Tone stack calculator
  • Tone stack calculator
    Hello. Does it exist any Duncan TSC version for Android? Or exist any possibility to run it under Android with a JavaScript emulator, please? Thanks
    "If it measures good and sounds bad, it is bad. If it measures bad and sounds good, you are measuring the wrong things."
    I believe it's a native Windows program. It would require a substantial re-write to run under Android which is a version of linux running Java and native apps.
    There are some circuit simulators around for Andriod (e.g. EveryCircuit, iCircuit..) so you could model your tone stack using one of them. That said I've never even looked at one. It's hard enough using a big LCD for schematics let alone a tiny one.
      People nowadays want to do *everything* with their phones
