I'd think the current being balanced for the 2 sides of the OT would be preferred.
Ampeg SVT 6146 open screen & Plate resistors
So I think I will probably call AES Monday to swap these tubes out. I will ask them to kindly to put aside these 6 tubes in case I need to swap any out. It's nice living 20 minutes away from that place.When the going gets weird... The weird turn pro!
So I took a trip over to AES today and got 6 more of these tubes. I set the bias supply voltage to -52v for both sides and started testing a pair at a time. The first sextet that I got last week measured at 16.7, 19.5, 25.1, 26, 30.1 & 33.5ma. The sextet that I just picked up today is 15.5, 17, 19.6, 32.3, 32.5, & 33ma. So obviously neither set was matched but now I can select a sextet out the twelve tubes and return the other six that I don't use.
So I have this sextet where the bias is 26, 30, 32.3, 32.5, 33, & 33.5ma. The other sextet is 15.5, 16.7, 17, 19.5, 19.6, & 25.1ma. Which one should I choose? I am leaning towards the first set.
Also, AES does actually match the tubes on their Apex tester. So that part about the factory doing the matching and putting labels on the box was not accurate. As ususal the true tube tester is the amplifier. I have to give a shout out to AES for having the greatest customer service and for taking great care to make things right.When the going gets weird... The weird turn pro!
Are these tubes being tested for current in the amp and in the same socket? Each tube should be plugged into the same socket one at a time. Just wanting to be sure there's nothing un-adjusted (or a leaky cap) about the amp that may be skewing the results."Take two placebos, works twice as well." Enzo
Originally posted by DrGonz78 View PostWhich one should I choose? I am leaning towards the first set.
Implementing their tube testing system was a master stroke for AES, it upped their game considerably. However, there is one more thought, at what plate / screen grid voltage are they testing? We know 700V and 350V are what the tube is going to see in an SVT, so testing at those voltages would be primo. I know of only one tube dealer that will go to the trouble of testing at specified operating voltages, Jim McShane in Chicago, but I doubt he has a quantity of 6146B to offer. For other tubes, he sticks with ones he feels he can trust. Apparently Jim got bitten by some lousy JJ's earlier in the century, and he still avoids them to this day. No JJ power tubes to be found there last I checked.This isn't the future I signed up for.
Originally posted by Leo_Gnardo View PostYes, the percentage spread is lower on the first set, and with lower Pc readings less likely that one will "run away".Logic is an organized way of going wrong with confidence
Originally posted by Chuck H View PostAre these tubes being tested for current in the amp and in the same socket? Each tube should be plugged into the same socket one at a time. Just wanting to be sure there's nothing un-adjusted (or a leaky cap) about the amp that may be skewing the results.When the going gets weird... The weird turn pro!
Implementing their tube testing system was a master stroke for AES, it upped their game considerably. However, there is one more thought, at what plate / screen grid voltage are they testing? We know 700V and 350V are what the tube is going to see in an SVT, so testing at those voltages would be primo. I know of only one tube dealer that will go to the trouble of testing at specified operating voltages, Jim McShane in Chicago, but I doubt he has a quantity of 6146B to offer. For other tubes, he sticks with ones he feels he can trust. Apparently Jim got bitten by some lousy JJ's earlier in the century, and he still avoids them to this day. No JJ power tubes to be found there last I checked.When the going gets weird... The weird turn pro!
Originally posted by Leo_Gnardo View PostWith all that testing, you will have identified the "safe sextet"When the going gets weird... The weird turn pro!
Originally posted by nevetslab View PostI likewise concur with Leo. DrGonz78 did state he had preset the bias on both upper/lower halves, so I presume the same TWO tube sockets were being used in getting the current readings on each pair. That's how I do it when I'm getting my initial readings. I'll select the triad of tubes for each half from that, put them all in, then will do a final biasing for equal average current, let it burn in a while, and do a final trim afterwards. I forgot which Ampeg amp you're working on. Most of our inventory here are SVT-CL's, so each tube has its' own 10 ohm cathode resistor. On SVT-VR's, I made a clear plexiglass test panel with probe openings to get across the plate resistors with all six tubes in place, or in pairs as well (using long EZ-Hook probes). Earlier SVT's also have plate resistors, accessible from the bottom.
https://ampeg.com/support/files/Sche...20Version).pdfWhen the going gets weird... The weird turn pro!
So I finally got 6 tubes in the amp and biased to 72ma each side. Gonna start audio testing tomorrow and hopefully this beast of an amp will stay off my bench for the rest of my life.
Quick question about the 10A fuse. It calls for a GLH 10A fuse which an obsolete part. The damn fuse in there was a 32v 10A fuse, of course! I think GLH is a fast acting type so I put an AGC fast acting 10A 250v in place. Is this correct?When the going gets weird... The weird turn pro!
Originally posted by DrGonz78 View PostI think GLH is a fast acting type so I put an AGC fast acting 10A 250v in place. Is this correct?This isn't the future I signed up for.
