Results 1 to 12 of 12
Thread: Sentura II Quiescent Noise
    Member patlaw's Avatar
    Jun 2012
    215
    Received: 54/0
    Given: 21/0
    8
    When my Sunn Sentura II is sitting idle with the volume turned all the way down, there is a certain amount of hiss in the speakers. When playing loud, it's not a problem. When recording in a studio, it would be nice to have it quieter. The amp has been completely recapped. The tubes are in good shape. Everything is working as it should - except for the noise. Some people say the problem is resistors. I'm wondering where you think I should look. The hiss level does not change with the volume control, so the problem is not in the preamp section.
    Sep 2011
    Pace, FL
    3,108
    Received: 1,016/100
    Given: 141/35
    11
    Quote Originally Posted by patlaw View Post
    Noisy plate resistors?
    http://www.geofex.com/ampdbug/hiss.htm
    nosaj
    Jun 2012
    215
    Received: 54/0
    Given: 21/0
    8
    Quote Originally Posted by nosaj View Post
    nosaj
    The article mentions "noisy resistors in the B+ decoupling string, often around 10K in value." Which resistors are those?
    Near Dallas Texas
    3,511
    Received: 185/0
    Given: 104/1
    18
    Does turning the Treble Bass and Contour controls to zero affect the level of hiss? How about turning the Reverb control down?
    Jun 2012
    215
    Received: 54/0
    Given: 21/0
    8
    Quote Originally Posted by loudthud View Post
    Yes and no. The hiss I'm talking about is with everything turned down. If I turn up the volume or the reverb, a different hiss comes in, but that's normal and to be expected.
    Let me say that this hiss is not a major problem. Since I play the amp at home at low volume and do some recording with it, I'd like to reduce it as much as possible. That's why I wonder if the source is as esoteric as the plate resistors, which are easy enough to replace. I'd still like to know which components comprise the B+ decoupling string.
    Mar 2018
    Germany
    1,744
    Received: 1,314/1
    Given: 773/2
    4
    The PS resistors adressed in the link would be the ones between points A,B,C,D in the schematic. These resistors may produce some noise, but if the filter caps are good, most any noise is shorted to ground.
    If they are carbon compound types, replacing them with wirewounds might help a little. I wouldn't expect a significant difference.
    But things are different with bad/aged filter caps.
    2 Not allowed! Not allowed!
    - Own Opinions Only -
    Jun 2012
    215
    Received: 54/0
    Given: 21/0
    8
    Thanks for the info. I just noticed something strange on the schematic. The plate on the pentode of the 6AN8 shows 70 volts while the cathode shows 75 volts. Please confirm that's an error. There are other errors on the schematic, but this is the first time I've seen this one.
    Feb 2010
    11,492
    Received: 1,424/21
    Given: 3,551/8
    22
    And whatever that voltage is, it isn't coming through the 12pF either.
    Feb 2010
    11,492
    Received: 1,424/21
    Given: 3,551/8
    22
    Here's one that shows the plate resistor. Working from that 270K value and the supply node & 70V at the plate I think that cathode voltage should read .75Volts. 75V with that cathode resistance is pretty much impossible.
    1 Not allowed! Not allowed!
    Jun 2012
    215
    Received: 54/0
    Given: 21/0
    8
    The PS resistors addressed in the link would be the ones between points A,B,C,D in the schematic. These resistors may produce some noise, but if the filter caps are good, most any noise is shorted to ground.
    The filter caps are new.
    Sep 2011
    Pace, FL
    3,108
    Received: 1,016/100
    Given: 141/35
    11
    New , does not mean good.
    nosaj
  12. #12
    Near Dallas Texas
    3,511
    Received: 185/0
    Given: 104/1
    18
    I would be suspicious of those two high value (220K and 620K) resistors at the input (pin 8) of the 6AN8. Replace with metal film if you can find them.
  1. Biasing or quiescent current procedure vh140c
    By xjbear in forum Maintenance, Troubleshooting & Repair
    Last Post: 05-28-2018, 03:20 AM
  2. Sentura II Grill Cloth
    By patlaw in forum SUNN
    Last Post: 10-31-2017, 09:35 PM
  3. Help with a 68 Sunn Sentura II
    By shiner555 in forum Maintenance, Troubleshooting & Repair
    Last Post: 03-19-2015, 02:10 AM
  4. QSC ISA500 quiescent current
    By MarkusBass in forum Maintenance, Troubleshooting & Repair
    Last Post: 07-19-2011, 01:53 PM
  5. Sunn Sentura 2
    By Mars Amp Repair in forum Maintenance, Troubleshooting & Repair
    Last Post: 06-05-2007, 09:46 PM
