Results 1 to 4 of 4
Thread: Outboard guitar controls for testing?
    Nov 2007
    Kansas City, MO USA
    129
    Given: 3/0
    13
    I have a couple guitars for testing pickups. I like the ability to swap pickups with just a screwdriver and I don't have to even slack the strings. OTOH I am frustrated with the limitation of my hard-wired volume and tone controls. E.g. now it is set up with 500k pots and I-can't-remember-what capacitor, and I want to test strat pickups with other values. So I will have to rewire the guitar again, which kinda defeats the purpose.
    I thought of making swappable pickguards with a quick connect.
    Then I thought of the following idea, which is basically an outboard box to live-audition pot and cap values.
    As I imagine it, this outboard box should sound the same as the controls in the guitar. Will this work the way I expect?
Name:	outboard box volume tone guitar.JPG
    Alternately, has anyone collected good ideas for guitars like these - a test platform for pickups?
    Old Timer Leo_Gnardo's Avatar
    Sep 2012
    Dogpatch-on-Hudson
    6,889
    Received: 1,785/21
    Given: 1,461/0
    14
    That is one king size excellent idea.
    FWIW I ran my guitar pickups straight-out in the late 70's. If my information is correct, so did another fellow who later on became a major gittar-pickin' sensation, Eddie van Halen. He practiced a lot more than I did.
    2 Not allowed! Not allowed!
    ToneOholic! big_teee's Avatar
    Jun 2010
    Mid-South USA
    11,820
    Received: 1,089/32
    Given: 1,039/14
    22
    We've discussed the test guitars in the past, and seems like we had pictures listed by members.
    Not sure where those threads are.
    I will try to find some.
    T
    "If Wishes Were Horses, Beggars Would Ride!" Scottish Proverb 1600s
    Supporting Member nevetslab's Avatar
    Apr 2010
    Burbank, CA
    2,106
    Received: 785/1
    Given: 1,910/1
    13
    Quote Originally Posted by Kindly Killer View Post
    I like the idea of a dedicated guitar-test platform, I'd guess a budget Strat-look-alike, tweaked to behave like a good one, but with the body cavities routed so you can quickly swap out pickups as you're doing/want to do with just a screwdriver. I'd set up the pickup wiring on suitable quality connectors so they can plug into your 'shielded control box', and also have your pots connectorized so they too can be swapped out or switched in. I'd be inclined to wire up machine pin sockets for allowing plugging in caps, which are wired to your rotary switches, all accessible from one panel. And, have that control box mounted to the body so you can still play without having a maze of wiring following you and falling over everything.
    In many of my breadboard constructions, I use in-line gold-plated sockets, 0.1" ctrs, come in break-away strips, and solder them into copper-clad perf board, allowing parts to be swapped out by plugging into the strips.
    The images below are for an API Console ProTools Monitor Panel I put together using this method....obviously more complex than your control box/cap selection box for the guitar test bed, but you'll get the idea.
ID:	51616 Click image for larger version.
ID:	51617 Click image for larger version.
ID:	51618 Click image for larger version.
ID:	51619Click image for larger version.
    The original panel with all rotary controls ended up changing to short-throw Penny & Giles faders, Mute & Solo switches & pan pots, but it's the mechanics of the idea I'm talking about for your swappable parts to support your guitar test bed.
    1 Not allowed! Not allowed!
  1. Square wave testing guitar amp OT
    By GainFreak in forum Theory & Design
    Last Post: 04-27-2018, 09:00 PM
  2. Testing Pickups In the Guitar--thoughts
    By jschweid in forum Beginner/ Hobbyist
    Last Post: 08-08-2014, 05:34 AM
  3. Super Reverb Volume Controls won't Silence the Guitar
    By AtomicMassUnit in forum Maintenance, Troubleshooting & Repair
    Last Post: 12-20-2013, 06:34 PM
  4. Pickup testing guitar
    By Jeff Callahan in forum Pickup Makers
    Last Post: 09-08-2009, 06:48 PM
  5. Multiple pans in an Outboard Reverb
    By BJosephs in forum Guitar Effects
    Last Post: 04-02-2008, 05:20 PM
