Results 1 to 6 of 6
Thread: JMP-1 encoder mod
    Feb 2007
    Iowa
    1,372
    Received: 9/0
    Given: 2/1
    14
    JMP-1 encoder mod
    Ive read in other forums about fixing the data wheel issue in the JMP-1 Marshall preamp. I just got one and the patches jump around when turning the control. I guess this is common in these units . They are adding a de-bouncing chip. No one mentions "how"
    here : https://www.mouser.com/ProductDetail/863-MC14490DWG
    https://www.mouser.com/ProductDetail...CW1J-C36-CC24L
    so the encoder is 3 pins and the chip is 16 pins.
    Has anyone done this mod? Is there a scem , or can someone tell me how to do this ??
    Senior Member Pedro Vecino's Avatar
    Jul 2006
    Spain
    583
    Received: 116/0
    Given: 59/0
    13
    When the encoder ages it tends to be unstable, making the adjustment difficult.
    When it is new, its precision is total.
    Sometimes I have cleaned them and they work better, but if the degradation due to use is excessive, it is enough to order a new one.
    Feb 2010
    11,194
    Received: 1,153/21
    Given: 2,919/8
    22
    "The circuit I used was just the standard circuit in the MC 14490 data sheet, and I attached the PCB to the back of the encoder with foam tape."
    http://www.marshallforum.com/threads.../#post-1167049
    Feb 2007
    Iowa
    1,372
    Received: 9/0
    Given: 2/1
    14
    i found some help--thanks though
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    31,525
    Received: 1,415/7
    54
    Debounce? It didn't need debouncing when the parts were new. Seems like a lot of extra effort to get around replacing a worn control.
    Feb 2010
    11,194
    Received: 1,153/21
    Given: 2,919/8
    22
    Apparently the datasheet for the encoder shows a recommended debounce circuit. Not sure if that means it is recommended to use one, or if it means if you are using one, here is the recommended version.
  1. Fender cyber twin replacement encoder problem
    By Klemay83 in forum Maintenance, Troubleshooting & Repair
    Last Post: 03-23-2018, 10:14 PM
  2. Digitech rotary encoder
    By Mick Bailey in forum Guitar Effects
    Last Post: 06-04-2015, 05:00 PM
  3. Marshall encoder
    By Valvehead in forum Maintenance, Troubleshooting & Repair
    Last Post: 11-29-2014, 03:19 AM
  4. 15 position rotary encoder?
    By ricach in forum Guitar Effects
    Last Post: 03-30-2011, 01:48 AM
  5. Digitech Whammy Rotary Encoder
    By EstynEstyn in forum Guitar Effects
    Last Post: 03-18-2011, 07:30 PM
