Page 2 of 2 FirstFirst 12
Results 36 to 39 of 39
Thread: taming a Rod Piezo
  1. #36
    Supporting Member
    Join Date
    Jan 2018
    Location
    Michigan
    Posts
    207
    Thumbs Up/Down
    Received: 28/0
    Given: 54/0
    Rep Power
    2
    plan #1 is leaving the Alumitone set up as is , piezo to a 10k pot both sent to a TRS stereo out jack , stereo Y cable out, send the piezo through a pre-amp(tech 21 is on the way) to one amp , Alumitone out to another amp . I have more than one build, so I'd still like to have an internal blend set up , haven't decided which way to go on that yet. JM if you are still contemplating on providing a sketch please do , this is not a push!! so please don't feel it is , would like to try a DIY/w help something.
    0 Not allowed! Not allowed!
  2. #37
    Join Date
    Mar 2018
    Location
    Germany
    Posts
    1,161
    Thumbs Up/Down
    Received: 770/1
    Given: 531/2
    Rep Power
    4
    Quote Originally Posted by shortcircuit View Post
    It is no good idea to connect a 10k pot to the piezo. A piezo PU is a high impedance capacitive source, a typical capacitance value being 1.5nF. Connecting this to a 10k pot produces a high pass filter with a corner frequency of above 10kHz! This means that all frequencies below 10kHz will be strongly attenuated.
    The minimum load resistance should be 1M. But a 1 M pot will noticeably reduce highs at lower vol. settings.
    There is actually no good passive solution to your problem.
    1 Not allowed! Not allowed!
  3. #38
    Old Timer J M Fahey's Avatar
    Join Date
    Oct 2007
    Location
    Buenos Aires, Argentina
    Posts
    10,968
    Thumbs Up/Down
    Received: 1,105/15
    Given: 831/23
    Rep Power
    25
    Ok, here´s the very low consumption (0.2mA meaning 4000 playing hours from a typical 9V alkaline ) chopped to the bone Piezo/magnetic preamp.
    Fails safe, IF battery dies (which by itself will take Months or Years ) you simply turn Balance pot fully towards the Magnetic pickup and continue playing.
  4. #39
    Supporting Member
    Join Date
    Jan 2018
    Location
    Michigan
    Posts
    207
    Thumbs Up/Down
    Received: 28/0
    Given: 54/0
    Rep Power
    2
    Thank you JM , very nice design, I will start gathering components , will have to order a few , I'll give it a go and let you know.
    Thanks again really appreciate it.
Thread Information
Users Browsing this Thread
There are currently 2 users browsing this thread. (0 members and 2 guests)
  1. Blackstar HT-DISTX taming
    By tbonuss in forum Music Electronics
    Last Post: 11-08-2016, 10:10 PM
  2. Taming high B+
    By Rhodesplyr in forum Other Amps
    Last Post: 08-08-2014, 04:26 PM
  3. Changing Piezo Coax Cable for Ceramic Piezo Element
    By astaf in forum Music Electronics
    Last Post: 08-23-2010, 01:21 PM
  4. Taming Yamaha's noisy fan?
    By Le Basseur in forum Music Electronics
    Last Post: 01-12-2008, 01:25 AM
  5. Taming splashy reverb
    By tonezoneonline in forum Maintenance, Troubleshooting & Repair
    Last Post: 08-13-2006, 04:53 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
