Results 1 to 5 of 5
Thread: 12at7 question
    Mar 2008
    798
    Received: 92/0
    Given: 208/0
    12
    12at7 question
    Hi, does it any truth 12at7 sound better drived by low impedance source,please? I read somewhere due to its grid conduction and somehow bigger grid resistance it ask for low grid leak resistor for stability operation as 1m ussual (stated in datasheet). Are these the reasons for 12at7 demands for low impedance source, or maybe the other reasons are? For instance if I ensure perfect stable operation why should be the reason to drive it from low impedance source ?
    "If it measures good and sounds bad, it is bad. If it measures bad and sounds good, you are measuring the wrong things."
    Mar 2018
    Germany
    1,906
    Received: 1,431/1
    Given: 835/2
    4
    What is the source and context of that statement?
    A tube has characteristics but no sound of its own (except if you drop it ). The sound influence (meaning frequency response and non-linear behaviour) depends on the whole circuit including the tube. Without specifying the circuit no evaluation is possible. And "better sound" is a rather subjective assessment and depends on the function of the circuit.
    The 12AT7 was primarily designed for lower impedance HF applications, while the 12AX7 being a more linear, higher gain type was optimized for audio purposes.
    5 Not allowed! Not allowed!
    - Own Opinions Only -
    Old Timer J M Fahey's Avatar
    Oct 2007
    Buenos Aires, Argentina
    11,733
    Received: 1,856/22
    Given: 1,453/35
    26
    Agree.
    Sounds like another of those implausible fake Science theories appearing all the time in audiophool sites.
    1 Not allowed! Not allowed!
    Aug 2006
    Lancashire
    649
    Received: 16/0
    14
    Quote Originally Posted by catalin gramada View Post
    Yes it is true that the 12AT7 draws more grid current than the 12AX7 and therefore will clip harder when driven from a similar source impedance, and hence may suffer worse from blocking distortion. Reducing the source impedance and grid leak will help with this, but nothing guarantees a good distortion sound until you try it.
    7 Not allowed! Not allowed!
    Mar 2008
    798
    Received: 92/0
    Given: 208/0
    12
    Quote Originally Posted by Merlinb View Post
    Thanks Merlinb. I had not the oportunity to drive it into blast yet as I live into a flat, but definitely drived 12at7 pi from c.f. changed the sound substantially. My project becomes way more touch sensitive with a lot of sustain, not quite compression one, and easy prone to get in feedback reaction on entire range. It changed completely dynamics in something else. It was very easy to bias directly from previous c.f. so the source impedance was very low indeed, but the signal applied was few mV order so nothing to put 12at7 into grid phenomena. From comparison drived from regular 12ax7 plate sound very anemic.
  1. Question on 12AT7
    By Alan0354 in forum Guitar Amps
    Last Post: 01-11-2014, 02:29 AM
  2. 12AT7 vs AX7 in V1 for dynamics?
    By daz in forum Theory & Design
    Last Post: 06-23-2013, 10:10 AM
  3. Question about replacing 12AX7 with 12AT7 in PI
    By Steve A. in forum Theory & Design
    Last Post: 11-16-2011, 03:47 PM
  4. 12at7 in 5e4?
    By scole in forum Tweed Builders
    Last Post: 06-19-2008, 02:43 AM
  5. 12at7 vrs 12ay7
    By macdillard in forum Tweed Builders
    Last Post: 11-16-2007, 04:54 PM
