Results 1 to 12 of 12
Thread: Sentura II Quiescent Noise
  1. #1
    Member patlaw's Avatar
    Join Date
    Jun 2012
    Posts
    207
    Thumbs Up/Down
    Received: 50/0
    Given: 21/0
    Rep Power
    7
    When my Sunn Sentura II is sitting idle with the volume turned all the way down, there is a certain amount of hiss in the speakers. When playing loud, it's not a problem. When recording in a studio, it would be nice to have it quieter. The amp has been completely recapped. The tubes are in good shape. Everything is working as it should - except for the noise. Some people say the problem is resistors. I'm wondering where you think I should look. The hiss level does not change with the volume control, so the problem is not in the preamp section.
    0 Not allowed! Not allowed!
  2. #2
    Master Destroyer nosaj's Avatar
    Join Date
    Sep 2011
    Location
    Pace, FL
    Posts
    2,795
    Thumbs Up/Down
    Received: 813/100
    Given: 113/33
    Rep Power
    10
    Quote Originally Posted by patlaw View Post
    Noisy plate resistors?
    http://www.geofex.com/ampdbug/hiss.htm
    nosaj
    Binkie McFartnuggets‏:If we really wanted to know the meaning of life we would have fed Stephen Hawking shrooms a long time ago.
  3. #3
    Join Date
    Jun 2012
    Posts
    207
    Thumbs Up/Down
    Received: 50/0
    Given: 21/0
    Rep Power
    7
    Quote Originally Posted by nosaj View Post
    nosaj
    The article mentions "noisy resistors in the B+ decoupling string, often around 10K in value." Which resistors are those?
  4. #4
    Supporting Member loudthud's Avatar
    Join Date
    May 2006
    Location
    Near Dallas Texas
    Posts
    3,477
    Thumbs Up/Down
    Received: 147/0
    Given: 85/1
    Rep Power
    17
    Does turning the Treble Bass and Contour controls to zero affect the level of hiss? How about turning the Reverb control down?
  5. #5
    Join Date
    Jun 2012
    Posts
    207
    Thumbs Up/Down
    Received: 50/0
    Given: 21/0
    Rep Power
    7
    Quote Originally Posted by loudthud View Post
    Yes and no. The hiss I'm talking about is with everything turned down. If I turn up the volume or the reverb, a different hiss comes in, but that's normal and to be expected.
    Let me say that this hiss is not a major problem. Since I play the amp at home at low volume and do some recording with it, I'd like to reduce it as much as possible. That's why I wonder if the source is as esoteric as the plate resistors, which are easy enough to replace. I'd still like to know which components comprise the B+ decoupling string.
  6. #6
    Join Date
    Mar 2018
    Location
    Germany
    Posts
    1,361
    Thumbs Up/Down
    Received: 967/1
    Given: 637/2
    Rep Power
    4
    The PS resistors adressed in the link would be the ones between points A,B,C,D in the schematic. These resistors may produce some noise, but if the filter caps are good, most any noise is shorted to ground.
    If they are carbon compound types, replacing them with wirewounds might help a little. I wouldn't expect a significant difference.
    But things are different with bad/aged filter caps.
    2 Not allowed! Not allowed!
  7. #7
    Join Date
    Jun 2012
    Posts
    207
    Thumbs Up/Down
    Received: 50/0
    Given: 21/0
    Rep Power
    7
    Thanks for the info. I just noticed something strange on the schematic. The plate on the pentode of the 6AN8 shows 70 volts while the cathode shows 75 volts. Please confirm that's an error. There are other errors on the schematic, but this is the first time I've seen this one.
  8. #8
    Join Date
    Feb 2010
    Location
    Posts
    11,204
    Thumbs Up/Down
    Received: 1,161/21
    Given: 2,934/8
    Rep Power
    22
    And whatever that voltage is, it isn't coming through the 12pF either.
    Just because they don't have tubes doesn't mean they don't have feelings! - glebert
  9. #9
    Join Date
    Feb 2010
    Location
    Posts
    11,204
    Thumbs Up/Down
    Received: 1,161/21
    Given: 2,934/8
    Rep Power
    22
    Here's one that shows the plate resistor. Working from that 270K value and the supply node & 70V at the plate I think that cathode voltage should read .75Volts. 75V with that cathode resistance is pretty much impossible.
    1 Not allowed! Not allowed!
  10. #10
    Join Date
    Jun 2012
    Posts
    207
    Thumbs Up/Down
    Received: 50/0
    Given: 21/0
    Rep Power
    7
    The PS resistors addressed in the link would be the ones between points A,B,C,D in the schematic. These resistors may produce some noise, but if the filter caps are good, most any noise is shorted to ground.
    The filter caps are new.
  11. #11
    Join Date
    Sep 2011
    Location
    Pace, FL
    Posts
    2,795
    Thumbs Up/Down
    Received: 813/100
    Given: 113/33
    Rep Power
    10
    New , does not mean good.
    nosaj
  12. #12
    Join Date
    May 2006
    Location
    Near Dallas Texas
    Posts
    3,477
    Thumbs Up/Down
    Received: 147/0
    Given: 85/1
    Rep Power
    17
    I would be suspicious of those two high value (220K and 620K) resistors at the input (pin 8) of the 6AN8. Replace with metal film if you can find them.
Thread Information
Users Browsing this Thread
  1. Biasing or quiescent current procedure vh140c
    By xjbear in forum Maintenance, Troubleshooting & Repair
    Last Post: 05-28-2018, 03:20 AM
  2. Sentura II Grill Cloth
    By patlaw in forum SUNN
    Last Post: 10-31-2017, 09:35 PM
  3. Help with a 68 Sunn Sentura II
    By shiner555 in forum Maintenance, Troubleshooting & Repair
    Last Post: 03-19-2015, 02:10 AM
  4. QSC ISA500 quiescent current
    By MarkusBass in forum Maintenance, Troubleshooting & Repair
    Last Post: 07-19-2011, 01:53 PM
  5. Sunn Sentura 2
    By Mars Amp Repair in forum Maintenance, Troubleshooting & Repair
    Last Post: 06-05-2007, 09:46 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
