Not a joke, read it somewhere they banned transformer power supplies. Not efficient up to their standards. Now i am seeing 2008, so 10 years ago?
pedal power supply question about RG's article
Originally posted by mozz View PostNot a joke, read it somewhere they banned transformer power supplies. Not efficient up to their standards. Now i am seeing 2008, so 10 years ago?
nosajsoldering stuff that's broken, breaking stuff that works, Yeah!
For most people a One Spot works just fine. Just have a spare in your kit if you are paranoid. I’ve been using the same one several times a week for 6+ years with no issues. Most pedals have a very low current draw. I run a separate wall wort supply for my finicky EH C9 pedal. Used to have my wireless receiver on my board on a separate supply too but moved it to the top of my amp a while back.
Originally posted by mozz View PostNot a joke, read it somewhere they banned transformer power supplies. Not efficient up to their standards. Now i am seeing 2008, so 10 years ago?The only good solid state amp is a dead solid state amp. Unless it sounds really good, then its OK.
Originally posted by Chuck H View PostThe way I would approach it would be simpler.
1) What is the mA requirement of the highest current pedals on the market.
2) Multiply that figure by the number of outputs you plan to use.
3) Find a 12V transformer capable of 20% more current. (regulation will eat some current)
4) Regulate it to 8.6V/9V (8.6V seems to be what most 9V batteries actually put out)
Easy peazy lemon squeezey.The only good solid state amp is a dead solid state amp. Unless it sounds really good, then its OK.
Originally posted by Dave H View PostYou don't need a 400mA transformer. 400 mAH means the battery can (optimistically) supply 400mA for 1 hour before it's toast or 40mA for 10 hours or 4 mA for 100 hours etc. If you are using separate transformers each output only has to supply the current required by your highest current pedal.
Also, not exactly sure why we would need separate transformers, couldn't we use one, and use that to power several regulator boards?The only good solid state amp is a dead solid state amp. Unless it sounds really good, then its OK.
Isolated transformers means isolated (floating) grounds. If that's important.If it still won't get loud enough, it's probably broken. - Steve Conner
Originally posted by Leo_Gnardo View PostTrue, who would bother building a complex SMPS when you can buy one ready made for $20 or so. And when that a power supply costs $20 more or less, buy a spare! Those who build their own PSU's would be wise to stick to the cheap & reliable, low parts count, ol' fashioned standard supply.
I hope that's a joke, but - California - yikes!The only good solid state amp is a dead solid state amp. Unless it sounds really good, then its OK.
Originally posted by TomCarlos View PostI built a Jameco Dual Output Power Supply Kit. If you look on YouTube, you will see videos of the kit being built. Just get yourself a project box, drill some holes to mount you outputs and you're done. I am only using one side of the kit and it supplies ample power to my pedal board (7 pedals).The only good solid state amp is a dead solid state amp. Unless it sounds really good, then its OK.
Originally posted by doctor View PostHow long does the pedal work until the repair? 5 years, at best 10 years. And then it must be repaired. SPMS will work no less. MTBF for the SPMS usually is not less than 20,000 hours (2 years of continuous work without shutdown). No pedal will work so long.
For any pedal (as for any audio equipment) MTBF isn’t controlled parameter at all. And reliability is determined by luck (although the quality of development, components and manufacturing also affects).
In addition, all modern pedals (like other audio equipment) use SMPS.The only good solid state amp is a dead solid state amp. Unless it sounds really good, then its OK.
I too would (and have) built in the conventional format of selecting a suitable power transformer capable of supplying sufficient current with adequate headroom and thermal capacity, and not go in the direction of SMPS. Keep it simple, reliable, built to last.Logic is an organized way of going wrong with confidence
Originally posted by mikepukmel View PostNot sure I agree with you completely, Doc. My brother is a real guitarist (opposed to me who just tinker), he's got a very large collection of boxes, and several just don't work with any of the SMPS he has. They made odd, and awful noises, unless plugged in to a 9v battery. I would like to try those sensitive pedals with a clean linear supply and see how they perform.
Originally posted by mikepukmel View PostYeah, and given that a usable, working SMPS is so far over my engineering capabilities ... its a no-op for me: buy whatever, or build a linear.Last edited by Dave H; 12-31-2018, 09:21 AM.
No one should agree with me. I just expressed my opinion both as a pro-audio engineer who designed and manufactured a variety of equipment: pedals, amplifiers, analog and digital effects, etc., and as a guitarist.
And, of course, I did not mean that someone will develop and manufacture the SMPS here. Judging by the level of discussion, here are no specialists with the necessary qualification.
I had in mind to buy ready-made SMPSs for $ 5.00 and not bother.
