SVT-CL Output Tube Schematic and Layout Needed
  • SVT-CL Output Tube Schematic and Layout Needed
    Does anyone have an SVT-CL Output Tube Schematic and Layout? I have several sets of SVT-CL documents, including some from Ampeg (I think), but non have these documents. Without the missing documents, I cannot sort out which pins of J11 connect to which 6550 (without pulling the tube board out and checking for continuity). Not that I expect knowing to tell me anything ;-(
    I'm trying to solve the usual red light-no green light issue on one triplet. The amp powers up and puts out full power, but I want it right. I swapped tubes between sides to no avail, checked all the components on the output board, and made sure that the LED is good.
    I measured all of the voltages on ICs 3-6 and nothing looks amiss. All of the tube sense pins have between 162mV and 290mV. The voltages on the pins that feed the green LEDs match (within 200mV).
    Ampeg_SVT-CL.pdf
    This is what I have. No layout, but you should be able to trace it out.
      Ampeg SVT-CL Output Tube PCB photos/Technical Note, schematic, parts placement dwg
      While Ampeg never published a top/bottom PCB layout drawing like they had done on other boards, I do have this one Technical note that shows the PCB fairly clearly on the top side, though not all of the bottom side. I do service these regularly, and will add that to my agenda to get assembly photos for my database and post it.
      Technical Information Bulletin (TIB0003, June 2001) -- Power tube PCB modifications.pdf
      Tube PCB Schematics (41941h3_).pdf
      Tube PCB Pictorial and Parts List (41941p5_).pdf
        Thank you sir!
