JCM900 Frequency Doubling Weirdness
  • #16
    Yikes 2 !!!
    True *sinewave* frequency doubling , never saw that in a power amp.
    Please triple check what nickb says.
    The centre tap IS the centre tap. 44/42 ohms to plates 86 ohms plate to plate.
    I'm beginning to suspect that I'm doing something stupid. WOuldn't be the first time. But I need to work out what.
    ( I should say that I did try playing a guitar through the amp and it did sound terrible).
    • #17
      Wild suggestion: Does the power full/half switch have any effect on the problem?
      • #18
        Can you see signal voltage at the OT primary CT? Maybe a bad filter cap (connection) causes some multiplication effect of the half-cycles?
        - Own Opinions Only -
        • #19
          did you try disconnecting feedback?
          • #20
            Changed the filter caps. No effect.
            • #21
              Feedback disconnected.
              No Effect
              • #22
                The effect is still there in half power mode
                • #23
                  Have you tried different input frequencies with the same result? Have you tried another pair of tubes?
                  • #24
                    OK. Got it. I'd already changed output transformers before I started poking around with the scope - I'd injected 2VAC into the transformer secondary and the voltage on the primaries looked a little unbalanced, so I swapped it out with a brand new Marshall part.
                    Foolishly, I assumed that the new, straight-from-Marshall transformer would be OK...
                    When I measured the CT-plate and plate-plate resistances everything looked sensible.
                    However I tried the 2VAC on the secondary thing again. Was getting sensible voltages from CT-Plate on each side.
                    However plate-plate was showing almost nothing. A quick look at the plates with the scope...
                    Both sides of the primary are in phase.
                    I said a bad word. Several times. Tried an old Laney 50W transformer that I had on the shelf, and all is rainbows and unicorns.
                    I'm going to have a word with the parts department at Marshall in the morning.
                    Thanks for your help everyone. Thought you'd like to know how this one turned out.
                    • #25
                      Yikes, again!
                      So glad you found it. That was subtle.
                      So why the same problem with the original transformer?
                      • #26
                        Originally posted by nickb View Post
                        Yikes, again!
                        It wasn't the same problem - the problem was that it sounded terrible - weak and distorted. I hadn't looked at the original transformer with the scope. It was a couple of days between trying it out with each transformer. So it probably sounded terrible but in a different way. The human brains memory for audio is around 15 seconds apparently.
                        • #27
                          Wow, who would/could have thought of something like this? It means that one of the 2 primary halves was connected at the wrong end to the CT. In result the signal voltages of the 2 power tubes are not added as supposed but substracted instead.
                          Good job, though!
                          • #28
                            Originally posted by Helmholtz View Post
                            Wow, who would/could have thought of something like this! It means that one of the 2 primary halves was connected at the wrong end to the CT. In result the signal voltages of the 2 power tubes are not added as supposed but substracted instead.
                            Doesn't say much for the transformer manufacturer's final QA process, does it?
                            • #29
                              Just curious what brand was that transformer?
                              By your words, not a Marshall original part (meaning Drake or Dagnall)
                              I will laugh all the way to China and back if it turns out to be an expensive MM though
                              • #30
                                It was a Dagnall, bought direct from Marshall.
