Now THIS is what I call a TRUE Ground (fake as h*ll but who´s counting?)
  • Now THIS is what I call a TRUE Ground (fake as h*ll but who´s counting?)
    The solution to all our grounding problems: a portable grounding block which since it´s *active* works anywhere (provably even in the vacuum of Space 35000 Miles away from Earth):
    https://highend-electronics.com/prod...SAAEgJDe_D_BwE
    ONLY:
    $3,295.00 USD
    ..... a bargain considerin you get 4 FREE mains cables, which are worth over U$1500.
    This is the interface between "The Ground Block" and our poor,dirty, plebeian wall outlet ... that alone justifies the price:
    It's perfectly simple:
    Filtration is handled by a UEF Ground Filter that’s 3 times the size of the original's UEF Ground Filter and this translates into 3 times the performance of the passive ground filter alone.
    To this we add an Active ULF Field generator as found in our PowerCell 12 UEF which re-clocks high-frequency ground noise to the Earth’s Schumann resonance as well as noise generated inside connected components at the circuit level, so each connected component’s performance is fundamentally transformed at the source.
    With such a lucid explanation it must obvious to all but a simpleton how this works. Right?
      This makes me want to listen to the Cephalic Carnage album "Lucid Interval." The album as far as the sound of the band is similar to the writing of the paragraph Nick posted because even a small amount of exposure leaves your mind in a state of totally obliterated. Some people like that
        Like Metal Machine Music ?
          I have not checked out Metal Machine Music but I will. I have been told in the past to check it out and for some reason I never have!
          Noise/experimental music is awesome. The kind that tears real instruments to shreds
            How about a $225.00 beeswax fuse.
            It keeps the fuse element from vibrating.
            https://highend-electronics.com/prod...eswax-shd-fuse
            Oooh!
              Oooh!
              Right! Because it's a bummer to have to swap out fuses to find one that's not microphonic
                Oooh!
                Not just that. " This fuse will give you tighter bass and yet sound relaxed - very natural sounding. The sound stage will become bigger and deeper, more detailed, better layering, better micro detail but with a relaxed musical presentation"
                  I think it's not an issue of microphonics. It's an issue of every time you turn the amp on and off there is a surge of current that goes through the fuse and the little wire will slightly flex. After it slightly flexes back and forth for about 20 years there is about a 1% chance the fuse will fail due to metal fatigue. So now, all your worries can be put aside.
                    So you are trying to tell me that artificial candle wax will sound the same as natural beeswax? No way...
                      I had to listen. Now I wish I hadn't.
                        I'd be more concerned about the wax in my ears degrading the sound than the wax in my fuses.
                          "The new Ultimate is extremely difficult to build considering Audio Magic is drilling into both sides of the fuse now, sometimes it takes up to 3 tries to get one good fuse"
                          I guess they can't get a real fuse maker to even talk to them.
                            It´s hard to align holes at ends of fuse tubes when your only tools are a rusty nail and the heel of your fairy boot.
                              Lou Reed was quoted: "only an idiot would listen to MMM from beginning to end."
                              So, naturally I did exactly that. But I never told him about it.
                              For those curious would-be listeners, it's sort of a Mandelbrot set. That is, by hearing any part of it, you've essentially heard all of it. Hope this saves yez some time, and keeps smart MEFsters out of the idiot squad.
