Working on this Line 6 Low Down and traced the issue down to an overheating 3.3v regulator. This overheated reg. seems to be caused by the DSP chip overheating. I can cool the chip off and the 3.3v returns. Curious if any of you have ran into this and if it is a common issue? I really don't want to attempt to resolder this chip without a proper reflow station. I think I may just install a little fan to help keep it cool but not sure if it will completely solve the problem.
Line 6 Low Down LD 175 Hot DSP
Originally posted by Tymbler View PostThanks you! I'll try, but I also want to install a radiator on the chip. I have a matching size from the old motherboard. Do you think it's worth it?
Originally posted by Tymbler View Postand one more question, if I buy a new dsp does it require programming or not?Experience is something you get, just after you really needed it.
Are you referring to U14? I've seen those overheat before, they are not pre-programmed. It's a CODEC or Analog-Digital converter AK4528.
https://www.digikey.ca/product-detai...3-1-ND/3679887
Originally posted by dmeek View PostAre you referring to U14? I've seen those overheat before, they are not pre-programmed. It's a CODEC or Analog-Digital converter AK4528.
https://www.digikey.ca/product-detai...3-1-ND/3679887Experience is something you get, just after you really needed it.
