Results 1 to 10 of 10
Thread: Hardware help
    Senior Member booj's Avatar
    Jun 2008
    635
    Received: 4/0
    11
    Hardware help
    Hi all,
    Trying to get a LIne 6 AxII chassis back together and I lost the screws that hold the two chassis pieces together. I have one screw to compare to. Looks just like a #6 SAE 1/2 inch but it won't fit a #6 nut, so it is probably metric. Hardware store has M3 screws which look to be the same diameter, but its not a .50 thread pitch. Looks to be a .70 pitch looking at the M4 screws. Can't find an M3 .70 pitch screw on line, at EBAY, Mouse, Digi-key, Home Depot, Walmart, Ace hardware, any place on line or a local store. Guess I'll order from Line 6, but just wondering if anybody out there has a line on where such a beast can be found? About 1/2 in. long, round head. Embarasing me, since I had all the screws taped to the chassis (6) but 5 of them went away.
    Thanks for your time
    Feb 2010
    11,093
    Received: 1,077/21
    Given: 2,695/8
    22
    No such thing. .5 is the only pitch for M3.
    How about a fine #6 (assuming you tried coarse 32 vs fine 40 pitch)
    Supporting Member
    Nov 2016
    Nova Scotia
    136
    Received: 51/1
    Given: 137/1
    3
    There is also an M3.5 x .6mm thread. I don't think it is especially common, but worth a try.
    1 Not allowed! Not allowed!
    Old Timer J M Fahey's Avatar
    Oct 2007
    Buenos Aires, Argentina
    11,119
    Received: 1,283/18
    Given: 979/24
    26
    What do they screw on/to?
    If cage or clip nuts, you can probably replace them by similar but available ones; if press fit (Tons required) you are stuck to match originals.
    Care to share a picture or two?
    Jun 2008
    635
    Received: 4/0
    11
    g1, .5 is too fine. The threads actually mesh with a 6-32, but like I said, the screw won't fit in a 6-32 nut.
    Bloomfield. Interesting, but I think I'll just contact Line 6
    JM Goes into press fit boss's in the cover plate.
    I'll just get hold of Line 6. Thanks for your time guys. Appreciated!
    ToneOholic! big_teee's Avatar
    Jun 2010
    Mid-South USA
    11,116
    Received: 721/32
    Given: 693/14
    21
    May not be vintaage correct, but can you tap them to desired size.
    I keep a variety of taps around for guitar, amp type work.
    T
    It's only Rock and Roll, but I like it!
    Feb 2010
    11,093
    Received: 1,077/21
    Given: 2,695/8
    22
    For what it's worth, most of the hardware listed in Line6 service manuals are SAE, not metric.
    Interested to find out what it turns out to be.
    Jun 2008
    635
    Received: 4/0
    11
    Turned out to be 6-32 sae. The reason the screw I had wouldn't fit a 6-32 nut was because the end of the screw was buggerd a little DUH
    2 Not allowed! Not allowed!
    Apr 2010
    Burbank, CA
    1,432
    Received: 443/1
    Given: 1,093/1
    11
    Quote Originally Posted by booj View Post
    We all have had those days. With me, it's the last couple screws I know I don't have spares of, and in the course of driving the screw in, rear panel by the edge of the bench, screwdriver slips, screw escapes yelling 'FREEEEEEEEE.....all the way to the floor, it being black on a black floor, and takes a football bounce into the unknown reaches, just to entice me to lay down on the floor and grovel with a flashlight with fleeting hope of finding the little curd.
    Or, trying to re-thread the M6 screws back into the cage nuts of a Marshall head or Ampeg SVT, where it absolutely refuses to thread in.
    Oct 2007
    11,119
    Received: 1,283/18
    Given: 979/24
    26
    Glad you solved and the knowledge stays for future use.
  1. Where can I get black hardware?
    By Axtman in forum Maintenance, Troubleshooting & Repair
    Last Post: 12-15-2018, 02:39 AM
  2. Where to get hardware for 5E3 cab?
    By vjf in forum Cabinetry
    Last Post: 08-28-2009, 10:03 PM
  3. Sources for good hardware
    By armstrom in forum Cabinetry
    Last Post: 11-08-2008, 11:19 PM
