Originally posted by Chuck H
View Post
Kalamazoo Bass 30 Tone Stack
Originally posted by nosaj View PostIt's possible they are damaged since they now draw more bias current from redplating. Tube testers don't always tell a lot about tubes more or less a pass/fail an amp circuit is the best test.
nosaj
A few things looking at the schematic are you have a half wave rectifier which in my experience seem to have a little hum to begin with. The other is the amp is cathode bias which means the tubes adjust themselves. The only thing you can adjust in this bias circuit is the 100 ohm resistor.- Own Opinions Only -
Originally posted by bobloblaws View PostFair enough, they were probably red plating for awhile before I noticed. But, I don't believe this has any effect on the bias voltage. I see the same bias voltage with tubes in or out. Please correct me if I'm wrong.
nosajsoldering stuff that's broken, breaking stuff that works, Yeah!
Originally posted by Helmholtz View PostFrom what I see in the schematic, the amp has a full wave HT rectifier and a combination of negative grid bias and additional cathode bias. The 100 Ohm cathode pot allows to adjust power tube symmetry, which should also minimize power stage hum.
I stand corrected Full Wave Center-tapped Rectifier.
nosajLast edited by nosaj; 01-07-2019, 01:28 AM.soldering stuff that's broken, breaking stuff that works, Yeah!
The amp is full wave rectified. The reason for a greater diode count would be to increase electrical capacities on the components, but it's really the arrangement of the circuit that counts. Most full wave and full wave bridge rectifiers do use four rectifiers. Some full wave's use six (three in series from each branch), but one diode from each leg of the HV winding is fine if the diode chosen is up to the electrical demands of the circuit."Take two placebos, works twice as well." Enzo
Please check those diodes (HT rectifiers). And post what the B+ reads for DC and AC voltage with power tubes out.
Just in case something in the HT circuit is messing up the bias circuit, usually they are more isolated than this.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Originally posted by g1 View PostPlease check those diodes (HT rectifiers). And post what the B+ reads for DC and AC voltage with power tubes out.
Originally posted by bobloblaws View PostBetween the 390K resistor and the bias diode I have 152 VDC and on the other side of that diode I have -12 VDC. At the power tube grid pin we have -10V (same with tube in or out), should be -22V based on what I saw yesterday.
Test the bias supply resistors for value. Replace if necessary. Just put a new diode in there. The typical 1n4007 will do (and you likely have one on hand?). See to it there are new caps in the bias supply and be sure the + terminal is the grounded end of the bias caps. If, by chance, you have a cap in the bias supply installed with incorrect polarity you must replace it now rather than just flip it around."Take two placebos, works twice as well." Enzo
Originally posted by Chuck H View PostWhat do you mean by "I tried swapping those out as well" WRT the bias caps? Did you replace them? Did you parallel them? Did you put in new caps and then take them back out? I'm unclear.
Originally posted by Chuck H View PostSee to it there are new caps in the bias supply and be sure the + terminal is the grounded end of the bias caps. If, by chance, you have a cap in the bias supply installed with incorrect polarity you must replace it now rather than just flip it around.
Originally posted by bobloblaws View PostDoes the cap that bypasses the 47K resistor need to be reverse polarity too? I have it in with negative to ground. I knew the other one needed to be reversed."Take two placebos, works twice as well." Enzo
Originally posted by Chuck H View PostThey should both be in "reverse polarity" (as it were?). That is, + to ground. You should just put in new caps. The bias supply is critical for safe tube operating parameters. Why take any chances.?.
Originally posted by Chuck H View PostThey should both be in "reverse polarity" (as it were?). That is, + to ground. You should just put in new caps. And by new caps I mean new. Not caps that have been languishing in a drawer for over five years because sitting unused is very bad for electrolytics. The bias supply is critical for safe tube operating parameters. Why take any chances.?.
