I have a Newcomb D-10 that I want to mod into a guitar, bass, and/or harp amp.
Does anyone have a schematic? The schematic on the bottom panel is damaged.
Also, any recommendations regarding things I'll need to change (aside from the obvious replacement of caps) in order to make a good instrument amp out of it?
It uses a 12AX7, a 6SC7, a 6AX5GT, and two 6v6GTs.
Is this a viable conversion?
It has 6 different inputs, and it has both an 8 and 16 ohm output.
