Results 1 to 2 of 2
Thread: Ampeg SVT-CL OK on bench, fails with a bass.
    Senior Member TimmyP1955's Avatar
    Mar 2007
    Indianapolis
    383
    Received: 12/0
    Given: 10/0
    12
    "Stopped making sound during show." We replaced a bad 6550 with a good pull and all seemed well - biased right up, normal clean output on the bench, runs heavily into clipping with no issues. With a bass and a speaker (4 ohm Marshall) it sounded fine up to a point them it tripped. We installed a new sextet of 6550s - same issue.
    We were unable to find any bad joints. Amp has the 220 Ohm resistors instead of the early 22 Ohm.
    I seem to recall that a particular faulty cap can cause premature tripping, and that there may be a mod for the trip circuit - however this amp is from 2014, so the mod should not be relevant I'm thinking.
    Ideas?
    Apr 2010
    Burbank, CA
    1,306
    Received: 369/1
    Given: 942/1
    10
    Quote Originally Posted by TimmyP1955 View Post
    Ideas?
    That's kind of what I was looking for with this SVT-VR amp that was only exhibiting drop in output level driving an SVT 810 cabinet on stage, being more suspect of one of the power supply caps than a tube. I have had one of the series caps in the main power supply go bad intermittently, which would blow the 10A mains fuse. I'm not aware of any particular mod in the power supplies on these amps for that. I'll have a look at ESR on each of the caps, once I get it apart. I'd like to replace the culprit and not just shotgun the lot of them out of frustration of not finding the cause.
    Not having had any success with stress-testing of our amp, which hasn't blown any fuses, I'm pulling it apart today to dig further. I would have thought the symptom heard on stage would have shown up this past week.
  1. Ampeg Portaflex PF-500 on the bench, waiting for service manual from Ampeg
    By vertamps in forum Maintenance, Troubleshooting & Repair
    Last Post: 08-23-2018, 06:00 AM
  2. Ampeg bass amp
    By Valvehead in forum Maintenance, Troubleshooting & Repair
    Last Post: 10-14-2017, 03:38 AM
  3. ampeg svt-3 pro bass problem
    By amptech in forum Music Electronics
    Last Post: 08-24-2011, 11:06 PM
  4. ampeg ba-115 bass amp.
    By Jose8a in forum Maintenance, Troubleshooting & Repair
    Last Post: 04-28-2010, 05:05 PM
  5. Ampeg BA-115 Bass amp
    By Cal57 in forum Maintenance, Troubleshooting & Repair
    Last Post: 03-30-2010, 11:22 PM
