complaint volume drops 50% or better,not completely out , happens regardless what input or channel is in use, bumping the fader up will bring it back . I went over to hear it for myself and of course it wouldn't fail . I told them to keep notes to see if it happened roughly around the same time ,thinking something is getting hot and failing. Report back was intermittent ,sometimes happens at start up , 20mins 30mins etc. I've search through MEF archives but didn't see anything with this problem, any suggestions ??
Mackie 1604 vlzpro intermittent volume drop
Last edited by shortcircuit; 01-17-2019, 02:49 PM.If you don't know where your going any road'll take you there : George HarrisonTags: None
That link is dead.
Without knowing anything about the mixer, has the client tried a lube/cleaner/restorative on the fader track?If it still won't get loud enough, it's probably broken. - Steve Conner
it's not just one track , it does it regardless of input on all tracks ,to answer the question no I'm sure they haven't messed with anything, other than running the Mackie powered speakers with another mixer to isolate down to the 1604. Sorry about the dead link, I'm working on it.https://supportloudtech.netx.net/lou...category/11527
sorry I can't get my downloaded pdf to loadLast edited by shortcircuit; 01-17-2019, 03:42 PM.If you don't know where your going any road'll take you there : George Harrison
The Loud Tech portal is pretty handy, good source of info.
To be clear, when it happens it happens on all channels simultaneously? Or individual channels randomly?
Bumping up the fader will allow the user to compensate for the volume loss, or "bumping a fader" restores the original volume?If it still won't get loud enough, it's probably broken. - Steve Conner
Originally posted by eschertron View PostThe Loud Tech portal is pretty handy, good source of info.
Bumping up the fader will allow the user to compensate for the volume loss, or "bumping a fader" restores the original volume?If you don't know where your going any road'll take you there : George Harrison
If I didn't know this guy I'd say he's hearing things , listened to some great music for a couple of hours , never heard a volume drop . I brought it home just to please them , I'll clean the jacks , give it a once over , recommendations on cleaning fader tracks ??Last edited by shortcircuit; 01-17-2019, 09:10 PM.If you don't know where your going any road'll take you there : George Harrison
Originally posted by shortcircuitIf I didn't know this guy I'd say he's hearing things , listened to some great music for a couple of hours , never heard a volume drop . I brought it home just to please them , I'll clean the jacks , give it a once over , recommendations on cleaning fader tracks ??
I never did buy into the procedure of spraying in contact cleaner thru the pot shaft openings, as it destroys the viscosity feel from the greased shaft/bushings. The pots that really suffer are the Gain Trims.....that last 15 deg of rotation where you get to max gain is ALWAYS nasty as they age. I've pulled the pots out, pulled them apart, cleaned / lubed them, put back together and re-installed them with far better luck than spraying down thru the shafts. The switches.....just as with the pots....exercise the dickens out of them, and replace the ones that don't come back to being stable and quiet. The slide pots....I've cleaned the tracks on those after pulling them and lubricating the resistive elements. Or, just replace them.
They are tedious to disembowel. Also, the power supply on those run VERY HOT...something they've never cured, nor did I get any proper solution to improving upon. At Westlake, we used to service these on a regular basis....maybe 10 per month.Logic is an organized way of going wrong with confidence
^^^^^^ What he said about ribbon cables. I worked for a Mackie warranty station years ago and we replaced tons of ribbon cables. And, they can be horribly intermittent. Last I knew, they were on revision 'G' for ribbon cables in the VLZ series. Seven revisions to figure out a f'n ribbon cable. It's a bit ridiculous. I'd pop it open and see what the revision number on the ribbons is."I took a photo of my ohm meter... It didn't help." Enzo 8/20/22
Which output? Any or all? If it's just one side (for example) I'd normally think fader or insert jack for that output.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Originally posted by g1 View PostWhich output? Any or all? If it's just one side (for example) I'd normally think fader or insert jack for that output.If you don't know where your going any road'll take you there : George Harrison
Originally posted by nevetslab View PostThe switches.....just as with the pots....exercise the dickens out of themIf it still won't get loud enough, it's probably broken. - Steve Conner
Originally posted by shortcircuit View PostClient says it happens regardless what channel your using, as I stated I have yet to hear it happen .Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
I'm sorry , yes he's talking input channels . Outputs : first they said they were using the L & R and the R sounded weak , so he started using the L & mono , then he started getting this volume drop off . I have it here now, I did a quick hook up using L & R outputs , both sounded normal/equal to me , output meter led's are even ,no weak channel , so far no drop .If you don't know where your going any road'll take you there : George Harrison
Originally posted by shortcircuit View PostI'm sorry , yes he's talking input channels . Outputs : first they said they were using the L & R and the R sounded weak , so he started using the L & mono , then he started getting this volume drop off . I have it here now, I did a quick hook up using L & R outputs , both sounded normal/equal to me , output meter led's are even ,no weak channel , so far no drop .If it still won't get loud enough, it's probably broken. - Steve Conner
