Results 1 to 23 of 23
Thread: Tube heater question/idea
    Dec 2017
    Northern Minnesota
    49
    Received: 6/0
    Given: 2/0
    2
    First, I am putting a bunch of parts I collected together to build something.
    I have a PT from a Peavey Classic 30 to use.
    I am thinking 2 el84 and 2 12ax7 tubes.
    The secondary for the heaters on the classic 30 run ac to 4 el84 in series. (it's also rectified for other low voltage stuff, I don't want to do that)
    I was thinking of running the 4 tube fillaments ac, but that would be 6 fillaments to heat. Can I put each 12ax7 in parallel with itself and then run all tubes in series to equal the voltage of the 4 el84s in series?
    Seams to me it should work, but any negatives?
    I was just thinking of keeping it ac for all heaters to save space. (SS high voltage rectifier, there is no 5v tap)
    Kirk
    Mar 2018
    Germany
    1,478
    Received: 1,070/1
    Given: 674/2
    4
    No, but..
    To run 4xEL84 in series the heater supply voltage will be around 25Vac. Each EL84 and each 12AX7 with parallel filaments wants to see 6.3V. But the supply voltage will only split evenly between the 4 tubes if the hot filament resistances are equal. The EL84 filament corresponds to 8.3 Ohm but the parallel 12AX7 filament to 21 Ohm. So each 12AX7 will get a much higher portion of the supply voltage than the EL84s.
    To even out heater voltages you need to wire appropriate resistors (Rx) in parallel with the 12AX7s' heaters, so that 21Ohm//Rx = 8.3 Ohm. I get Rx = 14 Ohm. Wattage rating at least 5W, wirewound.
    1 Not allowed! Not allowed!
    - Own Opinions Only -
    Senior Member Malcolm Irving's Avatar
    Dec 2014
    Derbyshire, UK
    424
    Received: 116/0
    Given: 108/0
    5
    Sorry, it wont work. When you put things in series they have equal currents, but don't necessarily share the voltage equally. A 12ax7 with its two heater in parallel requires 6.3 volts and 0.3 amps (resistance = 6.3/0.3 = 21 ohms), while an EL84 requires 6.3 volts and 0.76 amps (resistance = 6.3/0.76 = 8.3 ohms).
    The overall resistance of your series connection would be 21 + 21 + 8.3 + 8.3 = 58.6 ohms. The voltage from the Classic transformer must be 4 x 6.3 = 25.2. The current in your series connection would be 25.2/58.6 = 0.43 amps. This would give 0.43 x 21 = 9 volts across each 12ax7 and 0.43 x 8.3 = 3.6 volts across each EL84.
    Mar 2018
    Germany
    1,478
    Received: 1,070/1
    Given: 674/2
    4
    Quote Originally Posted by Malcolm Irving View Post
    Seems you missed my post above .
    Dec 2014
    Derbyshire, UK
    424
    Received: 116/0
    Given: 108/0
    5
    Yes - simultaneous posting!
    Dec 2014
    Derbyshire, UK
    424
    Received: 116/0
    Given: 108/0
    5
    Helmholtz suggested parallel resistors would work well. It presents the same load on the transformer as the original 4 x EL84 circuit. (Actually an easier ride for the transformer as the overall 'cold' resistance will be slightly higher.)
    Dec 2017
    Northern Minnesota
    49
    Received: 6/0
    Given: 2/0
    2
    Thanks for the quick reply. Makes total sense. I wasn't thinking of the resistance and mismatched current.
    I could regulate DC to all. Any benefits to either way? (Besides maybe less hum) adding resistors seems easier. I will have to buy parts now either way.
    Thanks again, I've been repairing and adding simple mods for a while. I am new at building / designing. You guys have made me think in a new way about a couple things!!
    Kirk
    Oct 2015
    NEPA
    777
    Received: 153/1
    Given: 110/0
    4
    Why not run 4 of the el84 and 2 12ax7 as the original? You can switch off 2 of the output tubes if needed but leave the filaments lit.
    2 Not allowed! Not allowed!
    Old Timer J M Fahey's Avatar
    Oct 2007
    Buenos Aires, Argentina
    11,262
    Received: 1,443/18
    Given: 1,101/27
    26
    You canīt use "ohms" in this case since filaments are not standard resistors but strongly variable PTCs.
    They can be considered somewhat "equivalent" resistors as they will have some current clue and voltage drop ... but such calculated value will hold only at *that* point and nowhere else.
    That filament winding expects 4 EL84 filaments in series ... and nothing else.
    2 series EL84 ones, will drop 12.6V and pass 0.76 A .
    You need another 12.6V 0.76A load in series or values will be anywhere but needed.
    2 12.6V filament 12AX7 in parallel will pass a total current of 0.3A (0.15A each), so you need a parallel resistor passing 0.46A when dropping 12.6V so 27.4 ohm , and dissipating 6W .
    Mar 2018
    Germany
    1,478
    Received: 1,070/1
    Given: 674/2
    4
    2 12.6V filament 12AX7 will pass a total current of 0.3A , so you need a parallel resistor passing 0.46A so 27.4 ohm , and dissipating 6W .
    Or use the 6.3V/300mA wiring for each 12AX7, wire the tube heaters in series and place a 14 Ohm resistor in parallel with each 12AX7 heater, as I suggested above.
    Or you could wire a single 27.4 Ohm (=~ 2x14 Ohm) resistor in parallel with both 12AX7(6.3V) heaters.
    Why not? We use ohms with PTCs as well. Here we are dealing with the hot (operating) resistance, as defined by the tube datasheet values of nominal heater voltage and current.
    Apart from that, tubes like EL84, ECC83, 12AX7 are designed/recommended for parallel (constant voltage) heating, while some TV tubes (in Europe "P" series) were specially designed for series heating.
    I.e. for the tubes in question, series heater wiring is not the best solution anyway.
    Dec 2014
    Derbyshire, UK
    424
    Received: 116/0
    Given: 108/0
    5
    I think O/P meant the 12ax7 filaments are parallel within the tube (i.e. 6.3V) and then two 12ax7s are in series.
    Helmholtz suggested two resistors, each one in parallel with one of the 12ax7.
  12. #12
    Dec 2014
    Derbyshire, UK
    424
    Received: 116/0
    Given: 108/0
    5
    Yes, true. If I knew the 'resistance' of the filaments as a function of the current passing through them, I could have made an accurate calculation of the voltages and currents resulting from O/Ps original proposal. By assuming nominal 'resistances' my calculation would have worked out with the appropriate voltages and currents, if the proposed circuit was valid. The idea was just to show that the voltages and currents don't work out.
  13. #13
    Dec 2017
    Northern Minnesota
    49
    Received: 6/0
    Given: 2/0
    2
    Thanks again.
    Im not really a fan of fillaments in series anyway. I should wait for a better PT.
    I have an OT for 2 el84 from an old Baldwin organ amp. I have one for 4 el84 as well, but I thought to save that for something better. I just wanted to use what I have to get rid of some crap and learn a little!
    My goal was to only buy caps. Oh well
  14. #14
    Near Dallas Texas
    3,478
    Received: 151/0
    Given: 90/1
    18
    Since you only want to run two output tubes, why not use 12V6 or 12AQ5 or even 25L6. You can probably find NOS tubes cheap.
  15. #15
    Oct 2007
    11,262
    Received: 1,443/18
    Given: 1,101/27
    26
    Tell that to Peavey
    Too late now to complain
  16. #16
    Dec 2017
    Northern Minnesota
    49
    Received: 6/0
    Given: 2/0
    2
    The only reason I have the transformer is the Peavey dealer/repair shop in town clossed. I was friends with the owner/tech. He gave me a bunch of stuff from the back. He maybe didn't know about the thermal fuse.
  17. #17
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    31,589
    Received: 1,477/7
    54
    Why go through all these machinations just to cobble this particular tube set to that particular, but unsuited, PT? Just save the transformer for something else, and get a real PT for your project.
    I have no problem at all with series heaters, they reduce the current considerably when compared to four in parallel. We have various amplifiers that burn up molex connectors with heater current, and this arrangement neatly solves that problem. If one heater opens, it certainly is not a challenge to figure out which one.
  18. #18
    Feb 2010
    11,288
    Received: 1,238/21
    Given: 3,135/8
    22
    You can also use the PT for the HT and run an aux. heater transformer. I think it would be cheaper than another PT, provided you have room for it.
  19. #19
    Bent Member Chuck H's Avatar
    May 2007
    pacific north west
    14,771
    Received: 1,796/4
    Given: 2,004/0
    29
    That's why I gave a thumb to post #8
    Best solution IMHO. 2xel84's is a fun novelty, but IMHE you can easily find yourself under powered at a gig. Just make it four el84's with an option for just using two. Unless this is a consideration for an OT that is already at hand.?. Maybe more stuff needs to be acquired before attempting this spare parts build just to have all the parts that work together
  20. #20
    Near Dallas Texas
    3,478
    Received: 151/0
    Given: 90/1
    18
    They have 12V6GTs at tubesandmore.com for $6.90 Try to find a 6V6 or EL84 for that.
  21. #21
    Dec 2017
    Northern Minnesota
    49
    Received: 6/0
    Given: 2/0
    2
    Thanks for the 12v6 idea!
    Heater current reduction when running parallel is a good point
    I have been thinking about a filament transformer also
    The reason for the cobbling of this stuff is purely learning. I have gigging amps and studio amps. I have nicer parts, but just wanted practice putting together "something maybe different". Without spending much money.
    The chassis I'm putting it in is half of the Baldwin organ chassis. I'm not sure if I would even try to put it in a usable cabnet!
    I'm limited to this PT for a small one. I have a couple giant ones. (without buying one)
    Cheapest option would probably be a filament transformer, but the 12v6 idea sounds fun.
    This 35 below weather always gets me dreamin up some craziness!
    Thanks again!
  22. #22
    Mar 2018
    Germany
    1,478
    Received: 1,070/1
    Given: 674/2
    4
    The more I think about it, the less I like the idea of wiring power and signal tube heaters in series, even using suitable additional resistors.
    Firstly, individual heater voltages depend on the other tubes and may vary by more than 10% as tolerances add.
    But more importantly, I expect increased heater hum problems, especially if the 2 12AX7s are wired for 6.3V and connected in series, as the OP suggested.
    The 12.6V heater version Juan proposed seems favorable in this respect, as it allows one of the heater pins of each 12AX7 to be grounded.
  23. #23
    Oct 2015
    NEPA
    777
    Received: 153/1
    Given: 110/0
    4
    I've run 12ax7 on 12vac (output dual el84's in series)(old 5v, 12v, hv organ transformer) and from what i am reading they say do not use the center tap pin 9 to ground. I used 220 ohms from each leg to ground and it worked out fine. I forget the actual reasoning behind this but it made sense.
  1. Crazy tube idea?
    By Diablo in forum Theory & Design
    Last Post: 05-12-2014, 02:24 AM
  2. Replies: 69
    Last Post: 11-27-2012, 05:40 AM
  3. Idea: Low power subminiature tube amp
    By Koreth in forum Theory & Design
    Last Post: 05-14-2011, 03:38 PM
  4. Mesa/Boogie S.O.B. tube question/idea
    By methodofcontrol in forum Maintenance, Troubleshooting & Repair
    Last Post: 11-13-2010, 08:01 PM
  5. suggestions for non UL stereo tube amp idea
    By imaradiostar in forum Other Amps
    Last Post: 11-11-2008, 01:12 PM
