0
Thumbs Up/Down |
Received: 150/2 Given: 14/0 |
I have an EHX Guitar Micro-Synth on the repair bench. I have pretty well all the schematics I need for it, but there are ONE HELLUVA LOTTA CHIPS ON THE BOARD and none of them are identified by any legending. I could really use a component layout map or drawing of some kind so I could probe in the relevant places.
For now, it doesn't trigger or produce any sound other than the straight guitar signal. The filter "works" but doesn't sweep. Resonance works and both Start and Stop Freq controls will change the filter setting.
It's the first issue, or close to it, using the 5554 dual regulator, with no power-on indicator LED. Has a pale green PCB. If you could direct me to a legended pic or layout drawing, that would be terrific.
Thumbs Up/Down |
I don't know about "big name", but I'll give them a try. I was hoping there might be something posted that a Google image search didn't locate.
Perhaps Enzo has something tucked away.
Thumbs Up/Down |
Received: 657/100 Given: 99/33 |
Binkie McFartnuggets:If we really wanted to know the meaning of life we would have fed Stephen Hawking shrooms a long time ago.
Thumbs Up/Down |
The footswitch does work, though I don't get bypass, only clean signal in synth mode. This one is a lot earlier than yours. It's big and black but uses the onboard transformer.
Thumbs Up/Down |
Best I could do are these Factory schematics but no layouts.
https://sites.google.com/site/electr...ive/schematics
nosaj
Thumbs Up/Down |
Received: 1,226/7 Given: 0/0 |
I am not in good shape right now, but my contact with Mike Matthews was all in the very early days. Low serial #Sovtek Amps, and the original Big Muff pedals made of Russian military parts. No layouts of digital stuff. But call them, they have tried to be helpful before. You are certainly a way bigger name than I am.
Thumbs Up/Down |
Note sent. I doubt that my verbosity on forums holds any sway with the people at the other end of tech-support in-boxes, but they've been responsive in past interactions, so I'm hoping for a repeat performance. Whether their archives are as fulsome as their desire to help may be a whole other matter.
Thumbs Up/Down |
My good wishes for best health as well.
As it turned out, the right honourable Stephen Giles, who worked for EHX in Great Britain many years back, posted a scan of a drawing he had made years back, in response to my request, that labels all the chips corresponding to the same pedal issue. I think that may be enough to do the requisite detective work. Someone also posted a link to a site by Snarling Dogs co-founder Richard Excellente, where he describes his various roles within EHX over the years, including co-designing the Micro-Synth with David Cockerell. Very interesting reading.
https://captain6string.blogspot.com/
Thumbs Up/Down |
Thumbs Up/Down |
Thumbs Up/Down |
Fixed. All voices working again. The bridge rectifier was fried, and 5 dual op-amps were also fried when whatever happened, happened.
