Results 1 to 14 of 14
Thread: Compensating output levels in PJ sets
    Member bea's Avatar
    Dec 2010
    Germany, FRA
    278
    Received: 28/0
    Given: 1/0
    10
    Hi there,
    actually nearly a FAQ. Compensation of the large difference in output levels in a PJ pickup set. Usually the P cannot be lowered sufficiently to compensate or You might want to have the more aggressive tone of a split coil not too far away from the strings.
    A transformer with a ratio of about 3dB (1:1.4) would probably be sufficient. I am aware on the effect of the transformer on the resonant frequency of the pickup - pickups like the Dimarzio Ultrajazz might actually profit from that effect.
    I found a few transformers in the Xicon TM... series - but i am afraid the core would already suffer from saturation effects in the lower registers. Any hints for more capable but still small transformers? Maybe with a 25mm core?
    Supporting Member
    Mar 2018
    Germany
    2,589
    Received: 1,962/1
    Given: 1,118/2
    5
    Not sure, if I understand. Why not simply wire a suitable resistor in series with the louder PU? Any loss of highs can be compensated by a capacitor in parallel with the series resistor.
    4 Not allowed! Not allowed!
    - Own Opinions Only -
    May 2015
    98
    Received: 7/2
    Given: 47/3
    5
    " suitable resistor in series with..."
    Or a 50...100 kΩ trim pot.
    Member bea's Avatar
    Dec 2010
    Germany, FRA
    278
    Received: 28/0
    Given: 1/0
    10
    This is just what i'm going to replace....
    Supporting Member
    Mar 2018
    Germany
    2,589
    Received: 1,962/1
    Given: 1,118/2
    5
    Quote Originally Posted by bea View Post
    Why?
    A good quality miniature high impedance/inductance step-up audio transformer will probably cost more than a new PU. Unsuitable transfomers will cut bass response.
    Member bea's Avatar
    Dec 2010
    Germany, FRA
    278
    Received: 28/0
    Given: 1/0
    10
    I did not get the sound right. A voltage divider with treble bleed resistor usually sounds "weak" in that range.
    Junior Member
    Nov 2016
    7
    0
    I'm assuming the P pickup is the louder of the two. Depending on how tall the pickup is, you might be able to lower it more than you're able to now by shaving the foam to half height with a utility razor blade. You can also try Stewart-Macdonald's foam with built-in springs, and put that foam only directly under the pickup ears (where the screws go through), which I believe would let you run the pickups really low. You could cut the foam to a very small size to limit its contact with the bottom of the pickup body.
    The only downside I can think of is that if you move the pickup(s) so low that the strings are only barely in the magnetic field, then that reduced-volume pickup may also sound flat and non-dynamic, as if you were playing through a preamp with a weak vacuum tube.
    Member bea's Avatar
    Dec 2010
    Germany, FRA
    278
    Received: 28/0
    Given: 1/0
    10
    Quote Originally Posted by nhbassguitar View Post
    And that's why i'm considering using a transformer.
    Actually one of my target basses has the J-pickup so close to the bridge that it would profit of a lowering of the trebele resonance frequency.
    Supporting Member
    PDX
    3,314
    Received: 59/0
    Given: 32/0
    18
    Cinimag makes some of the nicest DI and other audio xformers around. They used to be in the $50 range.
    I'd suggest dropping 1000 turns off the P pickups and/or demagnetizing them slightly. Likewise you could bring the turns count of the J pickup up to 10,000 turns.
    Senior Member LtKojak's Avatar
    Feb 2008
    Milano, Italy
    1,029
    Received: 44/3
    13
    The simplest solution in this specific case would be a "blend" pot.
    1 Not allowed! Not allowed!
    Pepe aka Lt. Kojak
    Milano, Italy
    Woodgrinder/Pickupwinder copperheadroads's Avatar
    Jun 2009
    Iceburg Alley ,Newfoundland,CAN
    2,153
    Received: 41/1
    Given: 41/0
    13
    Beef up the Jazz pickups output by start winding with smaller wire or finishing with smaller wire like 43 gauge so you will have to change & join wires half way through the wind .
  12. #12
    Member bea's Avatar
    Dec 2010
    Germany, FRA
    278
    Received: 28/0
    Given: 1/0
    10
    I just tried the transformer idea, using a Monacor LTR-110. This is a fairly cheap yet still good line transformer with a secondary for 1:1 and one for 1:0.5. connecting them and using them as an autotransformer with a 50Ohms source and a load of 33k worked fine. But with the high impedance pickup the sound was thin, and the level was very low. Looks like a strong mismatch.
    (I bought the transformer for DI-out in a forthcoming tube amp project, a task where it is doing very well.)
    Well, the probably best thing might be a really hot J-pickup for the bridge matching the split coil as suggested above... and in one of the two basses in question that's the only option anyway, because space is lacking for the transformer.
    The "blend pot" approach is what i'm more or less using now, realized by a four way switch.
  13. #13
    Supporting Member
    Mar 2018
    Germany
    2,589
    Received: 1,962/1
    Given: 1,118/2
    5
    A transformer for a PU needs to have a considerably higher primary inductance than the PU's to not load down the PU especially at bass frequencies. Meaning 20H or more with a Hi-Z PU.
  14. #14
    Member bea's Avatar
    Dec 2010
    Germany, FRA
    278
    Received: 28/0
    Given: 1/0
    10
    That's what i actually expected when i thought about the idea the first time - but i wanted to try. (And it was fun to see an autotransformer actually transforming upward on the scope).
    As i don't want to bother with ultra fine wire i think i'll send a request to Christoph Dolf.
  1. Compensating a tube amp for oscillation
    By rf7 in forum Maintenance, Troubleshooting & Repair
    Last Post: 11-19-2012, 09:49 PM
  2. Lefty strat sets
    By Lpone in forum Pickup Makers
    Last Post: 08-27-2011, 12:37 AM
  3. can we attenuat sound without compensating
    By kldguitar in forum Theory & Design
    Last Post: 05-10-2010, 03:07 AM
  4. xformer sets for 5E3
    By tooloud in forum 5 E 3
    Last Post: 09-04-2009, 10:26 PM
  5. Help understanding tube preamp output levels
    By armstrom in forum Theory & Design
    Last Post: 11-01-2008, 02:41 PM
