Results 1 to 8 of 8
Thread: Verify a part: thermo-switch thing
    Senior Member Guitarist's Avatar
    Jul 2006
    543
    Received: 3/0
    Given: 8/0
    13
    Not entirely music related unless it's to keep the hands warm in the shop or a coffee maker in service. I have to replace a thermo-switch thingy in an infrared heater. It's listed at 240V but I need 110V, 16A—stated unoriginal part—and wondering if this value is important or not? Thank you
    https://www.amazon.ca/gp/product/B00...K6Y9EEQB&psc=1
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    31,483
    Received: 1,383/7
    53
    It is a thermostat. 240v is fine, the switch will safely open 240v, so 120v is no challenge. It will pass 16A safely.
    What matters is the temperature. Your link shows a part rated at 145 degrees Celsius. Is that what it says on your bad part?
    1 Not allowed! Not allowed!
    Jul 2006
    543
    Received: 3/0
    Given: 8/0
    13
    OK, that what I was thinking too, thank you. The part says 80 Degrees. It's is mounted through a hole that monitors the heated air area. I found that rating as those that were complaining of the near-new unit switching off after 5 minutes- they suggested that value.
    I also recall seeing one of these in some olde mixer/amp a ways back.
    Appreciated...
    31,483
    Received: 1,383/7
    53
    This type thermostat is common enough. god knows Peavey used a ton of them, but so did many others. They come in various temperatures, and normally open or normally closed. Also variations on the mounting.
    Jul 2006
    543
    Received: 3/0
    Given: 8/0
    13
    Ah right, well thank you so much Enzo. This is my favorite forum and has been for a loooong time
    Guitarist, BC Canada
    Aug 2012
    Great Black Swamp
    2,110
    Received: 315/0
    Given: 771/1
    9
    Good question. The temp rating is switching point, I assume. There'd be a lot of potentially molten household items at 145C...
    31,483
    Received: 1,383/7
    53
    His part says 80 degrees. As to melting, he did say this was from a heater.
    Old Timer J M Fahey's Avatar
    Oct 2007
    Buenos Aires, Argentina
    11,119
    Received: 1,283/18
    Given: 979/24
    26
    If the original part says 80 degrees then respect that.
    We have NO data suggesting anything else.
    Who is "they"?
    Whereb did they pull that value from?
    If unit switches off after 5b minutes, there probably is an very good reason fo that.
    As an example, my 80C set pressing iron becomes a burn-hole-through-shirt and eventually-burn-the-house-down device if I double temperature setting and am not very careful.
    Most plastics stand 80C , most plastics melt or deform at 140C.
    Just thinking aloud.
  1. Ntc thermo switch?
    By Off-Beat in forum Music Electronics
    Last Post: 02-13-2016, 03:28 AM
  2. Thermo Pad or Thermo Grease?
    By AMPREPAIR in forum Guitar Amps
    Last Post: 03-22-2012, 06:11 PM
  3. Does anyone know what this thing is?
    By paggerman in forum Maintenance, Troubleshooting & Repair
    Last Post: 01-17-2012, 01:40 PM
  4. Could someone verify that this bias pot is wired correctly please ?
    By gtrplayr1976 in forum Maintenance, Troubleshooting & Repair
    Last Post: 07-21-2011, 06:54 PM
  5. Using a hybrid wiring method, please verify.
    By jakeac5253 in forum Guitar Tech
    Last Post: 06-11-2010, 01:41 AM
