gibson's guitars/basses to know much further, though no doubt others here would know.
  3. #3
    Old Timer olddawg's Avatar
    Join Date
    Dec 2007
    Location
    La Jolla CA, Hanalei, Kauai
    Posts
    2,862
    Thumbs Up/Down
    Received: 204/0
    Given: 22/0
    Rep Power
    14
    I have never understood the tone control capacitor mojo thing. I’ve owned vintage guitars with the real deal. I’ve installed Asian caps from Radio Shack in others back in the day. They all seem to do the same thing to me.... roll off some treble. What mattered was the value.
    6 Not allowed! Not allowed!
  4. #4
    Join Date
    Jan 2016
    Location
    USA
    Posts
    114
    Thumbs Up/Down
    Received: 101/6
    Given: 153/6
    Rep Power
    4
    Seems to me that cluster just wants to know if anyone has supporting evidence that Gibson does ship guitars with the ceramic caps installed and not trying to debate the merits of other type caps over ceramics for the guitar tone control. In fact cluster could be on your side with the past debates on the subject.
    The picture in post #1 looks like it could be that of a stock Gibson wiring job.
    By the way - That's black tubing / spaghetti not heat shrink IMO.
    2 Not allowed! Not allowed!
  5. #5
    Old Timer J M Fahey's Avatar
    Join Date
    Oct 2007
    Location
    Buenos Aires, Argentina
    Posts
    11,211
    Thumbs Up/Down
    Received: 1,393/18
    Given: 1,057/27
    Rep Power
    26
    1) not worth having an argument over.
    Why would you care what "they" think?
    2) as said above, those are definitely ceramics and by the way what´s proper to use there, given their marginal job, and nil influence of tone, besides measured value that is.
    Voltage across them is so low, a few millivolts at best, that *anything* can do a decent job there.
    3 Not allowed! Not allowed!
  6. #6
    Join Date
    Aug 2015
    Location
    Edmonton, AB
    Posts
    222
    Thumbs Up/Down
    Received: 195/3
    Given: 101/3
    Rep Power
    4
    Quote Originally Posted by J M Fahey View Post
    Sure, you could probably get away with some gum wrapper foil,
    rolled up with a couple wires soldered on....
    1 Not allowed! Not allowed!
    The world is full of people that are right.
  7. #7
    Supporting Member The Dude's Avatar
    Join Date
    May 2010
    Location
    Sioux Falls, SD
    Posts
    5,865
    Thumbs Up/Down
    Received: 848/1
    Given: 690/1
    Rep Power
    15
    Surely not for everyone, but the first thing I do when I get a new guitar is disconnect the tone control. So, I've not a care in the world about what cap is in there. That said, IMO, and has others have said, a uF is a uF.
    “Yeah, well, you know, that’s just, like, your opinion, man.”
  8. #8
    Join Date
    Dec 2007
    Location
    Posts
    2,862
    Thumbs Up/Down
    Received: 204/0
    Given: 22/0
    Rep Power
    14
    Quote Originally Posted by The Dude View Post
    That's what we did when I was a kid 40 years ago... to get every last bit of output that pickup had straight into that kranked amp!
  9. #9
    Join Date
    May 2010
    Location
    Sioux Falls, SD
    Posts
    5,865
    Thumbs Up/Down
    Received: 848/1
    Given: 690/1
    Rep Power
    15
    I guess I'm still a kid. Less treble is what the neck pickup is for. I don't need no stinkin' tone knob.
    Want less gain? Turn the volume down, which also gets you a little less treble.
  10. #10
    Lifetime Member Enzo's Avatar
    Join Date
    May 2006
    Location
    Lansing, Michigan, USA
    Posts
    31,538
    Thumbs Up/Down
    Received: 1,428/7
    Given: 0/0
    Rep Power
    54
    We don't see it in guitars and amps, but there is something called a "gimmick capacitor", and it showed up in high frequency stuff and even TV sets. You make one with a short piece of zip cord or maybe two short pieces of insulated wire twisted together. Strip one end, and solder the two wires to the two points you want a cap between. The two wires next to each other form a small cap. Might be half a picofarad, or 1 or 2 picofarads. But that is often all it takes to stabilize a circuit. Amateur radio guys used them a lot, mainly useful in RF.
    When I was a kid, I made a Tesla Coil. It used carbon arc points as a rectifier, and to filter that supply at the extremely high voltages, we needed a cap. 500pf or so was plenty, but we needed it. Well 500pf 10,000v or higher caps were not common, so we made them. Put a pane of window glass in a wooden frame, glue a sheet of foil to either side of it, and connect wires to the foils, TA DA, a super high voltage cap.
    You really can make caps out of almost anything.
    In fact I was working in some Mesa amp once and discovered a small piece of bare wire soldered to some point, and sticking up from the board about an inch. I thought some tech was sloppy and snipped it off. Instantly the hum increased. Turns out it was supposed to be there. There was the existing hum, and they found that a short antenna - the wire - at that point in the circuit picked up the exact amount of hum, and out of phase with the audible hum. The hums cancel. Cheating? MAybe, but it solved their problem. I put a new piece of wire in place, bent it to the best angle for hum abatement, and waddaya know, hum was gone. That is kinda half a cap made out of a wire.
    Got a cap meter? Cut off a couple six inch pieces, and strip one end of each, connect to your cap meter. Set the wires apart and check the meter reading as your minimum. Now start twisting the wires together and watch the capacitance climb.
    5 Not allowed! Not allowed!
  11. #11
    Bent Member Chuck H's Avatar
    Join Date
    May 2007
    Location
    pacific north west
    Posts
    14,680
    Thumbs Up/Down
    Received: 1,715/4
    Given: 1,891/0
    Rep Power
    29
    Indeed! I've made caps here at home for the fun of it. I've tried a few different materials and techniques. Novel at best. I've never used any of them in a project like a sheet of glass with foil on either side for a Tesla coil (COOL!!!). Considering you were a kid when that project happened I sure wish Steve Conner was still here to read that. He would smile for sure. Nothing new under the sun (as they say).
    "Never bet your life on somebody else doing their job." SoulFetish's good friend
    "Being born on third base and thinking that you must have hit a triple is pure delusion!" Steve A
    "Back to the amp. It makes horrible sounds when I play my guitar thru it... because I suck at playing guitar." Mike6158
  12. #12
    Join Date
    Apr 2011
    Posts
    232
    Thumbs Up/Down
    Received: 11/0
    Given: 19/0
    Rep Power
    9
    so I finally found a picture of another Custom Shop SG on line and sure enough they use ceramic caps. maybe because they were period correct. Also, is that rubber insulation tubbing or shrink tubing I see there? Is that period correct?
Name:	12sg cavity comparision.jpg
Name:	10 phc5l3iso1qy3huoh0jj.jpg
  13. #13
    Join Date
    Jan 2014
    Posts
    83
    Thumbs Up/Down
    Received: 22/2
    Given: 30/0
    Rep Power
    6
    That would be common protective/insulative sheathing, made of something like PVC, used in all manner of modern appliances and non-shrinkable. As to whether it's period-correct, I doubt it. More likely a braided fiber sheath would have been used, if at all. A more experienced individual may chime in however.
  14. #14
    Join Date
    Mar 2018
    Location
    Germany
    Posts
    1,380
    Thumbs Up/Down
    Received: 978/1
    Given: 643/2
    Rep Power
    4
    Not sure about SGs. But in LPs the Gibson Custom Shop used ceramics in the earlier years and fake bumble-bees (polyester) in later years.
    My original '64 SG has ceramic.
  15. #15
    Old Timer
    Join Date
    Feb 2010
    Location
    Just south of Bawlmer, Merlin
    Posts
    2,655
    Thumbs Up/Down
    Received: 351/6
    Given: 342/1
    Rep Power
    12
    Quote Originally Posted by minim View Post
    I don't know if it was used in guitars, but insulating "spaghetti" was available in the '60s. My dad had a ton of it in his workshop.
    DON'T FEED THE TROLLS!
Thread Information
Users Browsing this Thread
  1. Vintage Custom Guitars
    By John_H in forum Guitar Tech
    Last Post: 04-28-2014, 04:25 AM
  2. [apg] pickups custom shop
    By apguitars in forum Pickup Makers Showcase
    Last Post: 10-29-2013, 09:56 AM
  3. Replies: 0
    Last Post: 03-05-2009, 06:47 AM
  4. custom building guitars. need help
    By rubymaster92 in forum Guitar Tech
    Last Post: 10-02-2008, 07:27 PM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
