Caver PT 1250 SMPS Caps
  • Caver PT 1250 SMPS Caps
    I've got a bunch of Carver PT1250s here. They have a primitive SMPS which uses a pair of series 2700uF 200V Sprague electrolytics for high-side smoothing. (this is the 230V model BTW). These have burst on several of the amps.
    Is there any earthly reason that I shouldn't replace them with a single 1500uF 400V device, provided that ESR and ripple current spec exceeds those of the originals?
    I'm guessing that large, high-voltage electrolytics weren't available when the amps were built in the mid 80s.
    https://elektrotanya.com/carver_pm-2.../download.html
    Please point out which capacitors are the ones mentioned in your post.
        No reason not to, if they physically fit. Price seems to be on par now either way.
