Results 1 to 5 of 5
Thread: How to repair hardwired connections on peavey kb100
    Twobie
    Jan 2019
    Pelham, NH
    3
    0
    On the kb100 the wires are soldered into small metal tubes that are soldered to the circuit board. A wire has broken off and the other part is stuck in the tube where it connects to the circuit board. Does anyone know either how to get the wire out of the tube or how to remove the tube from the board? I removed the solder from the tube but it still wonít budge.
    Feb 2010
    11,093
    Received: 1,077/21
    Given: 2,698/8
    22
    Those 'tubes' should not be removed from the board. You suck the solder out of it with a solder sucker. There is plenty of room in there that you don't really even need to remove the old wire bit. Just strip back a bit of insulation on the wire and solder it in there.
    Twobie
    Jan 2019
    Pelham, NH
    3
    0
    Thanks for the reply. Yeah, I had success using the solder sucker on a previous one but on this one Iím not having any luck. Looks like they pinched it when the wire was originally installed. Iíll keep at it.
    Sep 2011
    Pace, FL
    2,734
    Received: 763/100
    Given: 110/33
    10
    Quote Originally Posted by Sharaldsen View Post
    If that doesn't work strip back a bit of insulation and coil the wire around the tube then solder it.
    nosaj
    1 Not allowed! Not allowed!
    Twobie
    Jan 2019
    Pelham, NH
    3
    0
    Yeah, that may be my only option. Thanks!
  1. Peavey KB100 Hum
    By misterc57 in forum Maintenance, Troubleshooting & Repair
    Last Post: 08-24-2018, 01:23 PM
  2. Peavey KB100 no sound
    By Tone Meister in forum Maintenance, Troubleshooting & Repair
    Last Post: 10-21-2015, 04:59 PM
  3. 1984 Peavey KB100 Only HUMS
    By Jayz in forum Guitar Amps
    Last Post: 10-15-2013, 07:54 PM
  4. peavey kb100
    By anthillrich in forum Maintenance, Troubleshooting & Repair
    Last Post: 10-09-2009, 10:21 PM
  5. Peavey KB100 Horn Source?
    By dpresley58 in forum Maintenance, Troubleshooting & Repair
    Last Post: 08-06-2009, 02:51 PM
