Marshall caps
  • Marshall caps
    I cant find a 70s/80s Marshall schematic that shows 6 filter caps. I see that some of them did physically have 6 cans in there . Im talking about the 2203 models specifically .
    All the scems I can find show 3 , 50/50 can caps
    Did they come from the factory with 6 single 50uf filter caps ?? Or did they just not use half of them ?
    Maybe cause your looking at the re-issue amps. Here's a 2203 but they're not 50uf
    https://el34world.com/charts/Schemat...ad_100watt.gif
    nosaj
      Well, a 50/50 can is two caps. So three dual cans is six caps right there.
      The fact two caps live in the same can does not change the fact they are two separate caps.
        i see 4 can caps...am i missing something? the 10uf are bias
        the reason i ask is i just scored a 1980 JMP 2203. It has 6 can caps but i havent looked at it yet, and i didnt see a scem with 6 cans
          http://www.amparchives.com/folder/751/
          after looking through the photos...there are six " dual" 50/50 Daly can caps.....yes?
            Look at the schematic nosaj posted, the ones shown as 100uF might be made of two 50 halves paralleled. So 1 can for each 100uf shown.
              My '83 2204 has 3 2x50uF caps, one is jumpered to make a 100uF cap, and the others are used individually. I'm sure it was cheaper and less expensive to stock one cap versus two different ones.
