Results 1 to 7 of 7
Thread: How much extra capacitance can I use?
    Supporting Member
    Feb 2007
    Seattle WA
    386
    Received: 22/0
    Given: 2/0
    13
    I am working on an Ampeg J-12 amp that has a 40/20/20uf @450v multi-section can capacitor. I am considering changing it to one I have in my stash that is 40/40/40uf @450v. Should I use it?
    I know that transistor circuits require lots more power filter capacitance, especially in demand heavy circuits like bass amps. This is why transistor power supplies have hundreds or thousands of uf capacitance. I have been told that more capacitance on tube circuits can stress the rectifier tube, but the Ampeg amp has a solid state rectifier.
    So back to my original question. When is too much capacitance too much?
    Old Timer
    Chill-Ville, VA
    2,860
    Received: 417/4
    Given: 830/9
    15
    It's generally only a concern if you have a tube rectifier, and then only for the first capacitor in the line. Which model if Jet & rectifier do you have? It may slightly change the tone of the earlier stages, but that's subjective.
    Also, the specs on the vintage can were probably something like +80/-20% or vice versa. Meaning, it may not have been that far from what you have to begin with...
    Jusyin
    1 Not allowed! Not allowed!
    Mar 2018
    Germany
    1,190
    Received: 791/1
    Given: 546/2
    4
    Quote Originally Posted by Axtman View Post
    Regarding rectifier stress it's only the first/main filter capacitor that matters. And it seems that would not change using your replacement.
    A general design analysis would mean evaluation of turn-on surge current and repetitive charging currents wrt. rectifier specs.
    - Own Opinions Only -
    Supporting Member
    Feb 2007
    Seattle WA
    386
    Received: 22/0
    Given: 2/0
    13
    Thanks Justin!
    I have the Ampeg J-12.
    Attached Files Attached Files
    Old Timer
    Chill-Ville, VA
    2,860
    Received: 417/4
    Given: 830/9
    15
    Cool, you have a SS rectifier. The reason I ascked was cuz there was the first J-12 I think in the 50s, then the J-12-A, B, D, & I believe D. I've gotva T with the extinct & unobtainium 6BK11s, subbed w. 6C10s (also nearly extinct & unobtainium.
    Justin
    Feb 2010
    11,030
    Received: 1,013/21
    Given: 2,544/8
    22
    As far as transistor amps needing more capacitance, I think it's more that the high capacitance values are not available at the high voltage ratings needed for tube amps. At least not affordable ones.
    Even more so back when tubes were the norm for all electronics.
    Mar 2018
    Germany
    1,190
    Received: 791/1
    Given: 546/2
    4
    Smoothing quality (low ripple voltage) not only depends on filter capacitance but also on charging series resistance and and discharging current.
    SS amps generally are low impedance/higher current circuits. So for same smoothing they require much more filter capacitance than tube amps.
    3 Not allowed! Not allowed!
  1. is capacitance capacitance?
    By daz in forum Music Electronics
    Last Post: 01-19-2015, 07:57 PM
  2. Extra gain stage from extra triode
    By Spitfireb in forum Mods & Tweaks
    Last Post: 11-04-2010, 07:33 PM
  3. Can you have too much filter capacitance?
    By Axtman in forum Theory & Design
    Last Post: 07-17-2009, 02:33 AM
  4. Replies: 4
    Last Post: 03-19-2009, 12:35 PM
  5. Stray capacitance???
    By MikeT in forum Maintenance, Troubleshooting & Repair
    Last Post: 07-12-2008, 01:05 AM
