Page 3 of 3 FirstFirst 123
Results 71 to 73 of 73
Thread: Need ideas for a limiter circuit
  1. #71
    Supporting Member eschertron's Avatar
    Join Date
    Aug 2012
    Location
    Great Black Swamp
    Posts
    2,064
    Thumbs Up/Down
    Received: 264/0
    Given: 697/1
    Rep Power
    9
    Quote Originally Posted by Gaz View Post
    What circuits have you been looking at? It goes without saying, but I'm looking for more ideas now too
    Quote Originally Posted by J M Fahey View Post
    Oh, donīt worry, discussions are aways worth it because lots of new ideas appear .
    Pity this simple clever limiter which covers 99% of amps, from TDA2030 to 1000W monsters met the 1% which does NOT use dual rails.
    The one criterion I used for the class D amp that I selected, was that it was cheap. Literally, about USD $2, free shipping. If I end up finding something else that I like that also works better with the limiter design mentioned, I'd go for that.
    As far as using a J111 as a variable resistor, I'm back at looking for designs and discussions across the interwebs. If I'm using a 24vdc single-ended power supply, my signal path will be with +/-12vdc rails, otherwise indistinguishable from most stomp-box designs. There's plenty of compressor-type pedals that might help the design process. And I'm not above having a diode string to ensure a max level. As I see it, there are two design goals:
    1) prevent a signal level that causes the class D amp's output to collapse. Maybe some other modules are better in this regard, but the one I'm testing displays nasty behavior here. A simple diode clipper can do this.
    2) create a bit of compression just before clipping that models a traditional PP tube amp. This is where compression/sustain gives a little 'sweetness' to the notes. I expect a limiter circuit to be highly effective for this.
    0 Not allowed! Not allowed!
  2. #72
    Old Timer J M Fahey's Avatar
    Join Date
    Oct 2007
    Location
    Buenos Aires, Argentina
    Posts
    11,016
    Thumbs Up/Down
    Received: 1,150/18
    Given: 878/24
    Rep Power
    26
    As of plain clipping avoiding rail smashing, single diode drop is often not enough, so I often use a couple antiparallel red Leds, 1.9V peak each way so nice 1.5V RMS , enough for any regular power amp, and then add a trimmer after that, as a fixed Master Volume.
    I start with "Master" set to "1" , rise signal until Leds moderately clip (flat topped sinewave) , then slowly rise master trimmer until I see Class D amp clip on its own, which is clearly visible, sinewave becomes "squarier" and tops become flatter and wider, then back up a little until Class D amp is not clipping on its own.
    Then leave it there.
    In a way, same as old VOX Thomas limiter, only they varied clipping threshold by adjusting diode bias, I do the opposite by relying on fixed clipping, no bias involved, and varying clipped signal out level.
    End result ia about the same.
    You can use strings of plain diodes instead, but 2 Leds are equivalent to 6 diodes, for about same result,so I pick the simplest version.
    Itīs also easier to add to a pre existing circuit, no PCB needed
    3 Not allowed! Not allowed!
  3. #73
    Join Date
    Mar 2009
    Posts
    519
    Thumbs Up/Down
    Received: 22/0
    Given: 25/0
    Rep Power
    11
    End result is about the same.
    I used your red LED idea (except add another in series to each side), and it clips ~3.6Vp. This is just about perfect, and I am using the trimmer after the clipper like you mentioned to take it down a little if needed. Like you said, this is simpler than the Vox scheme.
    I also found this circuit, and it works well! It has pretty much the same performance at the LEDs however, and even when I force them both to clip hard they pretty much sound the same. In practice that volume level (800Wrms or more) subtly is lost.
    https://www.allaboutcircuits.com/tec...ified-signals/
    1 Not allowed! Not allowed!
Thread Information
Users Browsing this Thread
There are currently 2 users browsing this thread. (0 members and 2 guests)
  1. limiter design
    By catalin gramada in forum Theory & Design
    Last Post: 04-26-2017, 02:02 PM
  2. ADR Express Limiter
    By ID Crisis in forum Music Electronics
    Last Post: 03-18-2013, 12:38 AM
  3. Mesa Boogie SOB Limiter Mod?
    By gregsk777 in forum Mods & Tweaks
    Last Post: 10-22-2010, 09:59 AM
  4. MXR M-112 Mini-Limiter
    By Mark Hammer in forum Schematic Requests
    Last Post: 12-19-2009, 04:51 PM
  5. odd circuit ideas
    By Mystic in forum Theory & Design
    Last Post: 09-16-2009, 06:26 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
