Results 1 to 6 of 6
Thread: Wah - troubleshooting
    Senior Member Guitarist's Avatar
    Jul 2006
    566
    Received: 8/0
    Given: 10/0
    14
    Today I recall events that involved fixing a wah pedal. I'm wondering if there's a basic procedure to follow to fix one, e.g. Crybaby type and most common issues.
    With an Ω meter I tested the pot - OK
    Replaced upgrading the transistors
    Measured sweep of pot - OK
    Swapped out two electrolytic caps as they seemed in the vicinity of problem - same/OK
    So what next? I'm sure there's a lengthy topic on this but it doesn't show up on a search.
    I did find:
    Measure across the inductor's 33K Ω The inductor has a low DC resistance--normally under 75 ohms. The 33k resistor is in parallel with the inductor, so the in-circuit resistance measured across it should be lower than the inductor's resistance. If you measure a high resistance here (around 100 ohms) then the inductor is probably open.
    1.Positive (Red) at base and negative (Black) at emitter should give you a measurement of 0,45V to 0,75 V
    2.Positive (Red) at base and negative (Black) at collector should give you a measurement of 0,45V to 0,75 V
    3.Negative (Black) at base and positive (Red) at emitter should give you a measurement of 0 Volts
    4.Negative (Black) at base and positive (Red) at collector should give you a measurement of 0 Volts.
    Attached Files Attached Files
    Feb 2010
    11,627
    Received: 1,534/23
    Given: 3,905/11
    22
    What's the problem? Is the switch working?
    Jul 2006
    566
    Received: 8/0
    Given: 10/0
    14
    Yes switch passes clean.
    LEDs work but only unchanging hum is heard during sweep.
    Feb 2010
    11,627
    Received: 1,534/23
    Given: 3,905/11
    22
    And the model is Snarling Dogs Whine-O ?
    Jul 2006
    566
    Received: 8/0
    Given: 10/0
    14
    Yes, today it is. A rather cool pedal really but too big for me. It's a tad confusing...
    thanks.
    Feb 2010
    11,627
    Received: 1,534/23
    Given: 3,905/11
    22
    I don't think that schematic will get you anywhere.
  1. Troubleshooting Amp
    By SpareRibs in forum Maintenance, Troubleshooting & Repair
    Last Post: 02-27-2016, 09:35 PM
  2. Troubleshooting An OT
    By Daver in forum Maintenance, Troubleshooting & Repair
    Last Post: 05-14-2012, 11:29 PM
  3. 5e3 Troubleshooting
    By Javabirds in forum Debugging Your Build
    Last Post: 01-15-2011, 12:00 AM
  4. RAT Troubleshooting
    By ManRay in forum Guitar Effects
    Last Post: 08-11-2010, 01:21 PM
  5. troubleshooting ?- Hum
    By Rattler66 in forum Maintenance, Troubleshooting & Repair
    Last Post: 08-11-2008, 12:21 PM
