Page 1 of 3 123 LastLast
Results 1 to 35 of 93
Thread: OK Then
    Hack with a Workbench Tone Meister's Avatar
    Aug 2012
    NC, USA
    805
    Received: 116/1
    Given: 54/0
    8
    OK Then
    Champ 5F1 circuit built for 1 watt output, duly notated inside the cabinet and inside the chassis by the power tube socket. Tested and verified that indeed it produces exactly 1 watt into reactive load. (2Vrms into 4 ohms)
    I'd like to restore it back to stock but don't know where to start. Here is the relevant info:
    >Mercury FTCP-59 power transformer
    330-0-330, 6.3v no CT, 5v
    >Mercury Tone Clone FTCHO-5 output transformer
    single 4 ohm tap
    >Rectifier is a good, strong Ken Rad 5Y3
    315 VAC from the PT to rectifier (loaded)
    350 VDC out to first filter cap
    313 VDC at second cap
    273 VDC at third cap
    >6V6 Sylvania 6V6GT
    Pin 3 - 338.5 V
    Pin 4 - 313.8 V
    Pin 8 - 18.5 V
    >12AX7 RCA longplate
    Pin 1 - 163.7 V
    Pin 3 - 1.1 V
    Pin 6 - 183.1 V
    Pin 8 - 1.3 V
    Filaments are getting 6.7 VAC on each tube. Trying to figure out where the builder reduced output power.
ID:	52242   Click image for larger version.
ID:	52244   Click image for larger version.
    Attached Files Attached Files
    May 2010
    Sioux Falls, SD
    6,184
    Received: 1,107/1
    Given: 878/1
    16
    There's only a handful of components in that thing. I'd just start left to right on the eyelet board and see what doesn't match the factory layout. Shouldn't take long at all.
    1 Not allowed! Not allowed!
    Near Dallas Texas
    3,521
    Received: 201/0
    Given: 107/1
    18
    Verify that R8 is indeed 470 Ohm. Other than that I would need to verify the primary impedance of the output transformer. I think the stock OT has a 5K primary.
    Aug 2012
    Great Black Swamp
    2,216
    Received: 395/0
    Given: 1,039/1
    11
    What's the value of the NFB resistor?
    Does your amp match one of the schematics posted? If so, which one? (they differ by a cathode bypass resistor on stage 1)
    Aug 2012
    NC, USA
    805
    Received: 116/1
    Given: 54/0
    8
    Yeah, but it's not on a board, it's all point to point and the work is very sloppy. I did find a 220K from the 6V6 grid to ground that I'm wondering about. Wouldn't that limit curremt draw on the tube?
    Aug 2015
    Edmonton, AB
    239
    Received: 222/3
    Given: 112/3
    5
    Quote Originally Posted by Tone Meister View Post
    That is the grid leak.
    It's supposed to be there.
    2 Not allowed! Not allowed!
    The world is full of people that are right.
    Aug 2012
    NC, USA
    805
    Received: 116/1
    Given: 54/0
    8
    The V1 bypass resistor is 1K in this amp, not 1.5K. Also, the NFR is 1.4K and not 22K. R8 is indeed 470R.
    May 2010
    Sioux Falls, SD
    6,184
    Received: 1,107/1
    Given: 878/1
    16
    The other thing to look for would be series or parallel high wattage resistors in the OT secondary. It could just have built in power soak.
    Edit: I was typing during your last post. If the NFB resistor is 1.4K instead of 22K, you'll need to change that. That's a lot of additional NFB.
    Sep 2011
    Pace, FL
    3,143
    Received: 1,046/101
    Given: 143/35
    12
    What is the value of the volume pot?
    nosaj
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    31,785
    Received: 1,657/7
    54
    If the NFB resistor is 1.4k (and where did we get that odd value?) instead of 22k, then there is a tremendous increase in NFB signal. That will slow down a power stage. Just disconnect that resistor and see if the output grows.
    Aug 2012
    NC, USA
    805
    Received: 116/1
    Given: 54/0
    8
    Just looked closely. No power soak resistor(s)
  12. #12
    Aug 2012
    NC, USA
    805
    Received: 116/1
    Given: 54/0
    8
    I measured it. I was thinking that measuring 1.4K is better than relying on the stripes for actual value, at least in this case. After all, we have a (deliberate) reduction in output power. I'll disconnect that NFR and report back.
  13. #13
    Aug 2012
    NC, USA
    805
    Received: 116/1
    Given: 54/0
    8
    Peeled back the heatshrink and the NFR is 22K. Disconnexted it measures ok.
  14. #14
    May 2010
    Sioux Falls, SD
    6,184
    Received: 1,107/1
    Given: 878/1
    16
    If you upload a good pic or two, maybe somebody will spot something.
  15. #15
    Aug 2012
    NC, USA
    805
    Received: 116/1
    Given: 54/0
    8
    You asked for it, ha ha.
  16. #16
    Sep 2011
    Pace, FL
    3,143
    Received: 1,046/101
    Given: 143/35
    12
    Couldn't a properly sized volume pot throttle the amount of signal to hit the 6v6?
    nosaj
  17. #17
    31,785
    Received: 1,657/7
    54
    Look at the NFB circuit. Start at the cathode of the V1b. You have a 1500 ohm to ground from there. You also have the 22k going over to the OT. The OT secondary winding has essentially no resistance, at least low enough to ignore. That winding is also grounded. That all serves to put the 22k in parallel with the 1500 ohm. Calculate those in parallel, and you get... 1.4k
    Always consider parallel circuit paths when measuring parts in circuit.
  18. #18
    May 2010
    Sioux Falls, SD
    6,184
    Received: 1,107/1
    Given: 878/1
    16
    There are lots of ways to lower output. Also check to see if they are running the 6V6 in triode mode. Is the screen connected like the original schematic?
  19. #19
    Supporting Member Randall's Avatar
    Jan 2013
    Cape Coral, FL
    2,326
    Received: 495/0
    Given: 88/0
    9
    "Also, the NFR is 1.4K and not 22K."
    A few posts earlier you said it was 22k measured out of circuit?
  20. #20
    Aug 2012
    NC, USA
    805
    Received: 116/1
    Given: 54/0
    8
  21. #21
    May 2010
    Sioux Falls, SD
    6,184
    Received: 1,107/1
    Given: 878/1
    16
    Unrelated to your question, but that cathode resistor and cap sandwiched together is a horrible idea!
  22. #22
    Feb 2010
    11,605
    Received: 1,509/23
    Given: 3,827/11
    22
    lol. Somebody start a 'what's for dog's supper' thread.
  23. #23
    Aug 2012
    NC, USA
    805
    Received: 116/1
    Given: 54/0
    8
    Amp belongs to a buddy. He brought it by for me to "clean up." I want to sort out the power issue then start cleaning up the shoddy work.
  24. #24
    Aug 2012
    NC, USA
    805
    Received: 116/1
    Given: 54/0
    8
  25. #25
    Aug 2012
    NC, USA
    805
    Received: 116/1
    Given: 54/0
    8
  26. #26
    31,785
    Received: 1,657/7
    54
    Just a thought. The entire circuit is 12 resistors, and 6 caps. Might make sense to just gut it and build a new circuit.
  27. #27
    May 2010
    Sioux Falls, SD
    6,184
    Received: 1,107/1
    Given: 878/1
    16
    Sorry I asked!
    I'd start here:
    https://www.angela.com/5f1tweedchamp...cuitboard.aspx
    Edit:<simulpost> Looks like Enzo beat me to it.
  28. #28
    Aug 2012
    NC, USA
    805
    Received: 116/1
    Given: 54/0
    8
    Don't think I haven't already considered it. But my inquiring mind still wants to know what the builder did to purposely limit output to 1 watt. Can't be much, but I'm missing it.
  29. #29
    31,785
    Received: 1,657/7
    54
    Oh I am all for you figuring it out, I am interested too.
    I was thinking about cleaning up the mess, it seems that just rebuilding might make more sense. But DO solve the problem first.
  30. #30
    Aug 2012
    NC, USA
    805
    Received: 116/1
    Given: 54/0
    8
    Even went to the trouble to notate so in two spots
  31. #31
    Aug 2012
    NC, USA
    805
    Received: 116/1
    Given: 54/0
    8
    And I am all about gutting it and rebuilding it right on an eyelet board. As soon as we figure this out, that is exactly what I'll do. The soldering is amateur and as pointed out above, some of the wiring and component placement are poorly implemented.
  32. #32
    Sep 2011
    Pace, FL
    3,143
    Received: 1,046/101
    Given: 143/35
    12
    Don't underestimate the resistance of a bad solder joint.
    nosaj
    Just thinking out loud...using a scope at the input then input of 12ax7 and so on. You could see the signal size increase and at some point see it choke out.
  33. #33
    Aug 2012
    NC, USA
    805
    Received: 116/1
    Given: 54/0
    8
    Quote Originally Posted by Randall View Post
    Yes, it was under heatshrink so I had measured it in cirxuit amd got 1.4k. Out of circuit it measures 22k.
  34. #34
    Aug 2012
    NC, USA
    805
    Received: 116/1
    Given: 54/0
    8
    6V6 is wired normal as in that.photo
  35. #35
    Sep 2011
    Pace, FL
    3,143
    Received: 1,046/101
    Given: 143/35
    12
    And the volume pot?
    nosaj
