Hello, I just recorded some pretty high amplitude 300 kcps osscilation at the OT output with speaker connected. This are not present with a resistor, and also are suprimed with speaker and resistor in parallel. Sometimes are suprimed just connected one of my voltmeter over outputs, sometimes just disconnected one of preamp stages. It is not a well trusted osscilation but when appear is pretty consistent. Does it worth to bother to found its source into circuits or just to suprimed snubbing it over the OT winding, please?
Best way to cure output osscilation
Last edited by catalin gramada; 02-14-2019, 11:21 AM."If it measures good and sounds bad, it is bad. If it measures bad and sounds good, you are measuring the wrong things."Tags: None
Just to be clear, it's some thingie in there causing it.
Last edited by catalin gramada; 02-14-2019, 02:26 PM."If it measures good and sounds bad, it is bad. If it measures bad and sounds good, you are measuring the wrong things."
First all I am not surprized that the oscillation stops when you wire a load resistor in parallel with the speaker. Amp stability is influenced by open loop frequency/phase response, NFB ratio and open loop gain. All three of these influences depend on load impedance. A speaker has an impedance of over 100 Ohm above 100kHz and turns the phase because it is inductive.
Also your PI circuit has a much wider HF bandwidth than typical designs, which makes things worse. The main reason is the low impedance cathode follower driving the PI input. As a consequence the Miller effect limiting HF response at the PI input grid in standard high impedance designs is essentially eliminated.
To reduce HF gain of the PI, you can try to wire a capacitor of 100p or more between the PI plates.
To compensate for the reactive speaker impedance, a suitable Zobel network across the OT primary is recommendable.- Own Opinions Only -
Are the power tube 1k and 10k grid resistor bodies mounted at the tube socket terminals?
Is the feedback resistor 470 ohms?
That seems a lot of NFB (16ohm output, 470 ohm/100 ohm feedback network).My band:- http://www.youtube.com/user/RedwingBand
Thank You gents,
Yes 1k and 10k resistors are over the tubes socket, 470 ohm resistor on nfb ( ca 15 db) Weird thing I had before the pi, biased by cathode bias resistor and did not noticed any problems. And just now is osscilate by a margin, sometimes did sometimes not, but when appear is pretty consistent and around 2v pp level.
Also, when osscilation appear get some buzzy ,sort of hum noise in speaker but not found any components to justify those noise ,other than this 300khz osc. I can suspect a bad component like 12at7 tubes, which from my curiosity I toasted hk insulation at 150v for a while, but it measured very good so I think are out of question.
This osscilation appear not suddenly at startup. It takes 10 sec around after the stb switch is engaged, of course with tubes all ready heatedLast edited by catalin gramada; 02-14-2019, 06:19 PM."If it measures good and sounds bad, it is bad. If it measures bad and sounds good, you are measuring the wrong things."
Is it stable when open loop?
OT plate wires, and LTP output wires, twisted? As these wire pairs carry balanced signals.
With using that tap and those feedback network resistor values, you are applying a lot more NFB than a regular BF Fender.Last edited by pdf64; 02-14-2019, 06:23 PM.My band:- http://www.youtube.com/user/RedwingBand
Plates wires are not, there are a lot of building issues I have to cover but just for now it is a platform for experiment. It was excellent stable before to try this c.f. direct coupled with pi stage. Maybe is a building issue and becomes more vulnerable to osscilate due to rised hf sensitivity as Helmholtz states"If it measures good and sounds bad, it is bad. If it measures bad and sounds good, you are measuring the wrong things."
Originally posted by J M Fahey View Post+1 on too much feedback and check whether problems disappear with NO NFB applied.
Just try it.
Then use something like 1k5 to 2k2 instead of the 470 ohm one.
And above suggested 100pF plate to plate at the PI
I cleaned it a little:
[ATTACH=CONFIG]52528[/ATTACH]
the original drawing made my eyes bleed.Last edited by catalin gramada; 02-17-2019, 12:27 PM."If it measures good and sounds bad, it is bad. If it measures bad and sounds good, you are measuring the wrong things."
