Are you experiencing crossover distortion prior to clipping? More important,.. You mentioned that gain increased with reduced NFB, so, are you experiencing crossover distortion at the previous maximum gain level? It's possible the increased gain is allowing the tubes to attempt drawing some grid current and the coupling caps are charging. You could try decreasing the coupling cap value.
Best way to cure output osscilation
Last edited by Chuck H; 02-17-2019, 01:25 PM."Take two placebos, works twice as well." Enzo
Originally posted by Chuck H View PostAre you experiencing crossover distortion prior to clipping?"If it measures good and sounds bad, it is bad. If it measures bad and sounds good, you are measuring the wrong things."
Originally posted by catalin gramada View PostYes, that I talking about, there are not severe but still. Sending more feedback into loop cure it, otherwise running power tubes hotter did not help. Thanks"Take two placebos, works twice as well." Enzo
Trying to post a pic, found is much better today, but still can see. The mains voltage get lower with 10v around from 232v yesterday to 223v now.....
I measured everything slightly before clipping in respect with the bias voltage was set
Sorry for images was not pretty accurate, it is still pretty noisy, I have a spider on the table"If it measures good and sounds bad, it is bad. If it measures bad and sounds good, you are measuring the wrong things."
I don't think it's likely to be crossover distortion in the sense of 'tubes being too near cut off at zero crossing', rather it's probably 'gm doubling' distortion, as discussed https://music-electronics-forum.com/...ad.php?t=41210
Due to that, the transfer function is nowhere near straight, so waveforms will get distorted; try plugging the numbers into nickb's interactive valve data sheet page http://bmamps.com/ivds.html
I suggest not to worry about it, it's part and parcel of class AB tube amps, so don't lose sleep and tube life by attempting to run the tubes so hot that the transfer function straightens out.My band:- http://www.youtube.com/user/RedwingBand
Is the crossover distortion (or transfer function) occurring above or below your previous gain level when you used more NFB?"Take two placebos, works twice as well." Enzo
I never get before clipping before, that was with 15 db nfb instead 8db now that means top of semialternances was squashed first then crossover distortion appears. Now get crossover dist before peaks to clip"If it measures good and sounds bad, it is bad. If it measures bad and sounds good, you are measuring the wrong things."
I understand. But does the amp currently produce the same gain without crossover distortion as before when you were using more NFB. Or, let me ask this a different way...
What was the maximum gain before clipping when you were using more NFB?
And
What is maximum gain before crossover distortion now that you are using less NFB?"Take two placebos, works twice as well." Enzo
Originally posted by Chuck H View PostI understand. But does the amp currently produce the same gain without crossover distortion as before when you were using more NFB. Or, let me ask this a different way...
And
What is maximum gain before crossover distortion now that you are using less NFB?"If it measures good and sounds bad, it is bad. If it measures bad and sounds good, you are measuring the wrong things."
Ok, let me show you some numbers:
With 470 ohm nfb resistor: 26vpp PI input -77vpp PI output -58vpp OT (meant no trace of clipping, it clips at 64vpp arround)
With 1.5k nfb resistor: 10vpp PI input - 56vpp PI output- 45vpp OT (the output is far away from clipping but at this voltage I can see first trace of crossover distortion on the scope)"If it measures good and sounds bad, it is bad. If it measures bad and sounds good, you are measuring the wrong things."
I would ask though, is this amplifier intended for sound reinforcement or as a guitar amplifier?Last edited by Chuck H; 02-17-2019, 05:00 PM."Take two placebos, works twice as well." Enzo
Originally posted by pdf64 View PostI don't think it's likely to be crossover distortion in the sense of 'tubes being too near cut off at zero crossing', rather it's probably 'gm doubling' distortion, as discussed https://music-electronics-forum.com/...ad.php?t=41210
Of course "gm doubling" doesn't mean actual increase in gm. Rather voltage gain increases in class A region as the load current is shared between 2 tubes, making each tube see "doubled" load impedance.
But what's wrong with a little distortion in a guitar amp?Last edited by Helmholtz; 02-17-2019, 04:50 PM.- Own Opinions Only -
Originally posted by Helmholtz View PostThe signal waveshape shows (slightly) reduced slope near zero-crossing. That's just the opposite of what you would expect from "gm doubling" and is typical for dominating tube non-linearity near cutoff (reduced gm)...
As the issue is only reported to manifest at very high signal levels, I wonder if there's some degree of grid rectification going on, increasing the effective bias voltage.My band:- http://www.youtube.com/user/RedwingBand
Originally posted by pdf64 View PostYes, I agree, I posted before I'd seen the scope pics; I'd been expecting the kink to further along from the zero crossing.
As the issue is only reported to manifest at very high signal levels, I wonder if there's some degree of grid rectification going on, increasing the effective bias voltage."Take two placebos, works twice as well." Enzo
Found crossover distorsions appears as amplification goes up.this was not present with 15db nfb before. There is a way to get rid of it?
It is bias shifting which appears at high power, a very diffeent thing, in my way is "natural", it was "always there since day one" , is an important part of tube sound (so much so that Transtube and others create it on purpose, go figure) and people startted worryoing about it *only* after they started scoping amplifiers , misinterpret it and, of course, "listen with their eyes" so itīs now "unbearable"
Snowflakes.
[/rant mode]Juan Manuel Fahey
