Might 10KΩ pots work well enough on active pickups?
  • Might 10KΩ pots work well enough on active pickups?
    I have a couple of these 10K pots with push-pull switches and might like to swap these in. The guitar has an EMG 81 and also a Redactive single coil in the neck. BYW, running the neck pickup through a .022 uF cap (IIRC) helps the wean the bass down a bit. So hmm, maybe that 10K would taper off the lows...
    Probably be ok, 10k shouldn’t load the output excessively but need the active circuit schematic for a valid response.
