Page 14 of 14 FirstFirst ... 4891011121314
Results 456 to 464 of 464
Thread: Screaming Bright Switch Cap??? - 1974 Fender SF Twin Reverb Master Volume Push Pull Switch
  1. #456
    Join Date
    Feb 2019
    Location
    San Francisco, CA
    Posts
    245
    Thumbs Up/Down
    Received: 64/0
    Given: 301/0
    Rep Power
    0
    Quote Originally Posted by Chuck H View Post
    Take 'em out!
    that's all i needed to hear ... LOL
    The trem on that amp in the video sounds like @$$. All garbled and distorted. I wouldn't be chasing that video as a tonal standard to aspire to otherwise either. But now I'm just being a wet blanket.
    I'm with you, however I think everything on that video sounds bad and I am thinking is the camera's mic being unable to handle the powerful twin
    0 Not allowed! Not allowed!
  2. #457
    Supporting Member
    Join Date
    Mar 2018
    Location
    Germany
    Posts
    2,750
    Thumbs Up/Down
    Received: 2,082/1
    Given: 1,186/2
    Rep Power
    5
    that network DOES introduce a small low pass filter
    Yes, cuts treble above 16kHz.
    1 Not allowed! Not allowed!
  3. #458
    Join Date
    Feb 2019
    Location
    San Francisco, CA
    Posts
    245
    Thumbs Up/Down
    Received: 64/0
    Given: 301/0
    Rep Power
    0
    danke! i should not hear a difference if everything happens above 16KHz.
    actually here's an easy side by side comparison on how the circuit looked like during the evolution from the ONLY MASTER VOLUME version (010182 RevC) to the addition of the PULL BOOST (45377 RevE).
    It's clear that that arrangement (12K, .01uF, 1M) is not there in the ONLY MASTER VOLUME version
    however, additionally there is a 1K resistor that is also not there
    the landmarks I used to identify the common components are marked in GREEN and the differences in RED
    I guess that now the complete question is: should i remove: 12K, .01uF, 1M AND the 1K resistor?
  4. #459
    Bent Member Chuck H's Avatar
    Join Date
    May 2007
    Location
    pacific north west
    Posts
    15,934
    Thumbs Up/Down
    Received: 2,772/4
    Given: 3,249/0
    Rep Power
    30
    I don't suspect that area of the amp and it's circuitry in your previous problem. I doubt you'll hear a difference. You can simply lift one end of any of those components to see if it makes any difference for yourself. But to ask us if you "should" isn't something we can answer because the amp is not on any of our benches. I think you should try because the idea seems to please you. If it causes a problem you can put them back.
    "In fact when I run into problems working on electronic circuirts, there are so many times that when I finally track it down, the source of the problem is located between my soldering iron and my seat." SoulFetish
    "Being born on third base and thinking that you must have hit a triple is pure delusion!" Steve A
  5. #460
    Supporting Member
    Join Date
    Mar 2018
    Location
    Germany
    Posts
    2,750
    Thumbs Up/Down
    Received: 2,082/1
    Given: 1,186/2
    Rep Power
    5
    The 1k resistor just adds to the 470k, resulting in 471k +/- 10%.
    This HF filter may even have a beneficial effect, as it will attenuate residual oscillation blips. So best try both ways as Chuck recommends.
    Is there still a problem with the amp?
    2 Not allowed! Not allowed!
  6. #461
    Join Date
    Feb 2019
    Location
    San Francisco, CA
    Posts
    245
    Thumbs Up/Down
    Received: 64/0
    Given: 301/0
    Rep Power
    0
    I think there's not... but I will only know if I remove these components and find out it sounds better! LOL
    + you're totally right about the 417K
  7. #462
    Join Date
    Feb 2010
    Location
    Posts
    12,207
    Thumbs Up/Down
    Received: 1,947/24
    Given: 4,918/11
    Rep Power
    24
    Agree with Helmholtz that the circuit could 'accidentally' help prevent oscillations above 16khz so keep this in mind if anything weird happens with it gone.
    As a side note, since you just worked on the trem; not sure if I mentioned this already but this era Fender sometimes has the shielded cables dressed very close to the trem bug, and it can have quite an impact on the trem 'ticking' problem.
  8. #463
    Join Date
    Feb 2019
    Location
    San Francisco, CA
    Posts
    245
    Thumbs Up/Down
    Received: 64/0
    Given: 301/0
    Rep Power
    0
    yes! I had that problem in the past with the tremolo and fixed it by adding the .022 uF cap tremolo tick fix (which was actually a fix Fender came up with)
    thx!
  9. #464
    Join Date
    Feb 2010
    Location
    Posts
    12,207
    Thumbs Up/Down
    Received: 1,947/24
    Given: 4,918/11
    Rep Power
    24
    Ok, I mentioned that for the cases where the cap fix doesn't get rid of it all.
Thread Information
Users Browsing this Thread
  1. Replies: 16
    Last Post: 02-19-2019, 04:31 PM
  2. 1979 Super Reverb Push Pull Pot Master Volume Replacement
    By bobloblaws in forum Maintenance, Troubleshooting & Repair
    Last Post: 09-23-2018, 01:23 AM
  3. Replies: 4
    Last Post: 07-13-2013, 06:50 AM
  4. recapping a 100w 75 silverface twin reverb with push pull master...Need Advice please
    By wheatley in forum Maintenance, Troubleshooting & Repair
    Last Post: 07-30-2012, 11:33 PM
  5. 72 Twin Reverb Bright Switch Replacement
    By npunk42 in forum Repair and Restoration
    Last Post: 12-13-2011, 03:28 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
