Results 1 to 5 of 5
Thread: Newcomb D-10 conversion from HiFi Mono to guitar amp?
  1. #1
    New Member
    Join Date
    Aug 2018
    Posts
    1
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    Rep Power
    0
    I have a Newcomb D-10 that I want to mod into a guitar, bass, and/or harp amp.
    Does anyone have a schematic? The schematic on the bottom panel is damaged.
    Also, any recommendations regarding things I'll need to change (aside from the obvious replacement of caps) in order to make a good instrument amp out of it?
    It uses a 12AX7, a 6SC7, a 6AX5GT, and two 6v6GTs.
    Is this a viable conversion?
    It has 6 different inputs, and it has both an 8 and 16 ohm output.
    0 Not allowed! Not allowed!
  2. #2
    Supporting Member mozz's Avatar
    Join Date
    Oct 2015
    Location
    NEPA
    Posts
    766
    Thumbs Up/Down
    Received: 149/1
    Given: 109/0
    Rep Power
    4
    If you post to the antique radio forum, someone there might have a schematic. It appears in Sams photofact, i think 1956 is before the copyright fiasco so it should be able to be posted.
  3. #3
    Join Date
    Oct 2015
    Location
    NEPA
    Posts
    766
    Thumbs Up/Down
    Received: 149/1
    Given: 109/0
    Rep Power
    4
    I found i actually have the Sams for this model. I can post it but need to make a flatbed scan on the old windows xp computer.
    2 Not allowed! Not allowed!
  4. #4
    Old Timer olddawg's Avatar
    Join Date
    Dec 2007
    Location
    La Jolla CA, Hanalei, Kauai
    Posts
    2,861
    Thumbs Up/Down
    Received: 202/0
    Given: 22/0
    Rep Power
    14
    Honestly.. I always say this. But I would just use the iron and the chassis... MAYBE some pots if they arenít shot. New ceramic tube sockets are $2 apiece. A new turret board and all new components wonít break the bank either. Could save you hours chasing wierd problems in the future. You can also cut some sheet metal for a new control front with the number of pots that you want in the place order you want.
  5. #5
    Join Date
    Oct 2015
    Location
    NEPA
    Posts
    766
    Thumbs Up/Down
    Received: 149/1
    Given: 109/0
    Rep Power
    4
    Wow, finally got my old scanner to work on Win7, scanned at 300dpi so they are readable.
Thread Information
Users Browsing this Thread
  1. Electrohome Mono Hifi into 5F11 Vibrolux
    By Toxophilite in forum Tweed Builders
    Last Post: 01-10-2014, 01:29 AM
  2. Newcomb conversion
    By SpareRibs in forum Conversion Projects
    Last Post: 04-17-2012, 06:26 AM
  3. stereo to mono conversion
    By dscottguitars in forum Conversion Projects
    Last Post: 11-22-2010, 06:37 PM
  4. Newcomb AV1612, phonograph...no conversion needed
    By wrathfuldeity in forum Conversion Projects
    Last Post: 04-30-2010, 03:17 AM
  5. Newcomb h-25 pa to guitar amp
    By jtmaupin in forum Conversion Projects
    Last Post: 03-02-2009, 09:58 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
