Stupid question---
  • Stupid question---
    Been sick for 5 days and cant focus here---stupid question...
    i think the answer is no---shared ground on my can caps .
    ive got a couple 100/100 uf/500v can caps here i was going to use in this old 2203 Marshall--but it looks like i cant due to the shared ground of my caps --see the "four" 100uf filters ?----i think i need 4 separate caps.
    https://drtube.com/schematics/marshall/2203u.gif
    i do have some 50/50 uf cans here if i can use them
      Yes, the four 100uf caps need to be separate, and make sure the neg terminal of the upper ones are not grounded.
      I have seen series can caps, but those are rare.
      It is the common ground that is killing you. A common 50/50 would only work for the ones up along the tops.
        thats what i thought-------------------cheers Enzo
          That is not a stupid question. There are some non standard things going on in that schematic that did not endure.
