Look at the NFB circuit. Start at the cathode of the V1b. You have a 1500 ohm to ground from there. You also have the 22k going over to the OT. The OT secondary winding has essentially no resistance, at least low enough to ignore. That winding is also grounded. That all serves to put the 22k in parallel with the 1500 ohm. Calculate those in parallel, and you get... 1.4k
Always consider parallel circuit paths when measuring parts in circuit.
There are lots of ways to lower output. Also check to see if they are running the 6V6 in triode mode. Is the screen connected like the original schematic?
Just a thought. The entire circuit is 12 resistors, and 6 caps. Might make sense to just gut it and build a new circuit.
Don't think I haven't already considered it. But my inquiring mind still wants to know what the builder did to purposely limit output to 1 watt. Can't be much, but I'm missing it.
