Here's to good ideas, hope it all works out.
Increasing treble/bite and reducing midrange in humbucker
Originally posted by Helmholtz View PostYou might at least try to increase to 500k.Originally posted by big_teee View PostThe 500k with the vintage wiring I showed should give more tone roll off.
TOriginally posted by Helmholtz View PostA 250k tone pot is like 500k tone pot turned "halfway" down.
I purposely select 250k tone pots and smaller tone capacitors because I like a subtle rolloff and the taper isn't as sudden. I use varying shades of hf rolloff and never require the rapid and drastic changes that result from 500pk pots and larger tone caps( >0.033uF)
Originally posted by Tone Meister View PostI purposely select 250k tone pots and smaller tone capacitors because I like a subtle rolloff and the taper isn't as sudden. I use varying shades of hf rolloff and never require the rapid and drastic changes that result from 500pk pots and larger tone caps( >0.033uF)
Good luck, I'm done!
T"If Hitler invaded Hell, I would make at least a favourable reference of the Devil in the House of Commons." Winston Churchill
T
I will certainly know more after tonight's show. Thanks for all the great information!
Originally posted by Helmholtz View PostWhat about a linear taper 500k tone pot? Linear is less "sudden" than audio/log taper.
I feel like I've made some progress toward that goal. I will know much more after the show.
I roughly simulated your pickup on LTspice. Since you only have one tone control the schematic you posted can't show us how your switch is wired. If the unused portions of your switch can be used to eliminate the 250k tone control strictly from the bridge only selection you can gain 5dB at the resonant peak of around 1.8kHz. Which is also bumped up in frequency a a couple hundred Hz from where it's at with the arrangement you have. Both effects should give a much "brighter" tone.
Originally posted by Tone Meister View PostGood point, but realistically how much influence would increasing the value on the bridge tone pot actually have? The goal here is simply to increase treble/bite and slightly scoop the midrange. To change the tone pot to 500KL would make this guitar's tone control work differently than every other guitar I have.
I feel like I've made some progress toward that goal. I will know much more after the show.- Own Opinions Only -
Originally posted by Chuck H View PostI roughly simulated your pickup on LTspice. Since you only have one tone control the schematic you posted can't show us how your switch is wired. If the unused portions of your switch can be used to eliminate the 250k tone control strictly from the bridge only selection you can gain 5dB at the resonant peak of around 1.8kHz. Which is also bumped up in frequency a a couple hundred Hz from where it's at with the arrangement you have. Both effects should give a much "brighter" tone.
Originally posted by Tone Meister View PostI am asking specifically about ideas to tweak the existing pickup. No doubt the issue is the maple wood in this guitar body and I want to adjust it out.
All my guitars have treble bleeds - and the TBs have no affect on the circuit when the volume is wide open.
I use 10' cables to my pedalboards always, 22 pF/ft
I have 500k pots
Originally posted by John_H View PostWhat are you using for a treble bleed?
Fellas, listen up: I have this very same setup in two other guitars and don't have these issues. The only difference is this guitar has a maple body and a rock maple neck. The other two have alder bodies and maple necks. All three have rosewood fingerboards. I am absolutely convinced the body/neck wood is the culprit here. And the goal is to offset that with some minor tweaks.
Originally posted by Tone Meister View Post1nF in parallel with a 100k resistor.
Fellas, listen up: I have this very same setup in two other guitars and don't have these issues. The only difference is this guitar has a maple body and a rock maple neck. The other two have alder bodies and maple necks. All three have rosewood fingerboards. I am absolutely convinced the body/neck wood is the culprit here. And the goal is to offset that with some minor tweaks.Last edited by Helmholtz; 01-06-2019, 12:21 AM.- Own Opinions Only -
Originally posted by Tone Meister View PostI purposely select 250k tone pots and smaller tone capacitors because I like a subtle rolloff and the taper isn't as sudden. I use varying shades of hf rolloff and never require the rapid and drastic changes that result from 500pk pots and larger tone caps( >0.033uF)Originally posted by Tone Meister View PostI am asking specifically about ideas to tweak the existing pickup. No doubt the issue is the maple wood in this guitar body and I want to adjust it out.
I have 500k potsOriginally posted by Tone Meister View Post1nF in parallel with a 100k resistor.
Originally posted by Tone Meister View PostFellas, listen up: I have this very same setup in two other guitars and don't have these issues. The only difference is this guitar has a maple body and a rock maple neck. The other two have alder bodies and maple necks. All three have rosewood fingerboards. I am absolutely convinced the body/neck wood is the culprit here. And the goal is to offset that with some minor tweaks.=============================================
Keep Winding...Keep Playing!!!
Jim
Originally posted by Jim Darr View PostOne sure way to find out if it is the pickup or the maple guitar is to swap the bridge pickups of the two guitars and see if the problem stays with the maple guitar or the pickup!!!
It's possible there is something electronically different. The wind, a missed error in the wiring, etc. I wouldn't expect a asymmetrical humbucker in a maple guitar to sound more midrange than normal unless something is pinching off the highs."Take two placebos, works twice as well." Enzo
