Results 1 to 10 of 10
Thread: Modding a '60s Laney PA100
    Twobie
    Feb 2019
    5
    Received: 1/0
    0
    Hello all,
    First post here. I used to post on the now-defunct Plexiboard so hello to anyone that was there.
    For some years I've been playing guitar through a late '60s six channel 100W Laney PA. 6 preamp channels, effects loop with take-up gain stage (yes, really - advanced for the time), 4 x EL34s. It's the "Supergroup" PA and the power section is identical to the Laney Supergroup guitar amp. The pre is a simple one valve two gain stages per channel with a version of a James stack in between. Schematic available here.
    I've crudely cascaded two of the channels together for gain and made some other small tweaks, but now it's time to mod it properly into a guitar amp.
    I've prepared a little schematic to build an overdrive preamp in channels one and two drawn from the Laney Supergroup but with a slightly tweaked James stack. The original James stack on this had a mid-bump - I've tweaked it to have a mid scoop. The original Supergroup had a Fender-style stack.
    I'm pretty new to this, so I'd be grateful if someone could look over my schematic and tell me if you think it looks ok before I order in all the parts.
    My schematic is here. NB this is just the pre. It goes through to the power section as shown in the original schematic above.
    Many thanks for any input.
    Cheshire, UK
    2,239
    Received: 545/4
    Given: 288/0
    16
    Should the second stage have 470k from grid to ground?
    The third stage has 100k plate and cathode resistors. Is it supposed to be a cathode follower?
    Twobie
    Feb 2019
    5
    Received: 1/0
    0
    that 470k resistor/cap combo i lifted from the Supergroup preamp section. See here
    Re. the 100k cathode resistor on stage 3, i think that's a mistake. Should be 1.5k.
    Cheshire, UK
    2,239
    Received: 545/4
    Given: 288/0
    16
    Quote Originally Posted by parker_knoll View Post
    I was thinking R15//C12 and R16 give treble boost. It won't be as effective if R16 is missing
    1 Not allowed! Not allowed!
    Supporting Member
    Mar 2018
    Germany
    2,341
    Received: 1,788/1
    Given: 1,021/2
    5
    The two 470k resistors in the original circuit are primarily for mixing/separating the signals from the input triodes. You are already using one of them (including treble boost cap) before the second stage. But as Dave H suggests, it might be a good idea to wire the other one to ground to get enough treble boost. The RC highpass needs to see some load.
    This will actually reduce the level of lower frequencies by 50%.
    The 470k connected to the plate of your triode No.4 will just reduce its available output voltage by around 50%.
    - Own Opinions Only -
    Twobie
    Feb 2019
    5
    Received: 1/0
    0
    A belated thanks for these contributions. I will do without the treble booster. I can try it without the 470k on the plate of Triode 4. I guess it was there in the PA version of the amp to reduce to risk of valve distortion.
    Here's the amended version. If it looks viable. I will get the parts ordered. Right now when I turn my amp on it sounds like a school of dolphins and I don't want it to blow up.
    Sep 2011
    Pace, FL
    3,230
    Received: 1,116/102
    Given: 151/36
    12
    Invalid link for amended version.
    nosaj
    Twobie
    Feb 2019
    5
    Received: 1/0
    0
    Quote Originally Posted by nosaj View Post
    nosaj
    Sorry, Google Drive being funny. Try this: https://www.dropbox.com/s/ykmn72s7nr...up-V2.png?dl=0
    Feb 2010
    11,831
    Received: 1,666/23
    Given: 4,279/11
    22
    Don't change anything til you figure out how to get that 'school of dolphins' sound into a pedal. Take my money!
    Twobie
    Feb 2019
    5
    Received: 1/0
    0
    To do school of dolphins properly you really need the correct vintage gear. A pedal is a poor imitation
  1. Replies: 12
    Last Post: 05-01-2016, 06:41 PM
  2. Fender PA100 build
    By chris937 in forum Build Your Amp
    Last Post: 12-20-2014, 08:14 PM
  3. Fender PA100
    By pnut5150 in forum Maintenance, Troubleshooting & Repair
    Last Post: 11-15-2014, 06:38 AM
  4. pa100 reverb conversion question
    By 01redcobra in forum Mods & Tweaks
    Last Post: 04-21-2009, 06:53 PM
  5. How to convert Fender PA100 to guitar amp
    By 01redcobra in forum Conversion Projects
    Last Post: 03-06-2009, 05:03 AM
