Page 3 of 3 FirstFirst 123
Results 71 to 93 of 93
Thread: OK Then
  1. #71
    Feb 2010
    11,093
    Received: 1,077/21
    Given: 2,698/8
    22
    The question to me is: Does the amp produce 1W just before clipping? In this case it would be really power limited (would require something like an extremely mismatched or defective OT- or power limiting resistors at the output).
    I think you need to specify 'power tube clipping'. Otherwise, we see clipping at the 1W point yet it could be clipped by a preamp tube. In that case it's not really power limited. This is where the measurement you suggested at the power tube grid is important.
    I say this because it has become common for manufacturers to 'fake' real power attenuation by limiting the drive and labelling the amp with so called 'power settings' like 1W,5W, etc. Often the clipping is in the PI stage, and what the '1W' label on the switch means is that when the power stage hits 1W output, some clipping happens somewhere in the amp. The '1W' then becomes more than that, actually whatever power a square wave at that same pk to pk voltage turns out to be.
  2. #72
    Mar 2018
    Germany
    1,271
    Received: 881/1
    Given: 595/2
    4
    You're right, I should have been more precise. I meant clipping above 1W though there is sufficient drive voltage.
    If we have preamp clipping, this would be my "case B", namely drive voltage limiting.
    1 Not allowed! Not allowed!
    - Own Opinions Only -
  3. #73
    Hack with a Workbench Tone Meister's Avatar
    Aug 2012
    NC, USA
    772
    Received: 95/1
    Given: 48/0
    7
    The amp produces 2Vrms with the volume control wide open. I can increase the input signal to 400mV and total power increases to a whopping 2.4Vrms @ 4 ohms. I don't have a scope yet, so I really can't tell what the wave is doing. I can guess if you want me to.
    Parts on the way. I'm gonna gut it.
  4. #74
    Aug 2012
    Great Black Swamp
    2,110
    Received: 315/0
    Given: 771/1
    9
    I'm wondering if the original builder used a wrong-value part, or an under-spec'd part, or otherwise messed up the amp so that it only made "1W" and that the notation of that is an observation, not a design choice.
    Do you have booster pedal or similar? I'm curious how hot you'd have to get the input before it starts to sound like a champ that's clipping. Do you have time for that experiment before dissecting the thing?
  5. #75
    Bent Member Chuck H's Avatar
    May 2007
    pacific north west
    14,572
    Received: 1,577/4
    Given: 1,735/0
    28
    Could you please just plug a guitar into it? There's not much in a Champ to clip the preamp tube with a guitar signal (with the possible exception of peaks from a hot humbucker). So if the amp audibly clips generously I would suspect attenuation of the output signal. If it doesn't clip other than peaks (attack) I would suspect attenuation of the preamp before the power tube grid.
  6. #76
    Feb 2010
    11,093
    Received: 1,077/21
    Given: 2,698/8
    22
    Quote Originally Posted by Tone Meister View Post
    Please measure the AC voltage at the power tube grid when you are getting that 2Vrms (before you gut it ).
    2 Not allowed! Not allowed!
  7. #77
    Aug 2012
    NC, USA
    772
    Received: 95/1
    Given: 48/0
    7
    I've been playing the snot out of it all week and I like it the way it is. It sounds about right to me - decent cleans with amp volume on 8 and the typical grind when it's dimed - but a detectable volume difference when compared to mine.
    4.9Vrms at the 6V6 grid
  8. #78
    May 2007
    pacific north west
    14,572
    Received: 1,577/4
    Given: 1,735/0
    28
    Well I'll guess that the signal is padded between the second preamp stage and the power tube grid then. It's very hard to see what all is going on in the pics because of the angle of shots and, of course, the nature of the wiring as it is. But what is THIS resistor doing? (circled in red) It sort of hides behind other stuff in all but this shot and I can't see well what it's connected to.
  9. #79
    Aug 2012
    NC, USA
    772
    Received: 95/1
    Given: 48/0
    7
    That circled resistor is the 220k grid leak
  10. #80
    May 2007
    pacific north west
    14,572
    Received: 1,577/4
    Given: 1,735/0
    28
    Ok. Then what is this one doing? It's clearly a different resistor.
  11. #81
    May 2007
    pacific north west
    14,572
    Received: 1,577/4
    Given: 1,735/0
    28
    I can't tell what pin the resistor I indicated in post #80 is connected to. Could it be a HV bleeder? I don't think so.It's proximity is on the correct side of the coupling cap to be the power tube grid leak and I can't see how the resistor I indicated in post #78 could be connected to the correct end on the coupling cap to be the power tube grid leak.
  12. #82
    Jun 2006
    Norristown state hospital
    2,128
    Received: 97/1
    15
    Wow.....I would not put my name on that.
    Dude, you gotta' pull back and give us a nice clean pic of the whole chassis We need to see this in proper context to fully appreciate how ugly it is!
    Then take a nice pic after you gut it and rebuild it properly.
  13. #83
    Aug 2012
    NC, USA
    772
    Received: 95/1
    Given: 48/0
    7
    Quote Originally Posted by drewl View Post
    Remember. You asked.
    With and without flash.
  14. #84
    Aug 2015
    Edmonton, AB
    192
    Received: 179/3
    Given: 96/3
    4
    My eyes! My eyes!
    What has been seen, cannot be un-seen...
    The world is full of people that are right.
  15. #85
    Sep 2011
    Pace, FL
    2,734
    Received: 763/100
    Given: 110/33
    10
    I say lift that cap on the vol switch just one side and see what happens to your wattage.
    nosaj
  16. #86
    Feb 2010
    11,093
    Received: 1,077/21
    Given: 2,698/8
    22
    edit: so the resistor in post #78 is actually 100K ?
  17. #87
    Aug 2012
    Great Black Swamp
    2,110
    Received: 315/0
    Given: 771/1
    9
    I think you might get some joy of documenting the post-mortem on this beast. Put all the components (or assemblies of components) onto a nice, white, sheet of paper in order to reconstruct the layout under laboratory conditions. You could be a CSI: Champ Schematic Investigator
    3 Not allowed! Not allowed!
  18. #88
    Feb 2010
    11,093
    Received: 1,077/21
    Given: 2,698/8
    22
    Who's in here:
  19. #89
    Aug 2012
    NC, USA
    772
    Received: 95/1
    Given: 48/0
    7
    You fellows are just not going let a man enoy a beer are you?
    I'll check those things for you
  20. #90
    May 2010
    Sioux Falls, SD
    5,788
    Received: 773/1
    Given: 634/1
    14
    You presented a puzzle to a bunch of electronics geeks. What did you expect?
    Edit: Another thing to check: Are the coupling caps the correct value?
  21. #91
    Aug 2012
    NC, USA
    772
    Received: 95/1
    Given: 48/0
    7
    That is one of the 100K
    THAT is the grid leak, yes. My bad
    Yes, 100K
    Who's in here:
    Another 10K in SERIES with another to make up the 22K?? Off the screen to the last filter cap, I reckon
  22. #92
    May 2007
    pacific north west
    14,572
    Received: 1,577/4
    Given: 1,735/0
    28
    Post removed as a courtesy.
  23. #93
    Feb 2010
    11,093
    Received: 1,077/21
    Given: 2,698/8
    22
    If it's just going to be guesswork and reckoning, might as well take a wild guess at what's causing the power reduction and close up the thread.
    Are you having a laugh? How hard can it be to check components against a simple 20 part schematic?
    Good luck.
